Author Topic: Popular Mechanics Spade Bit Test  (Read 7100 times)
ElKootcho
  • Last login:October 22, 2012, 07:58:43 pm
« on: March 16, 2007, 12:59:34 pm »
In the current issue of PM they did a test using a standard spade bit vs. two new designs (Greenlee Self-Feeding Spade Bit & Irwin Speedbor Max Spade Bit). For those that care, the results and video are here: http://www.popularmechanics.com/blogs/home_journal_news/4212305.html
« Last Edit: March 16, 2007, 05:36:34 pm by ElKootcho »
Re: Popular Mechanics Spade Bit Test
« Reply #1 on: March 16, 2007, 01:02:52 pm »
Nice.  It always drives me crazy when a bit shatters through the other side to the point that I usually clamp on a second piece behind the whole to prevent it.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #2 on: March 16, 2007, 02:10:32 pm »
That really sucks. The speedbor max spanked em all but there's no 1 1/8". :cry:
Maybe they'll expand their selection if they're popular. Cutting that good I don't see why they won't sell really good. I may pick up a set anyway...
It's 9am. I'm calling it a nite.
kingflynn
  • Last login:May 01, 2023, 07:39:02 am
« Reply #3 on: March 16, 2007, 02:22:14 pm »
When just the tip of the bit pokes through the other side, back out of the hole and finish it from the back. No splintering.
NiteWalker
« Reply #4 on: March 16, 2007, 02:26:00 pm »
That's a possible solution but a backer board clamped under the workpiece is easier and faster and works just as well.
ElKootcho
« Reply #5 on: March 16, 2007, 03:15:12 pm »
I just sent a message to their customer service dept http://www.irwin.com/irwin/consumer/jhtml/contactUs.jhtml   Maybe they have them "in the works". I'll post the response when I get it
Kaytrim
  • I'm too nice a guy
« Reply #6 on: March 16, 2007, 04:32:28 pm »
Their standard speedbore spade bit comes in 1 1/8" in the standard length shaft.
http://www.irwin.com/irwin/consumer/jhtml/detail.jhtml?prodId=IrwinProd100186
They even have a 1 1/8" standard twist bit.
http://www.irwin.com/irwin/consumer/jhtml/detail.jhtml?prodId=IrwinProd100130
TTFN  :cheers:
Kaytrim
NiteWalker
« Reply #7 on: March 16, 2007, 07:42:25 pm »
They're nice (their normal spade bits work great and are very cheap), but they're not speed bor max bits...
I just thought it would be nice. Button holes in less than 5 seconds each. That's some good stuff. :cheers:
kingflynn
« Reply #8 on: March 16, 2007, 11:57:51 pm »
You're right, when drilling all the holes in a control panel.  But for one or two holes, I'd rather not run to my truck for clamps and scrap.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #9 on: March 17, 2007, 05:31:39 am »
Knowing beforehand that you'd be drilling holes, why would you have left those things in your truck?  Or did the need to drill those holes jump out in the middle of the road at you? ;)
kingflynn
« Reply #10 on: March 17, 2007, 03:28:01 pm »
For one, because I don't need a piece of scrap and clamps to drill a hole.  Secondly, as a frame to finish remodeling contractor,  the need to drill holes does occasionally jump out at me.  My drill and bits are usually nearby.  Clamps usually mean a run to the truck   :)
fjl
  • Pixels Rule!
« Reply #11 on: March 21, 2007, 10:38:33 pm »
I've used some of those bits in the past for drilling. They are superior but like they mentioned, they pull you in when drilling. They feel like they are sucking the drill towards the wood. Of course you need a pretty strong drill otherwise it will get stuck midway perhaps damaging your drill. This is not the kind of drill bit you can drill then pull back out while its spinning like can be done with normal drill bits. It either goes all the way through or you have to start spinning it backwards.
NiteWalker
« Reply #12 on: March 26, 2007, 05:35:03 pm »
Did you get a response yet? I just sent an email inquiring about the same thing. Hopefully they'll respond with good news. According to the website all their products aren't listed.
As of now I'm having wet dreams of that bit in 1 1/8" ripping through control panels...
Imagine, a whole control panel drilled in less than a minute. :notworthy:
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #13 on: March 27, 2007, 04:12:08 am »
I would buy a 1 1/8" version in half a second. As NiteWalker said, it would make drilling CP holes incredibly fast.
Anybody else feel that popular mechanics maybe should have researched some more talent for their videos though?
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
ElKootcho
« Reply #14 on: March 27, 2007, 09:16:49 pm »
Nope, Haven't heard a peep from them
NiteWalker
« Reply #15 on: March 27, 2007, 10:01:04 pm »
I got a reply today:
"I have not heard anything about adding the 1/1/8" size, but I will
forward your inquiry to the product manager for consideration.
Sincerely,
Ken Glardon"
I'll keep inquiring until they add the 1 1/8" size.
ElKootcho
« Reply #16 on: March 28, 2007, 05:18:51 pm »
Same reply:
"Currently this size is not available but I will forward your inquiry to
Sincerely,
Ken Glardon
shorthair
« Reply #17 on: March 29, 2007, 02:19:07 pm »
Coming in from the lower depths, here: why would you use a spade bit vs a whole saw? (Or vice versa?)
« Reply #18 on: March 29, 2007, 02:26:57 pm »
Or maybe half a saw?
Crax
  • Hmm......maybe you should get that test still
  • Last login:March 12, 2022, 04:11:41 pm
« Reply #19 on: March 29, 2007, 02:48:15 pm »
Sent an email in today as well asking for a speedbor max in 1-1/8"
Hopefully all these emails will convince them to at least give it a try.
NiteWalker
« Reply #20 on: March 29, 2007, 05:43:26 pm »
A spade bit cuts through wood and MDF much faster in my experience. Hole saws are best for metals. I used a holesaw for MDF and it burned badly and made a messy paste of the waste. It was a brand new dewalt bi-metal holesaw. I use it for drilling aluminum nor. Works great.
shorthair
« Reply #21 on: March 29, 2007, 08:37:27 pm »
Hahahahahahah....oh ---fudgesicle---.  Um, yeah.  Thanks, NiteWalker.
« Last Edit: March 29, 2007, 08:44:55 pm by shorthair »
Kaytrim
« Reply #22 on: March 30, 2007, 12:42:51 pm »
I have used a hole saw as well and found that if you 'bounce' the saw as you are running the drill the MDF clears the teeth allowing it to bite deeper.  Once the pilot bit makes it's way through start from the back side and finish the hole.  Makes a nice plug for filling misplaced holes.  The only problem I have found is that the saw gets dull rather quickly.
Now that I have the proper spade bit though I am not going to use the hole saw anymore unless I need a plug.  The spade bit works much better and quicker.
TTFN :cheers:
Kaytrim
RyoriNoTetsujin
  • Last login:March 23, 2024, 03:55:45 pm
« Reply #23 on: March 31, 2007, 10:48:38 am »
...our good friend Mr. Eric Sofge was really not meant to be in front of a camera.  Jeebus.  Did anyone else notice the moment where, rather than just crossing his arms, he basically hugs himself while he's talking?  (it happens right when the other guy starts talking.)  Extremely indicative of nervousness and discomfort.  PM needs to hire an actor next time ... or at least a voice over guy...
*sobs at another gig lost...* maybe next time...  :dunno
On topic?  Yay speedbor bits!
« Last Edit: March 31, 2007, 10:50:12 am by RyoriNoTetsujin »
