Author Topic: GGG inductive stick  (Read 2914 times)
freckleface
  • Last login:February 20, 2007, 07:04:55 pm
GGG inductive stick
« on: February 16, 2007, 06:20:47 pm »
Is this stick a hall-effect stick? Is this different than the 49-way in function?  How does the inductive connect?
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: GGG inductive stick
« Reply #1 on: February 16, 2007, 08:42:47 pm »
Yes
Yes... This one is 4 way or 8 way only.
Connects the same way as a regular switched joystick, except that you also have to give it a 5V supply as well.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
freckleface
« Reply #2 on: February 16, 2007, 09:59:56 pm »
Thanks.  I'm guessing it connects more like a P360 vs a microswitch stick. Anyone have one of these?
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #3 on: February 16, 2007, 11:55:27 pm »
Yes, but I haven't hooked them up yet.  ;D  It shouldn't be a problem, though as plenty of people around here use them. People that like them usually love them. Do a search for Suzo Inductive and you will find much more info on them. Kowal has a thread for a mod he did on them. Level42 also has a few threads about them as his ultimate goal would be to mate with one and reproduce.
Quote from: saint
saint is all powerful.
Apparently he is.
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« Reply #4 on: February 17, 2007, 11:51:12 am »
i tried a pair with kowal balltop shafts.
the joysticks ride over little bumps, as they move between the 8 positions. these interfere with the round, sweeping movements that are crucial in robotron, although others have reported that they enhance the play of some games.
you can remove the bumps with sandpaper,  but i still find the joysticks sluggish. i can not perform the movements i want as quickly or as accurately as with my happ P360s.
with or without the bumps, i was unable to achieve decent scores in robotron using the suzo inductive, so i gave up on them.
to see my "Frankenpanel" and design notes, click here.
freckleface
« Reply #5 on: February 17, 2007, 12:53:01 pm »
Thanks Robo.  That's the kind of info I'm lookin for...though I will check out those others, hb, thanks.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: February 19, 2007, 06:22:10 am »
Yes
Technically, no.  "Hall Effect" sensors work differently than "inductive" sensors.  The "inductive joystick" uses the latter.  However, the are very similar in that they use magnets and how they effect the flow of electricity.
FWIW, hall effect is based on that more electrons go to one side or the other of a conductive plate, perpendicular to the flow of electricity, depending of the strength and direction of a magnetic field perpendicular to the plate (IOW, imagine a plate on the screen with the current flowing from top to bottom, electrons turn left or right if there's a magnetic field going into the screen).  Inductive sensors work on that a magnetic material effects an oscillating current (IOW, the sensor creates its own magnetic field with a oscillating current, and measures any interaction with any external magnetic material).
Robin
Knowledge is Power
Fozzy The Bear
« Reply #7 on: February 19, 2007, 08:03:38 am »
Net Result: Exactly the same as far as the end user is concerned.... Which is why I didn't bother typing anything but :Yes! to the question. But thanks for the encyclopedia definition anyway.
Best Regards,
freckleface
« Reply #8 on: February 19, 2007, 06:21:31 pm »
Well, thank you both.  Sounds like they approach from opposite ends, electro-magnetism being what it is.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: February 20, 2007, 06:33:38 pm »
Err, if we're talking "net result ... to the end user":
Hall effect sticks (AFA the ones in the arcade) are analog, while the inductive (& optical perfect360) sticks are digital (8/4-way).  This makes the net result to the end user very different between hall effect & inductive sticks.  OTOH, the net results to user between inductive & optical are the same.  Would you answer 'yes' to "Does inductive = optical?", or "Blu-Ray = HD-DVD", or "microswitch = leafswitch"? ;)
IOW, the short answer is "No".
Come on, wikipedia, man! ;D (Inductive, Hall Effect)
...Sounds like they approach from opposite ends, electro-magnetism being what it is.
Close enough, but highly simplified.
Robin
Knowledge is Power
davieboynj
  • Last login:June 16, 2011, 01:32:09 am
  • Eating your legs solves lifes little problems.
« Reply #10 on: February 23, 2007, 02:57:41 pm »
 :laugh2: :laugh2: :laugh2:
I was able to get great scores in time pilot with these joys, and my shmups got a lot better as well.  But then again, I'm not a Robotron Nut.  :)
« Last Edit: February 23, 2007, 02:59:42 pm by davieboynj »
Level42
« Reply #11 on: January 11, 2008, 01:57:52 am »
Mmmm, mating with them is a bit too much, but reproducing them........mmmmmmm :D
