Author Topic: Screen changing during game (NBA Jam)  (Read 1403 times)
sewerrat
  • Last login:February 12, 2009, 11:53:11 am
« on: February 15, 2007, 11:16:27 pm »
Need some help:
2 player 6 button control panel using default IPAC config
No changes to the Mame config either
Using Mala as the front end
Playing NBA Jam TE in 1 player mode (uses P1 Joystick in 8 way mode and buttons 1,2, and 3)
In a flurry of button presses and joystick movements the screen will change its size to about 2/3 of the normal screen size and put in in the lower left side of the monitor.  Further along the screen will flip upside down (still being 2/3rds the size)
If I exit to Mala, Mala will be that size as well, which leads me to believe its a Mala problem, not MAME.
Exiting Mala to Windows and all is well again, so its not Windows.
Anybody with any ideas??
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Screen changing during game (NBA Jam)
« Reply #1 on: February 16, 2007, 01:01:48 pm »
It could be windows: ATi, nVidia, or Intel driver "change resolution" hotkeys, especially since it only happens with player 1 (assuming you're using the keyboard default ctrl & alt keys).  Check and see if your video driver has any hotkeys enabled.
Robin
Knowledge is Power
sewerrat
« Reply #2 on: February 16, 2007, 06:47:53 pm »
Thanks!!  3 games later and it appears my problem is cured. :applaud:
