Author Topic: Is there a shorter stick that will fit J-Stick  (Read 2511 times)
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« on: December 16, 2006, 11:30:11 am »
I'm using the J-Stick for all my dedicated 4-way games. I top mounted this puppy and the problem is it has too long of a throw for most games(At least for me). Is there anyway to shorten or replace it with a shorter stick?
Any thoughts or suggestions would be great!
My old user name was marlborroman13, but I kicked the habit many years ago!
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Is there a shorter stick that will fit J-Stick
« Reply #1 on: December 16, 2006, 08:44:42 pm »
I think a J-stick is really made by Sanwa- you might have a look at replacement Sanwa handles.
destructor
« Reply #2 on: December 17, 2006, 03:58:15 am »
1. You can change handle to original Sanwa. Andy has longer handles for wooden panels.
2. Mag-Stik has short throw.
3. Buy UltraStik and made own restrictor.
AMDman13
« Reply #3 on: December 17, 2006, 02:37:17 pm »
Anyone know how short the regular length ball top handle from ultimarc is? I believe the J-Stick is 70mm (at top of the balltop)
AMDman13
« Reply #4 on: December 17, 2006, 05:33:17 pm »
Well Andy just let me know that the T-Stick will not fit the J-Stick base. Also the lengths are the same anyway.. Looks like I'll just live with it.
Kremmit
  • - AHOTW -
« Reply #5 on: December 17, 2006, 09:15:40 pm »
Nope, the T-sticks are a totally different product, from a different manufacturer.  You're looking for a Sanwa handle, which Andy does not sell.
AMDman13
« Reply #6 on: December 18, 2006, 09:54:37 pm »
Thanks I emailed Himura to see if they have a Swana stick that will fit JLW J-Stick from Ultimarc.
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #7 on: December 19, 2006, 06:04:45 am »
Himura? be careful
http://www.akihabarashop.com/products.html
but this has be closed for 2 months :P
Japan version JLW has lower handle than J - stick
fatfingers
  • Got UltraStiks?™
« Reply #8 on: December 19, 2006, 06:20:13 am »
Any chance ponyboy can get you what you want?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
AMDman13
« Reply #9 on: December 19, 2006, 11:44:38 pm »
Thanks guys. I thought that JLW and J-Stick from Andy were one and the same joystick?
Himura yes, I know I ordered my black ball top from Himura and it took a little over a month to receive, but I got it.
I didn't think that Ponyboy carried Sanwa parts otherwise I would love to order from him.
fatfingers
  • Got UltraStiks?™
« Reply #10 on: December 20, 2006, 08:42:05 am »
He definitely carries some Sanwa parts.  I currently have an order in with him for Sanwa balltops.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
destructor
« Reply #11 on: December 20, 2006, 09:01:09 am »
J-Stik has base from JLW. Mountplate and handle is different.
AMDman13
« Reply #12 on: December 21, 2006, 10:51:26 pm »
Can anyone confirm that this is the model I need.. Japanese Sanwa JLW-TM-8 – Ą2300?
Thanks for all your help guys
kowal
  • Suzo 4ever
« Reply #13 on: December 22, 2006, 06:06:51 am »
JLW-TM-8 – Ą2300
yest this model
Seimitsu LS32 is good also
destructor
« Reply #14 on: December 22, 2006, 08:20:08 am »
Remember that mountplate in JLW-TM-8 can be different than in J-Stik. In Sanwa catalogue JLW-UM-8 has mountplate identical as J-Stik. JLW-TM-8 mountplate is a bit different.
Maybe for J-Stik ball-top Andy use whole base (base + mountplate) from JLW-UM-8 and mount own handle.
« Last Edit: December 22, 2006, 08:24:06 am by destructor »
AMDman13
« Reply #15 on: December 22, 2006, 10:24:56 am »
I'm looking to replace just the stick as my mounting plate is recessed into my CPT and the artwork is already adhered over it. So, in order to replace the mount plate I would have to scrap my CP art. Is the JLW-UM-8 handle any shorter?
destructor
« Reply #16 on: December 22, 2006, 11:42:21 am »
If you want to change handle only then buy JLW-TM-8 and replace hadnle with your J-Stik. JLW-TM-8 handle is shorter than J-Stik.
I wirte about mountplate for info only.
AMDman13
« Reply #17 on: December 22, 2006, 06:53:23 pm »
Sweet! Thanks a bunch... Does anyone know how much shorter this stick is?
Thanks again!
destructor
« Reply #18 on: December 23, 2006, 02:43:08 am »
:D kowal's site again.
http://www.kowal.itcom.pl/ArcadeParts_pliki/JLW.htm
On begining is:
Na Ultimarc joystick ten jest dostępny pod nazwą J-stick różni się jednak długością trzonka który ma 72mm podczas gdy wersja katalogowa Sanwy dostępna w Japonii ma 62mm
J-Stik = 72mm
JLW = 62mm
10mm shorter.
AMDman13
« Reply #19 on: December 23, 2006, 10:51:23 am »
Great! Thanks for all your help! Does the ball top the LB-35 balltop fit the JLW?
destructor
« Reply #20 on: December 23, 2006, 04:27:09 pm »
Hehe, yes ;) These are 6mm (screw-thread diameter) balltops. Saimitsu and Sanwa balltops are 6mm, some (battop for example) is 8mm but are sells with 8-to-6mm adaptors, then fit to all balltop joysticks.
LB-35 and all other 35mm balls (Bubble Seimitsu for example) are standard 6mm balls.
