Author Topic: single button selection?  (Read 3698 times)
dibb1er
  • Last login:March 25, 2010, 07:14:38 am
« on: January 13, 2007, 04:37:54 am »
Is it possible to use a single button approach to selecting a song?
I am thinking of layouts for my 2nd attempt at a jukebox, and want to use the aj8 or classic style of skins
BUT I want to enable a single button to select each song (instead of the 2 buttons now, ie A-1, or B-2 etc )
is this possible?
Karaokedude
  • Last login:October 16, 2007, 12:21:00 pm
Re: single button selection?
« Reply #1 on: January 13, 2007, 09:22:55 am »
In the skin file there is an option to use single letter
not sure if it works or not but asuming it does
if you wanted 16 letters A-P
[Selection]
# SelectionMethod: Alphanumeric,Numeric,SingleLetter,SingleNumber
SelectionMethod=SingleLetter
UseZero=False
HighLetter=P
HighNumber=4
DiscAddress=Relative
you would prob have to remap some keys in the control file as well in case some of the letters have other functions
you would also need to change the background image numbering to suit your layout
Karaokedude
« Reply #2 on: January 13, 2007, 09:27:13 am »
just given it a quick try and it doesnt seem to work
says the selection method is invalid so maybe Chris is working on it for a future release
nice idea but it would be a little limited to which size grid you could use
Chris
  • Moderator
    • Chris's MAME Cabinet
« Reply #3 on: January 13, 2007, 12:14:37 pm »
If your HighLetter is higher than the number of selections on the screen, it should automatically go to Single Letter mode.  The comment line Karaeokedude pointed out is out of date; I need to clean up those skin files!  Set the SelectionMethod to Alpha.
--Chris
--Chris
