Author Topic: Forgot to dampen before using gorilla glue.  (Read 19687 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: March 08, 2007, 10:36:39 am »
Hey guys I am way behind the Gorilla Glue part of my project, but I forgot to dampen with water.  The only thing I used the glue for was mouting the 2x2 blocks to the inside of the cab to mount the monitor shelf.  Now I did use wood screws also.  It has had a TV in there for like 2-3 months and all seems okay.  You think it will be okay over time.
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
Re: Forgot to dampen before using gorilla glue.
« Reply #1 on: March 08, 2007, 01:36:50 pm »
I question the long-term durability of Gorilla Glue, no matter whether you dampen the surfaces or not. Plus the stuff foams all over the place and creates a huge mess! I don't use anything but Titebond these days...
That said, if you've used a reasonably large screw you probably don't have anything to worry about.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #2 on: March 08, 2007, 03:20:25 pm »
I agree that gorilla glue is overrated and more importantly, overpriced. And as mentioned overmessy. ;)
If plain woodglue was used (I prefer the Titebond family of glues) and properly clamped, the bond would be stronger than the wood itself; meaning that if the joint were to fail, you'd see torn wood fibers, not a broken glue joint.
Titebond FTW.
It's 9am. I'm calling it a nite.
rdowdy95
  • This is my rifle.
« Reply #3 on: March 08, 2007, 06:15:54 pm »
There are four #8 wood screws in each mounting block as well so I think I will be okay.  I was just checking.  The rest of the cabinet is acutally pretty much done with glue from a hot glue gun or some elmer's wood glue.  But yes I use wood screws as well.
acevedor2
  • Last login:May 25, 2024, 08:21:24 pm
« Reply #4 on: March 10, 2007, 01:34:12 pm »
Ok, I will be the lone dissenter....for now.  I have used Gorilla Glue NUMEROUS times on things you would not even imagine you could use Gorilla glue on.  It has far exceeded my expectations.  I concur entirely that the stuff can make a mess, but once it hardens, you can just cut/scrape/sand off the excess. Again, this is just my opinion but I really like the stuff.
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
NiteWalker
« Reply #5 on: March 10, 2007, 01:38:01 pm »
Where gorilla glue really shines is its ability to glue odd materials together. But then again so can epoxy...
But for wood or wood products I think any of the 3 titebonds will work fine. Much cheaper as well.
