Author Topic: Sources for brushed metal?  (Read 3226 times)
1UP
  • Token Junkie
    • 1UPArcade
« on: March 24, 2002, 06:10:13 pm »
I'm planning to use brushed or ground aluminum or steel for parts of my cabinet.  I was thinking of laminating plain aluminum sheeting to wood, then using a sander to give it some texture.  Are there places where I can get this already made?  My preference is for metals brushed with textures that cause different lighting patterns to shine off it, like in modern metal sculptures.
I need both natural and anodized black metals.  Any suggestions?
My other job...
tellarite
  • Last login:Never
  • Codito Ergo Sum
    • Tellarite's MAME Cabinet
Re: Sources for brushed metal?
« Reply #1 on: March 25, 2002, 12:20:23 am »
I'm not sure what you are going for, as you weren't exactly clear (at least in my messed up my mind  ;) )
However, have you looked at formica? I know that sounds weird, but they have a product line called DecoMetal which is a metal foil in different varieties bonded to a thin peice of phenolic. This makes it really easy to bond to the wood.
Check out one example at : http://www.formica.com/north_america/products/decometal/solid_metals/chip.jsp?mode=&chip=M605
1UP
  • Token Junkie
    • 1UPArcade
« Reply #2 on: March 25, 2002, 05:58:27 am »
My other job...
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #3 on: March 25, 2002, 10:16:18 am »
Try using  a wire wheel in a dremel.  You should be able to get the results you are looking for. It may take a little practice to get the exact look that you want.
American Laser Games Wrapper
O2em Rom Utility
KeithD
  • Last login:October 19, 2008, 07:57:26 am
  • I HAVE built my own arcade controls!
    • Nameless Cab
« Reply #4 on: April 02, 2002, 05:59:48 pm »
Try using a scotchbrite wheel on a disc sander if you want a random pattern. The engine-turn finish on my control panel took about 4 hours to do on a Bridgeport, and I didn't quite get it even enough to look really good.
It would be tough to get an even finish by hand on a large sheet, so I think you are heading the right way with the random pattern.
K
You laugh because I am different;
I laugh because you are all the same.
