Author Topic: Question to people who have hacked a TV Remote.  (Read 3924 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: January 31, 2007, 01:43:03 pm »
Hey everyone I have a hacked TV Remote to power on TV.  My question is this.  I have extended the IR and it works great.  The thing is right now I have taken the top platic part off of the remote.  I also have taken out the rubbery buttons.  I have a + and a - wire running to where the power switch is on the pcb of the universal remote.  Here is the thing though.  I couldn't figure out a way to hold these wires to the pcb.  I used black electric tape.  It is good, but if I barely wiggle the wire to move things in the cab it comes off the pcb.  Is there anyway to keep the wires on that little area of the remote without it moving so bad.  I don't see how I could solder these wire because there is no little hole to solder them to like the IR had.
It works, but it is a hassle to push down on the pcb and make sure the tape stays.  I have tried rubberbands as well.  Those suck.
gonzobrian
  • Last login:April 18, 2011, 08:42:08 pm
  • This space for rent!
Re: Question to people who have hacked a TV Remote.
« Reply #1 on: January 31, 2007, 01:54:42 pm »
Have you tried hot glue?
rdowdy95
  • This is my rifle.
« Reply #2 on: January 31, 2007, 02:12:39 pm »
I have not tried that.  Very interesting...That may just work, and if I screw up I can prolly remove it easy with my fingernail or something.
Anyone else try the hot glut gun trick????
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #3 on: January 31, 2007, 03:00:50 pm »
please take a picture.  if it is what i am thinking it is... you should just solder it down.
rdowdy95
  • This is my rifle.
« Reply #4 on: January 31, 2007, 06:04:54 pm »
I will take a picture of it tonight and get it posted.  I suppose I could solder it, I just don't want to melt the board or anything.
rdowdy95
  • This is my rifle.
« Reply #5 on: January 31, 2007, 06:06:52 pm »
Here is a pic I got from the Best Buy site.  I will get you an actual pic of the remote in my cab tonight though.
Loki
  • Last login:August 14, 2012, 08:00:32 am
    • Deathnote
« Reply #6 on: January 31, 2007, 06:33:23 pm »
Huh? Is that a 3rd party Xbox remote or something? =/
Don't eat yellow snow.
rdowdy95
  • This is my rifle.
« Reply #7 on: February 01, 2007, 11:00:39 am »
RCA actually had this one out around the same time as the Xbox remote.  I think RCA made it for Xbox.  This is just a universal TV RCA Remote.
crashwg
« Reply #8 on: February 01, 2007, 11:21:37 am »
You should definitely solder it.  Just scrape off whatever coating is on the contacts and use a 15-30w iron, a little flux and a little solder and it will be better than anything electric-wise...
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
steveh
    • thecrazysteve.com
« Reply #9 on: February 01, 2007, 01:22:31 pm »
what i wanted to see was the inside not the outside of the remote.  i would need to see what the contacts look like that you are trying to connect to.  Hot Glue does not seam like the answer
rdowdy95
  • This is my rifle.
« Reply #10 on: February 01, 2007, 01:35:55 pm »
Dang camera wasn't charged last night.  I will get that pic on here tonight though of the inside.  Let you guys take a looksie!
rdowdy95
  • This is my rifle.
« Reply #11 on: February 03, 2007, 09:53:01 am »
Sorry it took soo long but here is the best remote pic I could take.  I can anser more questions if you have them about this remote.
blueznl
« Reply #12 on: February 03, 2007, 11:48:58 am »
Image isn't very good but looks like a regular PCB. Time to fire up the soldering iron!
rdowdy95
  • This is my rifle.
« Reply #13 on: February 03, 2007, 12:54:15 pm »
See how it has the little black things.  Right.  On the PCB the little black spots on the PCB well those are where the buttons hit if I had the rubber buttons on.  So I guess like you say just to make sure though.  I tin the red and black wire and solder them both to the little black part part of the PCB where the power button goes right?  My solder skills suck bad, but I did manage to solder the IR Diode and extend the wires to the front of the TV.  So I hope I just don't screw this up.  I do have the desolder roll stuff though.  Is it hard to get the solder to stick to the PCB?  Cause this will be the first time I ever solder something that didn't have holes to solder through.
Also do I have to make the red and black wire be seperate, or can I solder them together then solder to the pcb.  This is going to be tough.
blueznl
« Reply #14 on: February 03, 2007, 02:17:02 pm »
Don't cook it too long, and make sure you've cleaned the spots properly before soldering, and it should be a breeze. Drop a little solder on the spot and pre-tin the wire and it should be easy.
rdowdy95
  • This is my rifle.
« Reply #15 on: February 03, 2007, 05:57:09 pm »
Thanks man.  I will give it a go.  Do you think I can twist the positive and negative wire together first then solder it to the spot or do I need to keep them seperate kind of like I have them now?
blueznl
« Reply #16 on: February 04, 2007, 10:00:45 am »
I don't think twisting is going to make much of a difference if the cabling is not too long. I assume you mean 'side 1 and side 2' of the switch? :-)
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #17 on: February 04, 2007, 10:37:20 am »
This Won't work!!!!
Contrary to the suggestion made..... you can't solder directly to the black carbon pads. The solder simply will not adhere to them properly, if at all.
You need to gently scrape away the black stuff untill you see copper underneath it. You can then solder to that.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
rdowdy95
  • This is my rifle.
« Reply #18 on: February 04, 2007, 04:16:14 pm »
Hey Fozzy what do you recommend that I use to scrap off the black carbon part of the remote?  Exacto blade or a straight razor perhaps?
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #19 on: February 04, 2007, 04:28:31 pm »
Just wondering why you are doing this?  Did it not power on the TV before? :dunno
I b**ch. People listen!!
rdowdy95
  • This is my rifle.
« Reply #20 on: February 04, 2007, 04:40:18 pm »
It does work right now, but if the wires get jiggled a little bit I always have to go back there and press the tape back down.  I guess once I get the cab in the room it will be in, I won't have to worry about a little 2.5 year old messing with my wires.  LOL!  It will be up against a wall.
blueznl
« Reply #21 on: February 04, 2007, 04:44:13 pm »
Oh, I'm sorry, I thought he already scratched off the black stuff! Obviously you'll have to remove anything but the bare copper and / or tinned surface.
Teebor
  • Last login:June 04, 2009, 12:39:06 pm
  • What does this button do??
« Reply #22 on: February 04, 2007, 05:04:32 pm »
Exacto or just straight razor blade, be careful not to dig too deep though, test some buttons that are not important first.
Its always difficult when doing things like this, so try lightly scraping at it first to see how easily it comes away
How was your french toast dear?
Smelly and ungrateful
-American Dad
fjl
  • Pixels Rule!
« Reply #23 on: February 04, 2007, 05:07:29 pm »
You can use a blade to scrape it off or some fine sandpaper. Once the shiny metal is exposed, heat it with the soldering iron and treat with some flux. The flux will assure that when you add the solder, it will stick firmly to the exposed metal. You should also treat the ends of the wire with flux.
steveh
    • thecrazysteve.com
« Reply #24 on: February 05, 2007, 11:06:33 am »
to get the carbon off use some sandpaper,  i actually stole one of the womans emery boards (the nail file things) and used that to scrap off black stuff.  worked like a charm.  Just remember you want to keep the 2 sides separate so when you press the button or whatever it is you are using. it bridges the connection.  I have seen where people have used a dremel to clear away the middle swirls to make sure the accidental connections do not happen.  good luck..
rdowdy95
  • This is my rifle.
« Reply #25 on: February 05, 2007, 11:57:29 pm »
thanks steven that was the main thing, to keep the two sides seperate.  I will prolly just use a little solder cause tere isnt much room in between them, but I usually will put my red wire on the left and the black one on the right.  I will use some fine grit piece of 600 grit to sand it smooth.  I will be doing this later though.  Prolly if my tape loosens up.  Right now it works fine, and it is staying good.  Once I move cab to the room it is going  in, porly won't ever have to mess with, but it is just nice to know I can solder it for good if I need to.
