Author Topic: modify/ alter coin mechs?  (Read 1710 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: March 26, 2007, 02:14:49 pm »
I currently have a happs coin mech that accepts UK currency 50 pence pieces only. I there a way that I can alter or modify my mechs so that they can accept all coins?
Would appreciate advice and your help?
am_monkee
  • Last login:April 29, 2009, 09:48:45 am
Re: modify/ alter coin mechs?
« Reply #1 on: March 26, 2007, 05:58:31 pm »
I know a member here sells mechs that accept all coins. Here ya go:
http://forum.arcadecontrols.com/index.php?topic=63787.0
This was posted a couple weeks ago, so there's probably some still left if you want to go that route. Otherwise, I believe I saw a tutorial on how to do this. I'll search for it and post it if I can find it.
am_monkee
« Reply #2 on: March 26, 2007, 06:10:10 pm »
I remember coming across this a while back. I haven't tried it, but my friend did and he said it works great-accepts any coin.
Here's the link:
http://www.russprince.com/cabinet/
then click on 'coin door' on the left.
It's a pretty detailed description and there's pics. This guy's is also a Happs, so it should be the same (or at least similar). Hope it helps.
Marky_1979
    • Personal Webspace
« Reply #3 on: March 26, 2007, 06:30:59 pm »
Thanks mate I will check it out appreciate your help
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #4 on: March 26, 2007, 07:02:43 pm »
The mech you're showing a picture of is an IL universal system mechanical mech. It's a fixed mech.... which is why we don't use them in the arcade. They're popular in the USA when they buy them fixed to take quarters or tokens. Mostly because US currency doesn't change. In the UK we have the problem that every few years, the idiots in charge, change the shape size and materials of our coinage.
The answer to this depends on how you want your coin door and credits to react when you insert a coin.......
If you don't care how many credits you get...... IE you put 50p in you get 1 credit... you put 10p in you get one credit... you put £1 in you get 1 credit.... Then you don't need a coin mech at all. Remove the coin mechs and create a cardboard tube chute that runs from the top of the mech holder to the bottom where the microswitch is. Whatever coin you put in there will then just roll straight down the chute give you a credit and nothing will be rejected.... you can even stick washers in there and get a credit.
If on the other hand, you want to get 1 credit for 50p.... 2 credits for £1 ..... 6 credits for £2... 10 credits for £4.... etc etc etc...  Then it gets more expensive.  You'll need two electronic mechs, not mechanical ones and a Credit Board to count the coins. If you need more details of that then yell up and I'll post them.
Best Regards,
Julian (Fozzy The Bear)
« Last Edit: March 26, 2007, 07:05:20 pm by Fozzy The Bear »
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
Marky_1979
    • Personal Webspace
« Reply #5 on: March 26, 2007, 09:56:05 pm »
« Last Edit: March 27, 2007, 07:40:48 pm by Marky_1979 »
Marky_1979
    • Personal Webspace
« Reply #6 on: March 27, 2007, 07:42:02 pm »
Yes Fozzy this sounds like what IM after could you please tell me all about it?
