Author Topic: * * * * * WHEN MAKING A POST IN THIS FORUM: READ THIS FIRST!!!!! * * * * *  (Read 50209 times)
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
1) First, state the Make and Model of your monitor in your post.  First.  First.  FIRST!  In fact, make it part of your subject.
Most monitors have a specific cure for specific symptoms, so if you're going to post, don't be general about it...be specific.
If you can't figure out what kind of monitor you have, take a picture of the CHASSIS and attach it to your post.
2) Be descriptive.  Don't just say "hi my monitor doesn't work I don't know why can you help me" because that doesn't tell us jack diddly squat.  Describe the problems in detail, include anything you may have done to make the problem (or correct it)
3) Usually, the model of your monitor is NOT on the tube!  If you see a sticker with a number like "A63xxxxxxx" that's not the monitor type, it's the tube type.  Keep looking.
4) If you live in Europe, please let us know.  The electrical system there is different from the one in the US, and we deal mostly with people in the US.
« Last Edit: November 24, 2008, 06:57:25 am by Peale »
Ken Layton
  • Guru
  • Technician
Actually people need to visit the two monitor ID sites first. Then if they can't figure out a make & model then they should post a picture. I wish people would also remember that ALL monitors look the same from the front. It's the back where the circuit boards are that counts.
www.homearcade.org/BBBB/monitor.html
www.jomac.net.au/mon.htm
In general numbers on the picture tube are not the monitor brand nor are they the monitor model.
« Last Edit: January 14, 2007, 12:28:30 am by Ken Layton »
Kevin Mullins
    • Me on Myspace
A couple more sites I have found useful when trying to ID a monitor chassis to add to the ones Ken already posted.
http://www.medi-gmbh.com/chassis/chassis.htm
http://www.zax.com.au/spare_parts/monitor-chassis.html
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
Another thing worth mentioning in your posts:
If you're having a technical problem and you get it fixed, whether on your own or with someone's help, post what you did to fix it!!
Other people can benefit from your solution.  It's a lot easier to search the forums for an answer to your problem than to see 12 different posts asking help for the same problem because no one comes back to say what worked.
Ahhh...  Now that I've got that out of my system....
(Edit)  Sorry, didn't see the (or correct it.)  My bad.
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
Level42
Re: * * * * * WHEN MAKING A POST IN THIS FORUM: READ THIS FIRST!!!!! * * * * *
« Reply #4 on: November 25, 2007, 12:56:14 pm »
One of the most common monitors is the Electrohome G07.
There's a nice repair guide here:
http://www.pinrepair.com/g07/
SirPeale
« Reply #5 on: November 24, 2008, 06:58:19 am »
Added a stipulation regarding voltage and Europe.
  • Last login:Yesterday at 03:14:03 am
« Reply #6 on: November 26, 2013, 09:15:01 am »
What you say?!
Ken Layton
  • Guru
  • Technician
« Reply #7 on: November 26, 2013, 12:05:19 pm »
Confirmed. The user "silliboy" is a spambot that has posted that same exact message to dozens of forums and blogs over the past few days.  The username changed between forums, but it was always the same message posted.
NIVO
  • Last login:August 08, 2022, 12:32:13 pm
« Reply #8 on: November 26, 2013, 12:15:09 pm »
taken care of  :cheers:
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:June 05, 2024, 07:28:30 pm
« Reply #9 on: November 26, 2013, 12:26:30 pm »
You da man Nivo!
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
  • Last login:May 09, 2023, 01:16:55 pm
Ken Layton
  • Guru
  • Technician
Ken Layton
  • Guru
  • Technician
Updating this thread.
JOMAC'S monitor ID page has changed. In fact JOMAC'S whole website has been revamped and many links have changed. Here is the new monitor picture identification page:
http://www.jomac.net.au/services/monitors/
Ken Layton
  • Guru
  • Technician
Hydrolisk1792
  • Last login:September 11, 2023, 08:02:38 pm
  • Custom Cabinets and Games FTW!
Hardware Guy: It is a software problem!
Software Guy: It is a hardware problem!
Me: Hold My Beer!
