Author Topic: Chrome panelling ?  (Read 2554 times)
Solocade2008
  • Last login:March 06, 2012, 10:04:40 pm
    • Solocade
Chrome panelling ?
« on: March 07, 2007, 09:12:18 pm »
I'm looking for some chrome panelling for the kick board of my cabinet. Anyone know where to buy some?
Anything chrome will do for about a 24" x 6" area covering the mdf.
Can't seem to find anything...  :dunno
Chrome sheet metal?
Chrome vinyl adhesive?
Chrome plastic?
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Re: Chrome panelling ?
« Reply #1 on: March 07, 2007, 09:19:53 pm »
im not sure what to call it, but I have seen people use the edged chrome metal on kickplates its the same stuff you see on running boards on a truck not sure what you call it
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Loki
  • Last login:August 14, 2012, 08:00:32 am
    • Deathnote
« Reply #2 on: March 07, 2007, 09:23:57 pm »
diamond plate :)
Don't eat yellow snow.
divemaster127
« Reply #3 on: March 07, 2007, 09:33:45 pm »
there you go, i have seen this used on the kickplates it looks great & its tough
dm  :laugh2:
Donkey_Kong
    • CNC Machines
« Reply #4 on: March 07, 2007, 09:44:59 pm »
and you can buy diamond plate at any Menards in MN...Look somewhere in the hardware area near the screws. Then find a little display bin of Diamond plate and the like. They sell it in small strips and square sheets...Expensive as all get out though.
You could get it cheaper if you had a connection to your local steel man.
somunny
  • Is it hot in here?
« Reply #5 on: March 07, 2007, 10:33:46 pm »
You'll need polished stainless diamond plate if you really want that "chrome" look.  Get a piece of stainless sheet metal (doesn't have to be diamond plate) cut to the dimensions you want and find a place near you that does metal polishing.  Shouldn't cost more than $25-$30.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #6 on: March 07, 2007, 10:37:57 pm »
Why not just use a regular kick plate for a door?  I think they sell a highly polished stainless steel version which would look like chrome.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #7 on: March 08, 2007, 01:18:43 am »
Additionally, Wilsonart (same thing as Formica) makes crome laminate.  It is applied exactly the same as normal formica and can be manipulated with the same tools (jigsaw/tablesaw, router with flush-trim bit).
Best Kid iPad Apps
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #8 on: March 08, 2007, 09:38:37 am »
flat chrome panel = mirror, no?
NO MORE!!
somunny
« Reply #9 on: March 08, 2007, 09:53:02 am »
This stuff is sweet.  I've been meaning to order some samples.
crashwg
« Reply #10 on: March 08, 2007, 09:53:59 am »
Keep in mind that you won't be able to cut something that is chrome plated without it chipping and cracking.
At my local Lowes they have diamond plate stainless that is polished pretty well...
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
shmokes
    • Jake Moses
« Reply #11 on: March 08, 2007, 04:18:06 pm »
That's one nice thing about going with the laminate.  it does chip/crack right around the cut, which is why you cut it big enough that there's a 1/4" or 1/2" overhang over the piece to which it's being applied.  Then you run a router with a flush-trim bit along the edge to make it flush with the work piece.  No chipping when you use a router.
The one rather large problem with laminate, though, is you will likely have to special order a specialty laminate like that (you can order it through Home Depot, for example), but the smallest piece you'll probably be able to get is 4'x8' and the metal laminates are quite expensive.  So, hopefully, if you go this route you have some other surfaces that you would like to be chrom that you can use the leftovers for.
If you'd like an example of what it would kind of look like, I've posted a picture on the message board at one point of a control panel I covered in a Wilsonart brushed aluminum laminate.  It looks fantastic.  I'll see if I can dig it up.  It's not chrome, but it might give you an idea as to the quality.  And keep in mind that you also have the convenience of being able to use all the same tools that you normally use for wood and it really turns out to be a nice solution.
edit: Ah . . . here you go.
« Last Edit: March 08, 2007, 04:33:37 pm by shmokes »
Best Kid iPad Apps
somunny
« Reply #12 on: March 08, 2007, 06:31:50 pm »
Hey, you used to build stuff!
Seriously though, do you remember how much you paid for the lam?
shmokes
    • Jake Moses
« Reply #13 on: March 09, 2007, 08:55:05 pm »
I remember it was really expensive . . . like $80 or $100 for a 4' x 8' sheet.  Or something . . . I remember thinking, "Jesus, it's a good thing my wife doesn't know how much this costs."
Best Kid iPad Apps
Solocade2008
    • Solocade
« Reply #14 on: March 23, 2007, 11:17:39 pm »
Thanks for the tips!  :cheers:
I ended up going to Lowes and purchasing a small piece of chrome diamond plate for only $2. It was damaged (ie scratches) but looked good enough.
« Last Edit: March 23, 2007, 11:19:39 pm by online_mn »
Loki
    • Deathnote
« Reply #15 on: March 24, 2007, 05:24:31 am »
Great deal! and it looks great! :)
btp2k2
  • Last login:March 16, 2011, 01:02:36 pm
« Reply #16 on: March 24, 2007, 06:02:55 am »
I used chrome spray paint on one of my dreamcasts...it looks awesome and has stood up pretty well too.
I would put lexan over it, but it would look pretty good.
