Author Topic: Mounting TV?  (Read 5524 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
Mounting TV?
« on: November 21, 2006, 05:54:48 pm »
I have a 70lbs tv 27inch for my cab.  I have the cab from the Project Arcade book (Lucid style).  My monitor shelf has about a 14-15 degree angle on it.  COuld I just rest the TV against the back part of the cab,  aka the upper back section?  Or should I put some wood in there to prevent it from sliding around?  I won't be moving the cab once the TV is in there.
Does anyone just have it where the TV is in there?  With no big support wood?
Re: Mounting TV?
« Reply #1 on: November 22, 2006, 12:36:40 pm »
It should at least have something in there to keep the TV from sliding if someone tilts the cab.  It can sit on the shelf if you want but you don't want some houseguest tilting the cab forward and having the TV slam around.
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
Re: Mounting TV?
« Reply #2 on: November 22, 2006, 09:34:02 pm »
I agree with Chad you mignt also want to keep the TV from coming forward out of the front and falling on the floor or a family member.
There are three kinds of people in the world those that can count and those that can't.
BobA
  • What Me Worry?
Re: Mounting TV?
« Reply #3 on: December 01, 2006, 09:50:10 am »
Some wood strips on the shelf will go a long way to keep it from shifting.   Any additional restraints will help incase the cab it tipped in any way.
spiffykyle
  • Last login:April 26, 2023, 08:13:59 pm
Re: Mounting TV?
« Reply #4 on: January 03, 2007, 10:20:06 am »
Put a couple of wood blocks in to keep everything centered. You can use a ratcheting tie down strap to hold the TV to the shelf if you're worried about it getting knocked around.
spiffy
A wise man once said, "Forgiveness is divine but never pay full price for late pizza." -Michelangelo-
fjl
  • Pixels Rule!
Re: Mounting TV?
« Reply #5 on: January 22, 2007, 11:45:11 am »
Ratcheting tie down strap? Pics please. Or a link.
shardian
Re: Mounting TV?
« Reply #6 on: January 22, 2007, 02:26:35 pm »
Re: Mounting TV?
« Reply #7 on: January 22, 2007, 02:51:47 pm »
I love those things.  I use them all the time.
northerngames
  • Trade Count: (+18)
Re: Mounting TV?
« Reply #8 on: January 23, 2007, 12:30:38 pm »
yeah you could drill 2 hole's on each side of the tv mounitng board on the bottom and then strap it down like a quad or dirtbike
or like the other member said just use 1 wood block on each side of the tv base and it will hold as long as you don't bounce the machine up and down lol.
my old mame cab I used the small metal eyehook's with the threaded end for wood and just screwed them into the wood where I needed them to make theat size bungie taunt  then took the bungie cord's and connected them to it and stretched them tight over the object and connecterd to the one on the other side and they worked great for me and also kept the base vibration down on some part's also but I had more sound then I should have in that cab lol.
« Last Edit: January 23, 2007, 12:34:38 pm by northerngames »
