Author Topic: New leaf-switch project - I need your help  (Read 3565 times)
benarcade
  • Last login:October 13, 2023, 04:59:32 pm
« on: January 03, 2007, 07:34:16 pm »
I want to put together a leaf-switch console and have quite a few questions. It appears that the switches, at least, are sold in separate parts - is that right? Looking at Bob Roberts' site, it looks like there are several parts to a button:
  • Button $1
  • Pal Nuts $1
  • Leaf Switch & Holder $3
  • Spacers $1
So I need to buy 4 different items to get a single leaf-switch button? Also, which is better, the nylon or fiberboard? If I want to install the buttons in a 3/4" wood board, do I need the "short" or "long" buttons? - I'm assuming the "long" ones.
Do I need a leaf switch with a resistor? What does the resistor do?
Here's my shopping list at http://therealbobroberts.net/parts.html. Am I missing anything?
  • 2 Red Ball 4/8 Way Leaf Joystick = $20.00 [One for 8-way, and one for 4-way]
  • 1 White player 1 & 2 pushbutton set = $3.50 [These don't need to be leaf]
  • 9 Leaf sw & holder only for wood CPs Gold Flashed Contacts $27.00 [Switches with holder]
  • 2 Leaf sw pal nuts (Needed for above holders!) = $2 [10 total nuts]
  • 9 Leaf button only long (4 gold, 2 red, 1 green, 2 blue) = $9 [Green for coin]
Total = $61.50
Then I need an I-PAC2 from ultimarc, some wires and connectors, wood. Total should be somewhere around $100.
IPAC2 question: I see that it has PS/2 keyboard in/outs. They don't specifically say how to plug it into the USB - so I assume it comes with a standard ps/2 to usb converter? I'm gunshy now that I've experienced the incompatibility of x-Arcade with standard USB converters.
And here's a quick mockup of the layout:
« Last Edit: January 03, 2007, 07:38:37 pm by benarcade »
Encryptor
  • Trade Count: (+34)
  • Last login:December 21, 2025, 07:22:51 pm
Re: New leaf-switch project - I need your help
« Reply #1 on: January 03, 2007, 08:54:08 pm »
There is another alternative that will still allow you to use leaf switches. It is a new style that ponyboy is selling in the Buy/Sell/Trade forum here.
http://forum.arcadecontrols.com/index.php?topic=36770.0
Go to this thread, scroll down and look at the 4th picture down. It's a green Happs button with a new leaf style bracket.
Just something to consider.
Encryptor
Encryptor
« Reply #2 on: January 03, 2007, 08:55:41 pm »
Oh and I forgot to put this in. The bracket leaf switches are 2.15 each and what ever the button minus the micro switch cost. Around 1.50 or so. It's a bit cheaper than the way you were looking at doing it.
Encryptor
whammoed
  • Last login:Yesterday at 02:27:40 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #3 on: January 03, 2007, 09:18:30 pm »
If putting in 3/4" material, you won't need the spacers, just the holders with long buttons.
You can use the short buttons without the holder though, just screw the leaf switches directly to the 3/4" material.
Level42
« Reply #4 on: January 04, 2007, 01:24:46 am »
Do NOT buy that joystick ! It's rubbish:
http://forum.arcadecontrols.com/index.php?topic=41573.0
Also don't buy the leaf switches that Bob Roberts indicates as IMPORT, those are the same "quality" leafs as used on that joystick.
I can't understand why Bob is selling these....a man with such experience in the business should know better.
Indeed, getting the leafs that Ponyboy sells is a much better option. There is no real good alternative for a good quality new joystcik. You'd have to be very lucky to find an original Wico leaf joystick on e-bay or something.
If you hate microswitches like me, I suggest the Suzo Inductive sticks.
http://forum.arcadecontrols.com/index.php?topic=42066.0
and
http://forum.arcadecontrols.com/index.php?topic=53719.0 if you don't like the looks.
 $17,95 each at www.tntamusements.com.
Ultimarc also has a great new stick that doesn't use either microswitches or leafs:
http://www.ultimarc.com/ultrastik_info.html
« Last Edit: January 04, 2007, 01:40:33 am by Level42 »
benarcade
« Reply #5 on: January 04, 2007, 12:29:41 pm »
Okay - so I need to reconsider my list it seems. How do I buy buttons from Ponyboy? Doesn't anyone make a good leaf joystick anymore? Do I have to find one used?
Thanks for the responses. This is just the sort of stuff that isn't obvious.
Level42
« Reply #6 on: January 04, 2007, 01:15:12 pm »
You can contact Ponyboy through sales@rollieelectronics.com, be sure to check out his "sales thread":
He has great translucent buttons (or regular ones) and the mentioned leafs that can be used with these buttons.
And, no. No-one makes a good leaf joystick anymore. Sad but true. Indeed your only hope would be used or NOS.
Well, I was in exactly the same position as you, so I bought these lousy sticks....I hope to help others not to make the same mistake.
