Author Topic: Horizontal width coil adjustment?  (Read 7035 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: December 03, 2006, 11:55:29 pm »
1st question: I was wondering if someone knew where to get a horizontal width coil adjustment tool?
2nd question:  I have WG K7000 that I need to adjust the width on.  I was wondering if anyone had any advice when it comes to adjusting the width coil?  Do I have to worry about applying too much pressure and breaking the ferrite core on the coil.  Is there anything to look out for?
FrizzleFried
    • Idaho Garagecade
Re: Horizontal width coil adjustment?
« Reply #1 on: December 04, 2006, 12:09:46 am »
The easiest place to find a tool is over at Radio Shack.  They come in a set of 3 or 5 (i believe).  The 3-tool set contains the tool you are looking for...
Popcorrin
« Reply #2 on: December 04, 2006, 12:18:48 pm »
Anybody have any advice when it comes to adjusting it?
grantspain
« Reply #3 on: December 04, 2006, 12:40:41 pm »
when you get your PLASTIC trimming tool insert it in the width coil and turn which ever way you require to get your picture the correct size using a mirror to see what you are doing
you will not break the ferrite core with the correct tool
Popcorrin
« Reply #4 on: December 04, 2006, 12:47:45 pm »
Okay, thanks for the info.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: December 06, 2006, 12:06:24 am »
Visit here for more info:
www.homearcade.org/BBBB/wc.html
Popcorrin
« Reply #6 on: December 08, 2006, 05:11:16 am »
Thanks for the link Ken.  I wish I would have read it sooner because
I tried adjusting the darn thing and it wouldn't budge.  I ended up busting the end off of the tool.    I'll have another go at it using the info off of that site.
Ken Layton
  • Guru
  • Technician
« Reply #7 on: December 08, 2006, 10:24:53 am »
Remember that sometimes the monitor manufacturer will glue the width coil adjustment in place at the time of manufacture. Sometimes you can soften the glue with the heat from a hair dryer enough to allow you to turn the coil slug. If not then you need to order a replacement width coil. The replacements are not glued and have no need to be glued.
