Author Topic: IDE Cable Header for Mini-Pac  (Read 921 times)
tommyinajar
  • Last login:November 15, 2023, 12:23:20 pm
  • My other cab is a Cube Quest
« on: December 29, 2006, 03:42:19 pm »
Anybody know where I can get the IDE header and connectors like the one they use for the Ultimarc Mini-pac wiring harness ?
 Also, has anyone had any problem using an IDE cable hacked ? What do you do, just add on normal wires to the tiny, separated ribbon wires ?
miles2912
Re: IDE Cable Header for Mini-Pac
« Reply #1 on: December 29, 2006, 05:43:58 pm »
Just make your own.. kind of a pain but it will work.  Try to find an older ide cable with fat wires.  The bigger the better.  You basically just need to extend the wires or buy a long cable to start with.  The one that comes from ultimarc is really the one you want...
D-
