Author Topic: Cornchip's Revolver Arcade Project....Side art added.  (Read 37054 times)
Cornchip
  • Last login:December 27, 2023, 10:23:11 am
  • Thinking up more crap....
« on: January 27, 2007, 08:39:13 pm »
  Finished my first cabinet...finally. I have made up a lame webpage with a link to my photo gallery.
 http://cornchiparcadeproject.wetpaint.com/
 Hope this link works for others. It's a free site. Post any problems and I'll see what I can do.
Cornchip.
« Last Edit: April 13, 2007, 08:18:49 pm by Cornchip »
IG-88
Re: Cornchip's Arcade Project....Finished.
« Reply #1 on: January 27, 2007, 09:20:22 pm »
Nice Cab....! I'd love to see a video of that sucker rotating the monitor.
Whats the story on the PSU? Sucker looks like you could start an airconditioner with it!
-HarumaN
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
« Reply #2 on: January 27, 2007, 10:34:33 pm »
If you ever need another window motor let me know. I have access to used ones quite often.
Great looking project.
Xam
Can't talk to a psycho like a normal human being.
clockwork
  • Last login:December 11, 2008, 11:15:29 pm
  • Time to play!
« Reply #3 on: January 27, 2007, 10:50:34 pm »
Excellent job, Cornchip. Looks really good.
Charlie Brown: I'm still hoping that yesterday will get better.
kizer
    • Links4jeeps.com
« Reply #4 on: January 28, 2007, 12:56:23 am »
Wow,
Ive been lurking for a while and man I have to honestly say thats a slick looking cabinet. If I had an ounce of skill I would build something that looked like it.
What I really liked is the circuit boards, which add a really clean look. I'm guessing they might be a bit harder to swap out on the buttons if you have a problem, but clean.
blueznl
« Reply #5 on: January 28, 2007, 04:59:54 am »
I *love* it, would you be willing to share construction details on the rotating stuff?
IG-88
« Reply #6 on: January 28, 2007, 07:26:55 am »
Ya, I like to see them also.
-HarumaN
clockwork
  • Time to play!
« Reply #7 on: January 28, 2007, 08:47:04 am »
After browsing through all your screens, I have to agree with everyone. I'd love to see plans too! Or just some explanation text on your images would be great.
Kaytrim
  • I'm too nice a guy
« Reply #8 on: January 28, 2007, 11:55:46 am »
 :notworthy: Can't wait to see the full write up on the build.  Especially on the rotating system.
Cornchip
« Reply #9 on: January 28, 2007, 02:22:30 pm »
I'll try to describe my reasoning for making my rotating mechanism. I decided to keep the large disc to support the monitor (as seen in other designs) at the front and use rollers to support the weight. The disc is made from 1/4" aluminum and is 25 1/2" in diameter (Black anodized). 4 standoffs go between the aluminum disc to the 4 clearance holes in the monitor chassis. From the back side of the mounting holes are longer standoffs to connect to the rear mounting plate. This rear mounting plate has a driveshaft that is 'on center' with the 4 holes in the chassis. Basically the setup drives from the rear and also supports the weight.
 The next thing I needed to select was a motor. A 12V DC gear motor is reversable by simply reversing the polarity by means of a switch or relay. I went with a keyed switch that is 'center off' and either side of that is FORWARD/REVERSE. When driving to each position..a limit switch was employed to kill the power to motor stopping the monitor where needed. This setup needed to be adjustable as there is a certain amount of deceleration after cutting power to the motor (adjustable end stops).
 With the motor decided upon...next came the rotation RPM that I wanted. I guessed that 5 seconds allowed enough time to transit 90 degrees. My calculations are below worked backwards from the motor RPM at 12 VDC (my power supply is separate from my PC).
 165 RPM at 12 VDC (motor)
 Desired RPM of monitor 3 RPM (very slow).
 First drive sprocket 10 teeth
 Second driven sprocket 80 teeth
 Total gear reduction is 8
 165/8=20.626 RPM
 I needed to do this a second time using the same ratio with identical sprockets.
20.626/8=2.6 RPM final
 Why did I want 3 RPM final? Here's why.
 60 second/3 RPM=20 seconds for 1 revolution.
 20 seconds (1 revolution)/4 (90 degrees)=5 seconds.
 My power supply is 13.8 VDC vs 12VDC so the motor runs a little faster. So I'm sure the final is closer to 3 RPM vs. 2.6. Perfect.
 So I used a CAD/CAM program and made my own sprockets for a 25H roller chain. This is the same as used in pockets bikes...making it cheap.
 I made a numbered diagram of the parts.
 1 - Motor drive sprocket
 2 - Primary driven/secondary drive idler shaft. Also used a chain tensioner.
 3 - Secondary driven shaft.
 4 - Limit switches for horizontal/vertical orientation.
 5 - Monitor power interupt switch. Cam activated.
 6 - CAM
 7 - Rear support (3/8 x 3 aluminum). Has a bearing for #3.
 8 - Denso 730556-7030 12VDC gear motor.
 9 - Front plate
 10 - Idler wheel for front plate (x4)
 11 - Lower idler wheel mount (top is the same...just upside down)
 12 - Rear mounting plate.
 13 - Drive chain.
 14 - Primary chain eccentric tensioner.
 Hope that helps a little.
 1
Cornchip
« Reply #10 on: January 28, 2007, 03:05:58 pm »
IG-88
« Reply #11 on: January 28, 2007, 03:56:57 pm »
Dude, that is flat out impressive. You should be in the runnin' for a Mamey for that.   :notworthy:
-HarumaN
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #12 on: January 28, 2007, 05:03:22 pm »
Slick work!
Ohioboxster
  • Last login:February 08, 2007, 12:59:02 am
« Reply #13 on: January 28, 2007, 06:09:11 pm »
Every time I think Im pretty smart I see something like this.........pure genius
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
« Reply #14 on: January 28, 2007, 07:42:18 pm »
2 words.
Ola Salima.  :notworthy:  :notworthy:
This plan is so perfect, it's retarded. -- Peter Family Guy
Havok
  • Trade Count: (+17)
« Reply #15 on: January 28, 2007, 09:58:25 pm »
One word:
Awesome!
 :notworthy:
Gamester
« Reply #16 on: January 29, 2007, 09:59:38 am »
That is an outstanding achievement for your first cabinet.  Very impressive engineering!
needlesmcgirk
  • Last login:September 15, 2009, 10:54:31 pm
« Reply #17 on: January 29, 2007, 11:31:14 am »
Unbelievable.  What an amazing looking cabinet!  Congratulations on that!  Man, I was actually going into the section on the boards to start a post on my cab, but now I don't feel like it...
clockwork
  • Time to play!
« Reply #18 on: January 29, 2007, 12:21:16 pm »
What did you do to get the shine on your cab? It looks metallic.
Cornchip
« Reply #19 on: January 29, 2007, 11:01:37 pm »
  The cabinet is painted with Black Latex. It was a premium paint made by CIL here in Canada available through the Home Depot. Whats neat about it is it has a 'blue pearl' to the finish. It went on easy and didn't stink the house up in the process. It would be interesting to see what it would spray like.
clockwork
  • Time to play!
« Reply #20 on: January 30, 2007, 08:48:29 am »
Wow, that's nice. I can't believe you didn't have to do any extra coating.
Knievel
    • Knievel Kustoms
« Reply #21 on: January 30, 2007, 11:29:03 am »
Wow, very nice job all around. The monitor rotating mech is amazing enough but all those custom circuit boards and the custom bat-top handles and spinner top. I'm sure everyone would enjoy some more details on how you did those...I know I would. You are a very humble builder.
And those button surrounds look great.  ;)
(+_+)
  • Let me splain.
« Reply #22 on: January 30, 2007, 01:52:45 pm »
Hey Cornchip,
I was looking into something similar but not quite as industrial seeing my screen is the same size but an LCD which weighs far less. The other thing I was considering was making it a part of my launcher program. I have a setting that allows you to ask whether it is a vertical or horizontal game. Based on your choice send a message programatically to a serial or parallel port and have an encoder trigger the stepper motor. I hope I haven't bitten off more than I can chew here, but seeing you've raised the bar, I'll try to up the ante in the name of arcade building fun. Have you looked into this at all. If so, any help would be appreciated. Thanks.
Once again great job.  :applaud:
fjl
  • Pixels Rule!
« Reply #23 on: January 30, 2007, 02:50:38 pm »
Dude awesome! But thanks for making our work look like crap.  :laugh2:
Now we can expect our cabinets to be graded on a curve.  :hissy:
You deserve a Mamey :cheers:
  • Last login:Yesterday at 04:07:39 pm
« Reply #24 on: January 30, 2007, 07:32:19 pm »
Cornchip
« Reply #25 on: January 30, 2007, 09:51:06 pm »
LCD monitors would be a win with this type of setup. Less weight,space and no degauss issues. If this monitor dies I'd consider a retrofit. The only bad thing I could think is 'gun' games would not be possible (no sync?). But I don't have one..so it wouldn't matter. I think the near future will bring lots of options for LCD.
 Here's a shocker you don't want to hear. I'm currently using Mame32FX as it has made life easy for 'globally' selecting display properties. I'm not sure if the standard command line version of Mame will do that without editing or separating Roms. I'm just guessing here. That dream of interfacing Mame with a serial/parallel port relay is possibly just that. You might have to sleep with a Mame developer to get it. I do believe it is possible....just not by me. With a DC motor you'd be half way there.
  Those Bat-top handles I didn't intend on building originally. It happened quite by accident at work on the lathe. To make a long story short...the halogen light on the machine illuminated the plastic. At this point I had already bought my translucent push buttons fro GGG along with extra blue button blasters (BBB's). The Led's and the plastic were a great match. Light seems to illuminate the entire piece of plastic...even behind the LED. Neat stuff.
 The spinner I did next. This took a little more work as it is made from 3 pieces. A new shaft....fits the TurboTwist 1 in the same manner as the original. The shaft is pressed into the spinner body (careful with the pressfit in plastic...it can crack if there's too much interference).  No set screw is needed with a careful press. The last part is a thin pressed Stainless ring on the outside diameter. I did this for the bling factor as well as dividing the skirt from the top. Really sparkles.
 Under the spinner is a 'hoop' circuit board that has 4 Led's. The shaft passes up through the center. All the resistors are soldered in place and 5VDC is supplied to all. These boards are drafted in Eagle Layout Editor. Oh...Kenevel...those button surrounds are drawn in Eagle and printed on the 'backside' of the vinyl (whiteside) and cut out. Print,cut and stick.I grabbed that idea form you. Thanks!
 The Bat-tops came next. A post by 'Imageek' gave me the info to build my own Slikstick copies. Thanks dude for the spy photos. I just copied the original dimensions using stainless for the handle and the same Nylon for the tops. The hardest part was getting a 3.5mm jack that had a thread I could tap in the end. The part I found had a 8mmx1 thread. Not a standard size...but I had one in my tool box. Drawbacks was the depth needed inside the shaft for the 3.5mm female jack. Note in the length below the the last circlip groove. My shaft is longer here by 3/4 of an inch. Add the right angle 3.5 plug and I'm close to having no clearance inside the panel. I got lucky.
 That original post..
 http://forum.arcadecontrols.com/index.php?topic=52509.0
 Hopefully this post makes sense...it's long winded. Sorry. I'll see if I can dig up some different pictures also.
« Last Edit: July 26, 2008, 10:41:23 am by Cornchip »
clockwork
  • Time to play!
« Reply #26 on: January 30, 2007, 10:07:54 pm »
Dude, if you wrote a book on how you built your cab from start to finish, I'd buy it.  ;D
Cornchip
« Reply #27 on: January 30, 2007, 10:20:45 pm »
  Great...I could use the money!   ;D
(+_+)
  • Let me splain.
« Reply #28 on: January 31, 2007, 10:12:18 am »
Quote from: Cornchip
I was thinking of embedding the code to do so within my app and not Mame. I think the code behind it won't be too difficult, it's the unknown (electronics) that I'm uneasy about. The reason I prefer doing so within my app is also due to the familiarity and control I have there. There are some app shots in the thread below somewhere.
http://forum.arcadecontrols.com/index.php?topic=62244.0
allanon
  • Last login:January 31, 2007, 05:31:58 pm
« Reply #29 on: January 31, 2007, 04:20:50 pm »
Wow Cornchip, that's extremely cool man.  I love the color scheme.
Cornchip
« Reply #30 on: January 31, 2007, 10:37:13 pm »
I was surfing Ebay tonight a did a search for serial relay cards. They'll run you 50 to 100 bucks depending on how many relays you want. I think I would want a minimum of 4. I'd like to keep my key switch...if I choose not to use it I could lock out a relay that supplies power to the switch (manual or auto mode).
 I think this is a possibility as long as you can write code to control the serial port. By using your app...you'd have a better chance. It's a shame a Mame dev couldn't throw in something that we could monitor with a program. I posted a picture of a serial relay board as seen on Ebay. This model has a PIC microcontroller...so it needs programming knowledge specific to PIC. Probably wouldn't be a good buy. I don't know.
Cornchip.
(+_+)
  • Let me splain.
« Reply #31 on: February 01, 2007, 11:30:06 am »
I stumbled across this myself the other day. I'd be able to plug this in to my app using the dll provided. Problem is I don't whether I want to spend the $200 for the card, stepper motor and gears and pulleys. I'm having an internal debate as to whether or not I should just drop the $200 beans into a Billabs 27" monitor. On the one hand an auto rotating monitor would be way cool. On the other a behemoth 27 inch screen would be great also and much simpler to implement. I hate it when I do that to myself.
http://steppercontrol.com/s100.html
http://steppercontrol.com/asoft.html
« Last Edit: February 01, 2007, 06:47:13 pm by (+_+) »
Cornchip
« Reply #32 on: February 01, 2007, 06:11:43 pm »
Stepper motors are a big move beyond simple motor control. Totally overkill for an arcade project. Granted...it would work great and totally eliminate most moving parts. That last picture of the Serial Relay board was not for stepper motor control.
 I can see where your right about the effort not possibly being worth it vs. a large arcade display. My project was really only possible due to the resources that I have available in the shop. I doubt I would pay the costs out of my own pocket for what I did. I would have definitely have bought a large display.
« Last Edit: February 01, 2007, 06:50:09 pm by Cornchip »
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
« Reply #33 on: February 01, 2007, 06:44:48 pm »
That is simply AWESOME  :notworthy: :notworthy:
Congrats on a cab that should be up for a Mamey IMHO.
There are three kinds of people in the world those that can count and those that can't.
Cornchip
« Reply #34 on: February 04, 2007, 12:20:14 pm »
The HP p1130 monitor used in this project has two VGA inputs.  I never bothered to add a second VGA before I buttoned up the cabinet. I rushed the drying process after painting and reassembled the rear panel before it was properly dry. This weekend I was able with the help of a broom handle to free the rear panel from its bonds and get to work on the second VGA input.
 After adding wires from the add on board and rerouting the bundle to a position inside the cabinet (safe spot out of the way) ...I then made a remote panel using spare arcade buttons. The switch was desoldered from the add on board and secured as well. It was a painfull job that had to be done. Yuk.
 After the job was finished I was able to try out my Dreamcast. I have to say VGA and a Dreamcast are great together. I even tried out 'Radiligy' in a vertical orientation (must be one of the few that supports vertical). I think I'll look into building a second panel to support the DC and maybe some other console. We'll see.
 Also...I made a second video from the rear of the machine with the panel off. Additional pictures also at the gallery.
 http://video.yahoo.com/video/play?vid=c21d69e0382f71459e1fae72760a3adf.1811007&vback=Studio&vdone=http%3A%2F%2Fvideo.yahoo.com%2Fvideo%2Fstudio%3Fei%3DUTF-8
 Cornchip.
« Last Edit: February 04, 2007, 02:00:42 pm by Cornchip »
Knievel
    • Knievel Kustoms
« Reply #35 on: February 04, 2007, 01:07:49 pm »
Thanks for the extra info on the joys/spinner, way beyond my skill level I'm afraid. If you go into production on those let me know.  :)
Love the second vid, you are definitely hitting new levels with this cabinet.
That said, I really think this machine needs/deserves some custom artwork to put it over the edge. I suggest you enlist Pixelhugger to make you a marquee/sideart, if you don't have those skills as well.
And I'm going to throw this cabinet name out there... THE REVOLVER
Cornchip
« Reply #36 on: February 04, 2007, 01:54:43 pm »
   Damn....that's actually a great name. I had  thought of 'Rotacade'. It was rather generic for a name. Perhaps generic like the stock Mame graphics I currently have.  ;D
 I could think on it....I have some ideas. A favorite shooter I play is Capcom's Gunsmoke. Pehaps a hack on the original Marquee might work. I don't know if it would have the 'pop' that the Mame Atomic has. It would also be nice to work the 'rotation' arrows from the front keyswitch it it some how. Beyond my skill level. I'll have a look at Pixel Hugger's work.
 I'd love to make a small run of something to sell.  Someday I'll move from this small house to a place with a decent garage. There I hope to have room for a small mill and lathe. Until then...anything that I do has to be made at work. That unfortunately puts a kibosh on production. But maybe just once I should try it.
Cornchip.
« Last Edit: February 04, 2007, 01:58:42 pm by Cornchip »
Knievel
    • Knievel Kustoms
« Reply #37 on: February 04, 2007, 05:27:29 pm »
I came up with that name for a dedicated gun cabinet, suits yours though.
That Gunsmoke art doesn't really fit with the high-tech cabinet. Pixel is the master of flashy blue/chrome type graphics. I'm sure he'd come up with something cool.
I'm envisioning circular sideart with REVOLVER angled across it and your blue rotation arrows around the outside. :)
blueznl
« Reply #38 on: February 05, 2007, 07:00:59 am »
Perhaps check some of the Anime series for inspiration, such as _Gunslinger Girls_ or _Gungrave_. Or you could go down the _Serenity_ route... good excuse to see more of Firefly :)
Pixelhugger
  • Last login:October 14, 2025, 10:53:10 am
« Reply #39 on: February 05, 2007, 04:42:53 pm »
Stunning. Absolutely stunning. The water-jet cutting is just unbelievable. And the engineering leaves me in awe... talk about project envy.  :applaud:
Project mega thread HERE
