Author Topic: smart strips, still good?  (Read 1629 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: March 24, 2007, 07:05:45 pm »
So do you guys still like your smart strips?  I am looking at getting a LCG3 or LCG4.
I b**ch. People listen!!
emerica
  • Last login:September 18, 2024, 09:27:07 pm
  • Goodtimes!
    • My ongoing projects
Re: smart strips, still good?
« Reply #1 on: March 24, 2007, 07:15:30 pm »
I always liked the idea of the bits limited power strip but never wanted to shell out the money for one. Instead I ended up going with the spystyle power strip and it works just as good. I think there is a tutorial somewhere on this forum but I am unable to find it at the moment.
I saw the best minds of my generation destroyed by madness, starving hysterical.
am_monkee
  • Last login:April 29, 2009, 09:48:45 am
« Reply #2 on: March 24, 2007, 07:16:29 pm »
yes. it's convenient for me to have 1 button that turns on the speakers, pc, monitor, etc. for 30 bucks, it's worth it to not have to open the cab every time i need to power up and it's a very simple solution.
TOK
  • The Game Always Wins
« Reply #3 on: March 24, 2007, 08:32:50 pm »
I have one, and it's been fine, but I found the one that Sears offers does the same thing and I don't have to order it.
Its in the tool department, made for powering on a lamp or other device when you fire up a power tool. Using one in my vert cab with no problems. Has less outlets than a Smart Strip, but I only need the PC, marquee light and monitor anyway.
More Cowbell
  • That's just dumb!
« Reply #4 on: March 24, 2007, 08:41:04 pm »
$30? That seems steep for the one switch to rule them all. I just buy a regular old $1.99 power strip, open it up, remove the switch, wire in a new switchto wherever it is on the cab, and close it back up. Plug everything into it and use the cab switch to turn it on and off. Works like a charm, it's easy, and costs next to nothing.
I've got a fever...
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #5 on: March 24, 2007, 09:02:06 pm »
I hope you're not turning off your PC by flipping the power on your power strip.
I like my BitSmart strip, it does just what I need it to. I don't consider it expensive, but I don't have a "use what was lying around" cab, so the money wasn't an issue for me. If you're on a budget maybe it's too much.
squirrellydw
« Reply #6 on: March 24, 2007, 09:05:19 pm »
thanks, I am going to get one.  what another $30 on top of $2000
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
« Reply #7 on: March 24, 2007, 09:27:15 pm »
I hope they are still good...just ordered one today.
Thirty bills may seem expensive, but you must consider that you are getting a surge suppressor also. Most of the $1.99 strips offer no protection other than a circuit breaker. Checking in the stores, you will find that a comparable surge strip cost about the same as the Smart Strip.
Xam
Can't talk to a psycho like a normal human being.
brian23
  • Last login:September 07, 2011, 03:52:01 pm
« Reply #8 on: March 25, 2007, 09:07:27 am »
I have had my SmartStrip for two years now in a muggy Florida garage. No problems whatsoever, nor has my PC had problems. I don't run it all the time, so I suspect that the SmartStrip will last a while as I only play my arcade every so often, but it is handling well.
Loki
  • Last login:August 14, 2012, 08:00:32 am
    • Deathnote
« Reply #9 on: March 25, 2007, 09:30:40 am »
I have this one... I was supposed to use this on for my pc, but atm using it for my tv... I guess it's the same as a SmartStrip.
When the master goes off the rest will also turn off.
Got it for uhh... 8 euro I think (about $10?)
I'll be using it when I start my cab :)
Don't eat yellow snow.
