Author Topic: Spinner resolution and Revenge of DOH  (Read 20606 times)
RandyT
    • GroovyGameGear.com
« on: November 13, 2006, 10:36:35 pm »
Most of my testing to this point has been with Arkanoid, thinking it was the king of spinner resolution hogs, but then I tried Revenge of DOH.
It's a great game, better than Arkanoid IMHO, but it appears to be using the Arkanoid geared spinner at 2x !  To be played correctly, this title requires an encoder wheel with a whopping 243 apertures when used with a modern 4x optical interface.  This is most likely in order to maintain it's 120 degree turn to screen traverse ratio, while having the in-game ability to make the paddle smaller, meaning a need for more possible positions.
My assumptions are that the game code is actually scaling the input in order to use the extra resolution when it needs it.  It could also be maintaining an internal paddle position for ball reactions that is greater than the on-screen resolution (although I'm a bit doubtful that the latter is happening.)
Anyone know what the real scoop is on this title and how it is using all that data?  Urebel perhaps?
In any event, it seems like there is a new benchmark for high res spinner titles now....
RandyT
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
Re: Spinner resolution and Revenge of DOH
« Reply #1 on: November 14, 2006, 06:02:40 pm »
D'oh!  :banghead:
to see my "Frankenpanel" and design notes, click here.
davieboynj
  • Last login:June 16, 2011, 01:32:09 am
  • Eating your legs solves lifes little problems.
« Reply #2 on: November 14, 2006, 07:43:40 pm »
I have both games in the same cabinet switching with a parallel port switch, sharing a spinner.  I can tell you that the vaus travels much faster in DOH than in Arkanoid, which to me seems to indicate that if emulated properly, you'd need less turns for DOH to be tolerable.  After playing DOH, it's tough to switch to arkanoid just because everything seems so sluggish (I still sometimes switch it back for the newbies, though :P )
RandyT
« Reply #3 on: November 15, 2006, 02:01:18 am »
I'm assuming you are talking about the original boards and a real Arkanoid spinner control here, yes?
If so, it sounds like you are saying that the range of motion is no longer 120 degrees, as it was with Arkanoid, rather something else?
Am I understanding you correctly?  How far do you need to turn the knob for the Vaus to get from one side of the screen to the other (at it's normal size) with DOH?
Thanks for the info,
RandyT
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
« Reply #4 on: November 15, 2006, 02:18:00 am »
Was the cabinet originally a DOH, Arkanoid or something else?
SlikStik Christian
  • Last login:December 20, 2007, 04:51:03 pm
  • The Worlds Best Arcade Products
    • SlikStik
« Reply #5 on: November 15, 2006, 09:17:10 am »
Hey RandyT,
   Just an FYI, The new SpinTrak Controller which is a joint venture new product between Ultimarc & SlikStik has already met that benchmark. It has been designed to and delivers a 250 ampeture rate at one complete rotation. It can easily handle DOH and Arkanoid no problem and is the highest resolution spinner ever manufactured.
There hasn’t been an official announcement as of yet, but this can be considered as one. It is now available on the Ultimarc website and will soon be available on the SlikStik website as well.
Features:
• Two modes of operation:
• Can be used as a lightweight Super High Resolution Low-Inertia Trackwheel control as used in "Arkanoid"
• Can also be used as a spinner with the addition of one of two sizes of fly-weight to provide inertia giving long spin-times
• The highest-resolution rotary control ever produced for arcade gaming use.
• Comes with optional choice of Spinner Tops made by SlikStik which are the same design and quality of the renowned SlikStik Tornado Spinner.
• Resolution of 1000 transitions per revolution makes this the only control ever to match the Arkanoid Trackwheel without noisy gearing.
• Precision dual-graticule optics as used on industrial shaft-encoders. Uses two etched Mylar optical grids.
• Sealed unit to prevent dust ingress to maintain precision accuracy.
• Dual sealed ball-bearing races give the ultimate in smooth control.
• One-Piece bearing housing/faceplate CNC machined from a solid alloy billet
• Available in two versions, for direct connection to USB, or for connection to our Opti-PAC or Mini-PAC interfaces.
• Usage not limited to gaming! Also suitable for precision control applications, CNC interfacing and other rotary measurement applications.
In addition it has a very small 2" X 2" installation footprint, can be fitted with 2 different size flyweights for different inertia and spin times, and uses a special version of SlikStik spinner tops.
Thank You
Christian
Team SlikStik
http://www.slikstik.com
RandyT
« Reply #6 on: November 15, 2006, 10:03:36 am »
Hey RandyT,
Hey Christian,
Didn't you state publicly that resolution wasn't important?
Just curious, how do you adjust that for different thickness panels?  No offense, but I am holding something in my hand that will be making spinner manufacturers need to update the claims on their websites ;)
Should be out in about a week.
RandyT
SlikStik Christian
    • SlikStik
« Reply #7 on: November 15, 2006, 10:58:43 am »
RandyT,
   No, just your previous claims of probable features. The shaft is set for 3/4" wood installation. Cant wait to see what you come out with.
Hey by the way, what ever happened to that rendering of that token spinner top you posted some months ago that never came to pass?
Thank You
Christian
Team SlikStik
fatfingers
  • Got UltraStiks?™
« Reply #8 on: November 15, 2006, 11:28:23 am »
"why can't we all just get along? "    :'(
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Donkey_Kong
    • CNC Machines
« Reply #9 on: November 15, 2006, 11:42:57 am »
This thing looks nice! Looks just like a skateboard wheel bearing at the base. If it is I'm getting this spinner as I will have plenty of replacements!
ahofle
    • Arcade Ambience Project
« Reply #10 on: November 15, 2006, 11:46:31 am »
2" x 2" footprint + high resolution =  :notworthy:
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #11 on: November 15, 2006, 11:54:22 am »
I once criticized Randy for being snarky in a competitor's thread, and said what a turn off it was for me as a potential customer, and I'd be a total hypocrite if I didn't turn around and back him when someone else does the same thing.
It's really distasteful, and a crummy way to get attention for your product. Make your own announcement.
RandyT
« Reply #12 on: November 15, 2006, 12:10:32 pm »
You probably won't like it.  But I think it will have a following. ;)
That's one of the reasons we have a new machinist on board.  I keep my prices low, so that sometimes means dealing with talented people who don't have much ambition.  We have finally found someone now who can meet our needs, and that's going to mean some cool things for the future.
That knob changed directions after a few discoveries along the way anyway.  The upcoming one will have added functionality, as well as maintaining most of the eye-pleasing look of the original.    I won't do a rendering of this one, as the real deal will be here in a couple of weeks..
RandyT
specfire
  • Last login:April 23, 2016, 10:39:09 pm
  • Shhh...
« Reply #13 on: November 15, 2006, 12:26:07 pm »
I have never jumped in on these threads where disputes break out and I know in the past that Randy has appeared to look hotheaded, but I think he is just really passionate about his products and maybe takes things too personally sometimes, but even when angry, he always tells the truth and stays on topic.
SlikStik on the other hand, this is just total utter crap; thread stealing, baiting and insulting all at once.  You are one Class A jerk (as if I didn't already know this.)  I don't care how good your product is, I won't buy it.
Man oh man, I can't believe that I have taken sides in this fight.  I have always had a personal rule, from way back to BBS and Usenet days, never to engage in these fights, oh well, I am in a cranky mood today.
BTW, Randy, compared to previous posts where you would get angry (often justifiable) your response here was very measured and classy.
I don't know if extra resolution beyond your original Turbo-Twist would be helpful, but I have never had a moment where it didn't perform perfect for me in all of the games I play (including Arkanoid.)
Read to your kids, you'll all be better for it.
Donkey_Kong
    • CNC Machines
« Reply #14 on: November 15, 2006, 12:46:14 pm »
This is one of the unfortunate evils of the online forum. When business desicions start to be made off of weird emotion because of this type of stuff...man it is tough! I have been in such a similar position as these guys and it sucks!! I lost everything because of a super competitive attitude mixed with very poor decision making as a result. It is so had not to get caught up in it though. When here you are chatting with your competition and your whole market gets to see the conversation and vise-versa. I don't envy you guys for this situation. I wish the best for all of you though and hope your end result is better than mine was!
Peace brothers!
SlikStik Christian
    • SlikStik
« Reply #15 on: November 15, 2006, 05:35:23 pm »
LOL!  :laugh2: Then why start now? Your commenting on how passionate he is (Are you running for comedian of the year?) 10 hours a day including weekends at the SlikStik for 6+ years is passion pal.
This is no where even close to thread stealing, it was in rebut to the statement about no spinner having enough resolution for DOH or it being a new benchmark that needs to be met, and that our new spinner exists and that it has more than enough resolution for the game Randy mentions. Insulting, umm check yourself :tool:
I was also a BBS and Usenet user back in the day and your point is? :dunno
Hmm, if you kiss anymore arse you might get a free RandyT shirt (Hehe I made a new product Randy”T” shirt)   :notworthy: :notworthy: :notworthy:  :tool:
Umm the Turbo Twist spinner cannot play DOH, in replicating the original DOH spinner because its resolution isn’t high enough, and that’s what is being discussed here, not Arkanoid :banghead:
Thank You
Christian
Team SlikStik
erictrumpet
  • Last login:February 17, 2016, 11:59:23 am
« Reply #16 on: November 15, 2006, 07:03:57 pm »
Yet another reason I steered clear of both of these guys and bought an Apache Blackhawk. These threads are mind-blowing!
Eric.
« Last Edit: November 15, 2006, 07:16:54 pm by erictrumpet »
RandyT
« Reply #17 on: November 15, 2006, 07:44:18 pm »
Christian, please quote where I stated that.  This thread was an exploration of how the internal code of DOH uses the data, not a product comparison.
It was intended to see if there really is a standard to be met there.  So far, I'm not convinced that there is.  Only someone with a real machine, or the ability to pick through the ROM code, will be able to tell us for sure.
That may be what you are discussing, but it doesn't seem to be true.  I fired it up with the old version of the TurboTwist and increased the sensitivity.  It still has single pixel precision over what appears to be the same amount of rotation (there is a legion of TurboTwist users who can verify this for you.)
That tells me that the internal code of the game is dividing (there are only so many positions available for the Vaus due to the screen resolution.)  So, unless the range of motion has drastically changed, the extra resolution looks like it is being discarded and may be unimportant.
Something else of interest;
This ROM is said to have problems.   The cocktail version has 2 spinners, but the stand up has only one.  A trip into the service mode shows that both P1 and P2 spinner values change when the spinner is rotated, with the P1 values going up in increments of 2 for every one of player 2.  Something is broken in this title, and it seems to be the input code.  I'm really suspecting that DOH and the original Arkanoid are using the same controls scheme, but DOH's is broken in MAME.  This says to me that increasing the sensitivity will allow perfect gameplay, even with an original TurboTwist.
But I'm still waiting for the definitive answer on this to know for sure.  Does anyone have anything useful to add to this discussion so that we might be able to get to the bottom of the anomaly?
The thread I started had nothing to do with any particular spinner outside of the requirements of the game in question and the modern day equivalent.  If you believe the discussion has degenerated, would it not have been prudent to avoid the furtherance of that issue rather than helping to fuel it?
RandyT
shardian
« Reply #18 on: November 15, 2006, 08:11:30 pm »
I just want to throw in support for Randy in this thread. Christian is way out of line here without a doubt. Randy is always around here offering support to anyone and everyone where he can. Christian only shows up to plug products, insult competitors, and berate people who question him.
It is too bad that Ultimarc now has to be drug into the slikstick mudpile now too...
On that note, I'll also throw in my support for Andy at Ultimarc just for good measure.
davieboynj
« Reply #19 on: November 16, 2006, 12:09:17 am »
I realize this thread has been hijacked, but let's get back to the matter at hand:
The spinner was originally from an arkanoid.  I would estimate 150 deg to go end to end in arkanoid, and 75 deg to go end to end in revenge of doh.  The motion is still very smooth in doh, so i think that alone is pretty fair confirmation that arkanoid is the one that is intentionally dropping information.
<stoking fire>
Christian,
Wouldn't starting a thread announcing your product be a slightly more productive than dumping it in the middle of a thread started by RandyT (who, by the way, is a contributing member to these forums)?  I don't know what this or any of your other pissing matches are about - - but whether you believe it or not, you always seem to be the person instigating.
In all fairness, Randy can get away with a lot more, as he posts in a lot of peoples' topics.  I rarely see you jump in to give someone advice as to how to fix their refresh rate on robotron or their jammed coin mech.  The only time I see posts from you is when you're trying to kick either a competitor or a customer in the teeth.  You really can't blame any of us for thinking Randy is more "passionate" about the hobby than you, and that you are, as you like to say, the tool.
</stoking fire>
RandyT
« Last Edit: November 16, 2006, 10:30:18 am by davieboynj »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #20 on: November 16, 2006, 12:44:53 am »
I'd like to throw in support for .. ME!!!
NO MORE!!
Havok
  • Trade Count: (+17)
« Reply #21 on: November 16, 2006, 11:31:34 am »
SlikStik posts -  :spam:
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #22 on: November 16, 2006, 02:46:55 pm »
Christian, you really should think about what you are trying to achieve with a post before you press the "Post" button. Or is it really your intention to run customers away from you?
On the other hand, what was the point of this thread anyway? Yet another "product announcement" for a product that doesn't yet exist?
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #23 on: November 16, 2006, 03:20:34 pm »
I too have to throw my support behind Randy and GGG here....
Every time Christian posts here he's either insulting his competitors or insulting members of this forum.  It doesn't seem to matter how many times we try to explain it to him, that he's putting off his pottential customers, it doesn't seem to sink in.  This is preciselly why I will NEVER EVER buy any of his products.
As for Andy at Ultimarc.... His quality and service record is pretty perfect! (until now) Damned good luck to him actually getting product delivered and promises met from Christian. The number of reports of appauling customer service from him are astounding.
Andy if you're reading this then, you really need to consider who you're involving yourself with. You're risking your own reputation here especially when Christian comes in here insulting people again and again and again.
He needs all the support he can get if he's involved with slikstick... Maybe we should club together and buy him a few sessions with a therapist? I'm just not sure what he was thinking here.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
SlikStik Christian
    • SlikStik
« Reply #24 on: November 16, 2006, 04:15:11 pm »
It’s pretty simple really, but why try to make something into something it isn’t. I could be a kiss A*S and jump in here 24/7 like RandyT does answering every possible question with a helpful answer to every BYOAC members post with its sole intention to drum up more business and look like a super hero but instead of being a message board rat I tend to think more along the lines of letting the products speak for themselves.
RandyT made a blanket statement without actually stating that there is a product that is already in production and for sale that already exceeds that specification and I made a public “albeit not in its own post” statement confirming its existence. In fact the new Spintrac spinner is by far the highest resolution spinner to date at 250 apertures and will play Arkanoid and DOH exactly as it was meant to be.
RandyT followers come out in droves with total crap comments, you’re absolutely correct; I did defend my self. Don’t get a fat head Randy, there aren’t many of them.
It is what it is; SlikStik manufactures the highest quality components for this industry and is always coming out with new improved and radical components for arcade systems.
Many BYOAC dwellers own and use SlikStik products, and confirm their proven quality.
Fozzy, your comments are simply ludicrous, you have no info to back up your statements and you have no clue as to what you are talking about.
« Last Edit: November 16, 2006, 05:28:41 pm by SlikStik Christian »
Thank You
Christian
Team SlikStik
RandyT
« Reply #25 on: November 16, 2006, 04:35:45 pm »
Christian,
I think that's the first time I've been called that here :)
But in any case, if you take stroll through the archives, you'll see that I have been a contributing member here LONG before I ever had a thing for sale.  I've been involved in this hobby for decades, and I don't view it as a "money grab" like a lot of vendors do.  If you think that is who I am, then you obviously don't know me.
Not sure where you got that from, but until now, when the spinner resolution issue pops up, it seemed like Arkanoid was at everyone's lips.  DOH surpasses that requirement and I am trying to figure out why, seeing as the graphic resolution of the game is the same.  These things have to be considered when building controls, and last I checked, that was the theme of the site.
Thank you.  The last calculation I did put Arkanoid at 120 degrees, so DOH is probably half of that at 60.  Arkanoid isn't really dropping info, it's apparently just not collecting all that it could from the control.  I'm still doing some calculations, but it looks like DOH may actually be collecting it and using it to reduce the turn to travel ratio.
Time to crunch some more numbers.....
RandyT
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #26 on: November 16, 2006, 05:06:31 pm »
That has just got to be the bloody limit, now he's accusing RandyT of contributing in a helpful way  ??? ::) :dizzy:
BTW Sorry for missing the point of the thread. Hope you get the answers you're looking for.
davieboynj
« Reply #27 on: November 16, 2006, 05:23:45 pm »
RandyT
Theoretically, wouldn't this mean that you could double the (software) sensitivity of the spinner in arkanoid while losing zero accuracy?
I still don't understand how in a MAME context this changes anything.  the old spinner had X teeth.  if DOH uses all of them, then for ACCURATE emulation, wouldn't you need X teeth?  Hardware is hardware, right?
btw - - I'd like to point out that i have never purchased a GGG product, or a slikstik product.  I only know what i read.
Banacek
  • Last login:November 08, 2017, 05:01:31 pm
« Reply #28 on: November 16, 2006, 11:38:57 pm »
RandyT, let me know when you figure out this Arkanoid spinner thing. The lady of the house will love you for it :)
/threads like this just remind me never to buy SlikStik...
Xiaou2
  • Last login:Today at 01:29:36 am
  • NOM NOM NOM
« Reply #29 on: November 17, 2006, 02:23:39 am »
 RandyT isnt a Saint either people.   As far as I remember, he has barged in on others
product announcements before.  His comments to other vendors, and even board
members has contained some pretty nasty things.   And overall, his attitude can
be just as bad if not worse, than all of the other vendors.
 I dont blame Christian for his hostile post, because RandyT Im sure, has been
hostile twords him in the past...  (or used non hostile, but provoking
tactics)
 However,  as the saying goes.. "Two wrongs dont make a right".
 Who will be the bigger man?  Will any of these vendors ever Grow up?
 Stay Tuned...
 :P
 Well, at least we have good competition that will improove products much
faster  hehe
 My money goes to the best products.  I could care less how bad thier
attitudes are..   though I do hope things change for them.  Thier
baggage must be pretty heavy to lug arround all the time.
And thier hyper inflated egos just kill everything arround them.
A little 'humble pie' goes a long way.
RetroBorg
« Reply #30 on: November 17, 2006, 02:44:16 am »
RandyT,
Not one to take sides here but isn't the pot calling the kettle black?
Brandon,
   I guess great minds do think alike. Here are some early photos of our WIP version of the SlikStik Tornado spinner DOT style that we have been working on, it employs the same exact theory in the diagram you posted.
Spring tensions and vertical glide options are being developed as we speak.
This project has now been accelerated and will be released as soon as it is perfected.
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
« Reply #31 on: November 17, 2006, 06:53:16 am »
Wow.  Just...wow.  This makes me suspect an actual personality disorder of some kind.
destructor
« Reply #32 on: November 17, 2006, 07:32:46 am »
I have Tornado and I'm not able to play on Arkanoid, it's crap (I tested different analog settings). I remember Arkanoid arcade machine where spinner works perfectly, beautiful. Only one game where Tornado is really good is Pole Position.
I want to ask where is difference between SpinTrak and Tornado? Can someone tested it on Arkanoid, Plump Pop or others breakout?
RandyT
« Reply #33 on: November 17, 2006, 10:40:18 am »
... (or used non hostile, but provoking tactics)
You mean like the one you just used?  I'm a real person too, Steve, and real people react when  provoked.  You and I have a history that involves debates over technical issues where you are frequently incorrect, and never seem to do the research or admit when you are mistaken .  And because I bring light to that fact, you are part of a very few select individuals who ride me every chance they get and this post is no exception.  You shouldn' t be surprised when the "kid gloves" get removed for you, and that doesn't make my interactions with you as an individual, representative of how I interact with other, more reasonable members of this community.
As for whether I am as "bad or worse than all of the other vendors", I think your view may be a little biased.
And for anyone still interested in the original topic, I'm still on it.  Just got sidetracked by some parts sourcing issues that kept me up all night....need coffee first......
RandyT
« Last Edit: November 17, 2006, 10:43:20 am by RandyT »
davieboynj
« Reply #34 on: November 17, 2006, 10:48:09 am »
RandyT
Saw you posted and was hoping it was something technical...  oh well.  If you have anything else you want me to figure out, let me know.
RandyT
« Reply #35 on: November 17, 2006, 11:00:47 am »
Yeah, sorry.  Got my coffee now :P
Here's something quick:  Yes, if the hardware is not using all of the information it is collecting, either by dividing it or discarding it, increasing the sensitivity in MAME will still allow for "near perfect", if not completely authentic gameplay.
However, MAME limits the upward scaling to 2.55 x of the original, which may or may not be enough to get it there.  This in turn, may be addressed through mouse speed settings in windows, but that starts getting messy.  More info shortly. :)
EDIT:
Also, tooth count on one does not always equal tooth count on another, as it can be interpreted at 1x, 2x or 4x depending on the hardware.  From what I can tell (need more research) DOH appears to be using 2x, while Arkanoid uses 1x.
RandyT
« Last Edit: November 17, 2006, 11:38:44 am by RandyT »
davieboynj
« Reply #36 on: November 17, 2006, 11:38:31 am »
Also, tooth count on one does not always equal tooth count on another, as it can be interpreted at 1x, 2x or 4x depending on the hardware.  DOH appears to be using 2x, while Arkanoid uses 1x.
Sorry, you're losing me on this "hardware" thing...  they both have identical hardware (a 2 led spinner) connected to the L and R of a jamma harness.  To me, this means that there are the same number of pulses being sent to the PCB per revolution.  As Doh does not jump more than one pixel at a time, I would argue that DOH uses 1x and Arkanoid uses 1/2x on the software side...  2x seems, to me, to indicate that DOH skips, which it doesn't.
If you're saying that you can use 3 led's to get double the sensitivity out of a wheel than with 2, I'd agree that you'd only need 1/2 the teeth that an arkanoid spinner has.
Hmm - Maybe we should categorize spinners by pulses per revolution, not teeth?
Or is this just a tomayto-tomahto thing, and i've missed the point completely?
RayB
  • There's my post
    • RayB.com
« Reply #37 on: November 17, 2006, 12:18:01 pm »
Is the hardware truly identical or could the gearing be different?
Consider that the # of apertures passing by is what makes a difference (and sample rate of course)? For example, you could have a large wheel that spins at one rate, or have a very small wheel with less holes in it, geared such that it spins very fast and the result is the same # of apertures passing over the sensor...
NO MORE!!
2600
« Reply #38 on: November 17, 2006, 12:47:06 pm »
RandyT,
I am confused about what you are confused about.
davieboynj says that the angle is about half.
You think Doh is using a higher resolution, 2x.
It seems that you figured everything out in that Doh uses 2x and Arkanoid uses 1x.
And davieboynj has basically confirmed it by testing his boards.
I've been following the thread, but I'm not sure what else are you looking for?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #39 on: November 17, 2006, 01:45:10 pm »
The difference is how the same "pulses" are decoded.  ("Pulse" is the wrong term though, as it implies a limited time on, while the actual signal is on or off depending on if the sensor is blocked or not, and can be steady on if it doesn't move.)  Remember that while PC mice decode the signals themselves and send the decoded info to the PC, (most) arcade spinners and TBs send the raw signals to the PCB.  So the PCB does the decoding.
This is how one arcade game can be 1x and the other 2x with the same spinner; different PCBs decoding differently.
I can go into the details of 1x, 2x, 4x, but to quote parapharse MEASUREMENTS & CONTROL, September 1988, Gerald S. Gordon:
"... quadrature square-waves contain 4 edges [or states] per [tooth]. Simple circuitry can be used to detect 1, 2, or 4 of these edges [states]."
Older tech detected on edges, current tech does state changes, but both can do the 1x, 2x, or 4x per tooth.
Robin
Knowledge is Power
