Author Topic: Xbox 360 Controller Hack Tutorial -- Wireless Hack Now Available!!!  (Read 544965 times)
butteroj
  • Last login:December 18, 2021, 06:12:24 pm
Re: Xbox 360 Controller Hack Tutorial -- Wireless Hack Now Available!!!
« Reply #280 on: June 28, 2009, 12:45:50 pm »
Does anyone know of an alternate solder point on a 2009 madcatz wired?  The pad ripped off on mine  :hissy:
magitek
  • Last login:August 11, 2009, 12:11:18 am
« Reply #281 on: July 02, 2009, 01:51:28 am »
On the 2009 MadCatz controller, does anyone know what the 10 silver points in the center are for? The first few are labeled S0, and S1. Has anyone traced that particular pcb? (Besides just knowing where the regular contacts are)
SG Jaycurl
  • Last login:January 30, 2017, 01:19:43 pm
« Reply #282 on: July 02, 2009, 01:51:31 pm »
An alternate point for what? Which button/direction, etc.
SG Jaycurl
« Reply #283 on: July 02, 2009, 01:52:18 pm »
I haven't personally seen a full map of all the alternate points, etc. I've been around the 'net on this one quite a bit, too.
DagYo!
  • Newbie
  • Last login:September 05, 2009, 10:57:54 pm
« Reply #284 on: July 03, 2009, 07:11:20 pm »
HarumaN I've got money in hand for 2 wireless controllers. email me if you would TheRealDagYo@gmail.com
« Reply #285 on: July 04, 2009, 10:29:18 am »
HarumaN I've got money in hand for 2 wireless controllers. email me if you would x@z.com
magitek
« Reply #286 on: July 11, 2009, 07:35:45 am »
Haruman,
I noticed in the pic of your hacked madcatz you offer that all your wires seem to be going below the controller, but the pcb diagrams don't indicate where those points are. Are all the buttons accessible from below? Do you have a diagram?
« Reply #287 on: July 11, 2009, 11:13:42 am »
Haruman,
A diagram of the solder points?
http://slagcoin.com/joystick/pcb_diagrams/360_diagram3.jpg
magitek
« Reply #288 on: July 11, 2009, 04:18:53 pm »
Haruman, in your thread about your hacking services, the pic of the madcatz controller has red wires going under the controller and none on the top of the face buttons. What points were you using? The diagram you posted doesn't list those points on the underside, only clicks, bumpers, and triggers...
I'm confused ???
« Reply #289 on: July 12, 2009, 10:01:49 am »
I'm confused ???
Oh, that was an unfinished pic.  I just posted that one when I figured out how to hack the triggers on the new MadCatz pad.  The wires on the bottom are for RT & LT
magitek
« Reply #290 on: July 13, 2009, 09:02:21 pm »
HarumaN, I have some money that has your name on it, check your pm  ;D
« Reply #291 on: July 13, 2009, 11:35:07 pm »
Did you send me a PM?  I don't have one from you... can you try again?
magitek
« Reply #292 on: July 14, 2009, 12:19:16 am »
Ok, sent.
Let's hope 3rd time's the charm, heh. (The very first time it failed I think)
« Reply #293 on: July 14, 2009, 09:29:44 am »
Ok, sent.
Got it, replied via email.
butteroj
« Reply #294 on: July 14, 2009, 04:50:03 pm »
This is for the Start button.....
dppham
  • Last login:September 16, 2009, 06:08:46 pm
« Reply #295 on: July 21, 2009, 01:33:09 pm »
how do i find the high low and wiper. im not sure if i connected it right
http://i901.photobucket.com/albums/ac211/dppham/IMG00036-20090713-1931.jpg
fjl
  • Pixels Rule!
« Reply #296 on: August 03, 2009, 01:26:10 am »
Is there any way to remove the plastic mechanism for the trigger buttons without damaging them or having to solder off the potentiometers? Cause it looks like I would have to either break the plastic or solder off the potentiometer to remove them. Two things I want to avoid.
Also, what should I do to move the headset jack from the controller to one of the sides of the arcade stick housing?
« Last Edit: August 03, 2009, 02:42:46 am by efjayel »
Volk
  • Last login:August 09, 2009, 05:30:36 am
« Reply #297 on: August 06, 2009, 11:21:18 pm »
hey ppl i know how to wire the controller and everything but i only dont know how to do one thing.... and its how to conect the wires to the joystick, i have been looking for tutorials but they only tell you how to wire the controller and i would like to some on to tell me how to conect it or sold it to the joystick cuz its my first time doing this kind of stuff and i dont wanna screw it  ):  so plz some one help me  (:
thx
« Reply #298 on: August 07, 2009, 07:35:33 am »
Hey, take a look at slagcoin.  They have a ton of info.
Here is a diagram from them:
Volk
« Reply #299 on: August 07, 2009, 06:44:19 pm »
thx for the info man..that was alot of help and now i understand a little bit more (:
but now im stuck with other things now  xP  in the diagram they use only one ground for all the signals of the joystick and i have ground wires for each of the signal wires... did i screw it already?  :0
« Reply #300 on: August 07, 2009, 06:57:21 pm »
Nope, you can eliminate their common ground, and just wire up your separate ground to each button.
Volk
« Reply #301 on: August 08, 2009, 01:03:54 am »
yeah i know that i can do that with the buttons but the problem its with the joystick...thats what i mean for one ground only and dont really know how to make that  :0 ....  i make a diagram based on the one you posted so you can tell me how to do it cuz i have 4 direccional signal wires (up,down,left,right) and for each the direccions i have grounds so i wanna know how to doit like the diagram u posted or another way cuz i really wanna make it right  (:
thx again and have patience on me... its my first time doing electronics and this kind of stuff  xP
« Reply #302 on: August 08, 2009, 08:10:00 am »
There is a pcb that runs around the joystick.  You simply have to break the ground wire on it (in 4 places) and then wire directly to the switches.
northerngames
  • Trade Count: (+18)
« Reply #303 on: August 08, 2009, 07:31:00 pm »
all you need to do is connect the 4 seperate switch's ground's on the joystick to any one main ground wire on the PCB.
you could run all 4 switch's with their own seperate ground wire all running to the main ground or you can run 1 single wire to be used as a ground to connect to all 4 switch's ground to ground and then have it run to your main ground off the PCB
that one ground wire can connect to any other ground wire wether it is one connected to your buttons in the control panel or to a ground of the printed circuit board but it all has to connect ground wise
see how your buttons are wired and notice the switch is the same as your joystick?
now wire the joystick the same as your button switch's as they are the same exact thing.
1 signal 1 ground for each switch.
the signals need to be seperate but the grounds do not you can run everything with it's own seperate ground that would eventually run into one main ground "the hard way" or you could dasiy chain 1 ground to them all "the Easy Way" or you could do a little of both.
to make it short there schematic is wrong so here it is corrected  :laugh2:
« Last Edit: August 08, 2009, 08:03:08 pm by northerngames »
fjl
  • Pixels Rule!
« Reply #304 on: August 09, 2009, 02:39:48 am »
Volk
« Reply #305 on: August 09, 2009, 05:30:36 am »
ok so i need to use the pcb of the joystick to conect all the grounds?
i found this vid and the dude from the vid sold the grounds (or signals?) to the joystick pcb... so i need to do it that way?  :0
thx
Hendew
  • Last login:September 20, 2009, 08:51:57 pm
« Reply #306 on: September 20, 2009, 06:44:30 pm »
Hey I need some help guys I have a new 360 wireleess controller that I am trying to hack I went to slagcoin.com and got the wireless pcb map, but it is totally wrong. I know this cause I did a continuity test on the board. Anyone know where I can get a proper diagram?
Hendew
« Reply #307 on: September 20, 2009, 08:51:57 pm »
nevermind I figured it out. I did buy a new wireless controller but however it was the late version, I was just being dumb and thought well the controller is new so it must be the latest hardware.
« Reply #308 on: September 21, 2009, 09:59:13 am »
Anyone looked into using the PCBs out of one of the guitar controllers?  I took apart an extra Xplorer and it's got reasonably large traces and I think most of the inputs you'd need...
Can you snap a pic of that PCB?
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
« Reply #309 on: September 21, 2009, 11:41:15 am »
I haven't looked into it at all, but I have a PCB from my original Rock Band drums lying around, and it would be an easy hack. I have a feeling the guitar would be just as easy to hack, but you are only going to get 5 play buttons out of it. (A,B,X,Y & RB)
versapak
  • I am t3h GAY!!!
« Reply #310 on: September 21, 2009, 12:30:09 pm »
Pretty sure the whammy and strum bar are two additional inputs, are they not?
And you've got the d-pad, start, select, and home.
The whammy and strum bars are what would be the right and left analog sticks, and I said play buttons.
There are plenty of games that you can play with only the 5 buttons, but why bother being limited? If funds are such that a cheap madcatz is out of reach, and you have the guitar wasting space, then I guess it is an option. I just personally don't see it as one worth bothering with.
versapak
  • I am t3h GAY!!!
« Reply #311 on: September 21, 2009, 04:27:22 pm »
Ah well, you're determined to be right so you win.  I think you'd get another input out of the tilt sensor, too.
It was just something I had contemplated as I've seen people throwing these controllers away, and hauled one out of the trash last week...
I'm not just determined to win. I am also right. You are guessing as to what is there, while I know exactly what is there.
Green = A
Red = B
Blue = X
Yellow = Y
Orange = RB
Whammy = right analog stick from center to right
Tilt = right analog stick pushing up
Strum Bar = d-pad up & down
5 way selector = various positions of the left trigger
Back, Start, Guide and D-Pad are all self explanatory.
On a rock band guitar the solo buttons are the same as the regular buttons with the addition of having the left stick click pressed as well.
If what it offers sounds sufficient for you to use as a hack for an arcade setup, then by all means go for it. I was simply stating its limitations.
[EDIT]
I notice that I stated in my other post that the strum bar was analog stick. That is incorrect, and what I have in this post is correct.
Oooops :)
« Last Edit: September 21, 2009, 04:30:19 pm by versapak »
northerngames
« Reply #312 on: September 22, 2009, 07:43:30 pm »
those look very easy to work with
the second pcb pic could be bypassed completly by just using the wire's that are running to/from the 2nd pcb to the main one so that could be eliminated right off the get with ease but still have it's function through the wire's or their solder points on the main pcb.
GuerillaDust
  • Newbie
  • Last login:October 01, 2009, 05:35:36 pm
« Reply #313 on: October 01, 2009, 05:35:36 pm »
So I'd like to make a wireless 360 Fight stick
I've never done this though
Can someone give me a list of all materials I need?  I think I'm going to make it out of a shoebox for my first run since I'm not so great with tools.
I have a 360 wireless controller so part 1 is done
Now what else do I need?
versapak
  • I am t3h GAY!!!
« Reply #314 on: October 01, 2009, 06:07:57 pm »
A stick, some buttons, some wire, some quick connects and some solder, but first...
Read up on the wealth of information already on the subject. The Wiki is probably a good place to start.
Mikeosoft
  • Last login:February 27, 2013, 10:38:00 pm
« Reply #315 on: February 19, 2011, 12:34:57 pm »
hi sorry to bring up an old thread, but I'm in need of 2 xbox 360 controller hacks for a naomi universal cab i'd like to play 360 on (some marvel vs. capcom 3)  do you still offer?
« Reply #316 on: February 19, 2011, 12:58:14 pm »
PM sent
ark_ader
  • I glow in the dark.
« Reply #317 on: February 20, 2011, 06:50:03 pm »
I'm looking at that Datel Pro to play Pacman CE on.
Do you think it will be suitable?
  • Last login:Today at 10:22:04 am
« Reply #318 on: March 17, 2011, 09:41:50 am »
I have a Mad Katz padhack where the "right" direction has stopped responding.  :'( I saw this coming as I've read somewhere that these things tend to fail after a while. Is it possible to use the analog input just for one direction? In my mind it would be possible for it to go from off->on just like a digital input somehow by bypassing it's pot?
Edit: I successfully used one of the analog directions and now I have full functionality again, even though it feels like a somewhat dirty fix. It will have to do for now.
« Last Edit: March 17, 2011, 10:42:01 am by emphatic »
thecig
  • Last login:January 06, 2016, 09:55:18 pm
« Reply #319 on: March 21, 2011, 10:55:05 pm »
HarumaN u have a PM from me :)
