Author Topic: Can a Slot Cutting Bit be used in a Drill?  (Read 4114 times)
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« on: December 19, 2006, 09:44:01 am »
Hey guys, question.
I want to add T-Molding (or the equivalent) to the edges of my cab, and I'm on a budget so buying a router is out.
Could I just use a Slot Cutting bit in a Power Drill or a Drill Press?
Kaytrim
  • I'm too nice a guy
Re: Can a Slot Cutting Bit be used in a Drill?
« Reply #1 on: December 19, 2006, 09:51:14 am »
The base of the router keeps the cutter stable and straight.  You would have no control over the bit and more than likely ruin the edge of the wood you are working on.  At worst you could seriously injure yourself.
postalp123
« Reply #2 on: December 19, 2006, 10:05:40 am »
Just as I assumed, I guess I'll rent a Router.
Kaytrim
« Reply #3 on: December 19, 2006, 11:00:22 am »
If you are going to rent one try and calculate the amount of time you will need it and compare it to the amount for buying one.  I have done this in the past and found out that it would be cheaper to just buy the tool then I would have it for later projects.
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
« Reply #4 on: December 25, 2006, 10:44:00 am »
I imagine the RPM's per tool would matter also. A router is usually around 20k or so RPM's versus a drill that is usually around 2-3k. Probably affects the cutting ability.
Xam
Can't talk to a psycho like a normal human being.
prOk
  • Last login:December 28, 2015, 08:29:34 pm
  • www.rgvac.com
    • Brian's Classic Arcade
« Reply #5 on: December 25, 2006, 08:45:15 pm »
Also keep in mind, a slot bit in a drill will be very very dangerous.  Get the right tool and be safe.
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #6 on: December 26, 2006, 09:00:45 am »
I dont know if this is a good unit or not ( i just asked in another thread.)  But theres a router on sale at Lowes this week for 90$
Checkout this thread for more info http://forum.arcadecontrols.com/index.php?topic=61462.0
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #7 on: December 26, 2006, 01:14:01 pm »
Did my whole cabinet using the $59 bucks Ryobi at Home Depot.  Work out great.  And after you use the sucker, you will go on think why didn't I buy one earlier as there's so much other things I can do with it.  Picked up the slot cutter bit at Lowes cause home depot didn't have them available.
And BTW, cutting plexi glass with the flush trim bit is a piece of cake, don't even need to sandwich or anything.
