Author Topic: Happ perfect 360 , It's making a crunching noise.  (Read 19573 times)
Keypel
  • Last login:December 11, 2006, 10:11:34 pm
« on: November 13, 2006, 01:55:14 pm »
Just installed a p360.
This is hard to explain but when moving the stick from right to left or up to down it's making a crunching (snapping , boing) sound.
I think it's the spring making all that noise. The stick does not feel smooth. Is this normal?
Here is a video of the problem (56k friendly)
main download: Click Here
alternative download Click Here
« Last Edit: November 15, 2006, 09:20:43 pm by Keypel »
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Happ perfect 360 , It's making a crunching noise.
« Reply #1 on: November 13, 2006, 02:53:37 pm »
You've got the pivot cone installed upside down.  The wide part goes down, toward the base of the stick.  The small end points up toward the handle.
Keypel
« Reply #2 on: November 13, 2006, 04:10:37 pm »
Checked the pivot cone. It was installed correctly the first time with the wide part going down. Tried it both ways for the hell of it, it's easy to tell the difference.
Any other ideas?
Maybe grease the pivot cone? Change the spring? I have an ultimate joystick, maybe try using that spring in the 360? Maybe buy another perfect 360?
I noticed the spring is super stiff, I have to use a screwdriver to push down the actuator just to put the E-clip on.
with the ultimate you can push the actuator down using just your thumbs.
Kremmit
  • - AHOTW -
« Reply #3 on: November 13, 2006, 04:38:28 pm »
Hmm.  That's usually it.  It certainly shouldn't be doing that, something's wrong, but there arent really a lot of other pieces to mix up.  Have you got both spacer sleeves installed? (you shouldn't)  Is the main spring somehow not lined up correctly, moving around in the base?  Is the dust washer somehow binding against the handle?  I can't think of any other parts that move or make contact...
shardian
« Reply #4 on: November 13, 2006, 04:39:30 pm »
Check it all again. I had the same issue in a reunion 4-way. I thought I had it together correctly to, and dismissed the pivot cone. I was wrong.
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #5 on: November 13, 2006, 05:12:20 pm »
Keypel
« Reply #6 on: November 13, 2006, 06:33:51 pm »
ok, I know (I think I know) why it's making that snapping crunchy noise (see pic below)
When I remove the optical hub, the crunchy noise stops.
Have no idea how to fix it.
kowal, I'm reading that thread now......
« Last Edit: November 13, 2006, 07:23:23 pm by Keypel »
Keypel
« Reply #7 on: November 13, 2006, 08:09:49 pm »
ok, Seems that we all agree that the crunchy noise is caused by the plastic piece that sits between the spring and the actuator rubbing against the optical hub.
Had to study the hell out of this picture (below) by kowal/2600 before it made any sense.
According to the picture above, It looks like a taller actuator will move that other piece further away from the optical hub. I have no idea on how to *make* a taller actuator.
Some other solutions I thought of would be to add a small washer between the E-clip and the actuator. Another one might be to add spacers between the main housing and the optical hub.
What do you guys think?
I take it that everyone that owns a perfect 360 has this problem??
I can't belive the makers of perfect 360 would allow such a design flaw!
kowal
  • Suzo 4ever
« Reply #8 on: November 14, 2006, 02:14:32 am »
funnel hinders about  hub but the bang of spring generates pivot (is too wide).
if you have not different pivot. use sticking plaster
taste to to wrap around stick tape.
P360 has a lot of constructional mistakes- Wico base is total crap. This is old construction.
everyone...
some men this does not disturb. they are exacting little.
http://forum.arcadecontrols.com/index.php?topic=57724.0
miles2912
« Reply #9 on: November 14, 2006, 03:21:04 pm »
I have 2 perfect 360's in my cab with absolutely no problems or noise.  If yours is defective Happs will replace them.  These are top of the line sticks and should operate as such.  My gut says you put them together wrong but it sounds like you are ok there.  They should be whisper quiet.
D-
destructor
« Reply #10 on: November 15, 2006, 02:44:45 am »
D-
And pay for replacing every time. In my P360 is noise too. In your P360s must be the same, check it very carefully.
AlanS17
    • AlanS17
« Reply #11 on: November 15, 2006, 02:50:37 am »
The RetroBlast review never mentioned anything about a noise. Did they miss something?
kowal
  • Suzo 4ever
« Reply #12 on: November 15, 2006, 06:44:43 am »
they do not write about many things. They estimated on 5 - P360 diagonals it hardly it records.
Diagonals Mag-stick they estimated on 2 :laugh2: this joystick has very easy diagonals restrictor is square.
destructor
« Reply #13 on: November 15, 2006, 07:59:18 am »
RetroBlast reviews are good for beginners.
I don't want to say nothing wrong about RetroBlast. Point is that on RetroBlast are not all very important informations and some informations are wrong.
« Last Edit: November 15, 2006, 08:02:36 am by destructor »
ften
  • Last login:March 06, 2022, 10:20:43 pm
  • Beep Beep
    • Fathertom.net
« Reply #14 on: November 15, 2006, 07:47:02 pm »
Having the same odd noise issue. Odd thing is that I bought two 360s, one makes noise and one doesn't. Annoys the hell out of me.
-FTen
Keypel
« Reply #15 on: November 15, 2006, 09:02:13 pm »
Since it's nearly impossible for me to describe this crunchy , snappy, noise I made a small video (only 1.5mb) Please take a look and tell me what you think.
or if that one doesn't work here is an alternative one, Click Here
« Last Edit: November 15, 2006, 09:16:40 pm by Keypel »
kowal
  • Suzo 4ever
« Reply #16 on: November 16, 2006, 02:58:53 am »
it is pivot
put together joystick and see that they will move he on sides after center.
these hatches cause this crunchy. this acts how shooting from ruler in boards
the best to make new shaft, pivot$ actuator
« Last Edit: November 16, 2006, 03:08:22 am by kowal »
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« Reply #17 on: November 16, 2006, 09:34:51 am »
Hey guys, I pinged Kevin as he wrote the 360 review, he should chime in shortly. Sorry your having issues, but I agree with miles2912, you may want to look into replacements. It is very possible the stick has poor quality control and we got a good one while others may be getting defects.
Also wanted to address these two posts,
Diagonals Mag-stick they estimated on 2 Ha! Ha! Ha! Ha! Ha! Ha! this joystick has very easy diagonals restrictor is square.
I pointed this out to Kevin as well, again he did that review, but please elaborate here or in email. I apologize but I'm not quite grokking what your pointing out and if there is an issue in one of our reviews we need to remedy that.  james at retroblast dot com
Again on this one, please let us know what you find that you feel is wrong. We all make mistakes, but would like to fix them whenever they are spotted.
KevSteele
  • Last login:January 20, 2025, 11:29:37 am
  • Retrogaming Media Mogul in Rehab
« Reply #18 on: November 16, 2006, 10:18:47 am »
I've never heard a sound from my P360's
A Happs P360 is perfectly silent in operation, with no noise at all and very smooth motion in any direction. If you don't have that, something is either installed wrong or something's broken.
Looking at the video, I think I can see what's wrong -- the bushing (the small angled "washer") is installed upside down on the shaft. Flip it over, reinstall, and see if that fixes things. I had a crunchy noise once when I reinstalled the parts wrong. Did you get a schematic with the stick? Check the Happ site, they usually have assembly diagrams available in the parts listing.
« Last Edit: November 16, 2006, 10:23:37 am by KevSteele »
Kevin Steele, Former Editor and Publisher of RetroBlast! and GameRoom Magazine
destructor
« Reply #19 on: November 16, 2006, 10:26:51 am »
RetroJames, I don't know how long you or your friend test this joystick.
Diagonals are one of the triumphs of this design
Yes, it's true but with moded actuator.
A firmer spring and a complete lack of friction make an interesting combination that really gave me a feeling of absolute and total control.
Firmer spring is hard and hand is tired after 1-2 hours of playing (it depend from your musculature).
It's even better with a SlikStik stainless steel handle. I had P360's with stainless steel balltops installed on my SlikStik control panel, and I am in love with these joysticks. The shape and feel of the SlikStik handles just makes the gameplay that much more enjoyable.
It's almost true. Look at this picture:
http://www.retroblast.com/photos/joysticks/p360_slik.jpg
how high is P360 with SlikStik in this panel? It's almost as tree :) Too long handle = too long way to engage.
In review I don't found any word about connection 5V and GND cables with P360 PCB. It's very weak and usually it must be changed for ... gold pins for example.
On joystick Chart we can read:
Diagonals = 5 (easy) :o
For J-Stik is 5 too. In J-Stik diagonals are far easier than in P360. In T-Sik we have 4. T-Stik have square restrictor, P360 - circle and diagonals on P360 are easier than on T-Stik?
It can be true but when you use moded actuator, not default.
You wrote that diagonals in Mag-Stik are hard (2). Jisus, no comment.
Otherwise there is more things for correct but I don't want to write new review. Better if someone will translater kowal's reviews.
destructor
« Reply #20 on: November 16, 2006, 10:31:06 am »
All parts are fited correctly, it's Happ's slovenling during production, nothing more.
KevSteele
« Reply #21 on: November 16, 2006, 10:37:36 am »
Destructor,
I'm glad you're on top of things and know exactly what the problem is.
As far as testing - I have two P360's in my cabinet, and I use them every day. Best joysticks I've ever owned. The picture you saw is with SlikStik's custom joystick handles. They're the same height as the standard handles, so I don't understand where you're claiming they're too high. Perhaps you've got your shaft set for metal control panels, not wood.
The cable connections are fine, no need for gold pins. Firm spring is fine, no sore hands. No need for a modded actuator, either. Diagonals are a cinch with this stick (I play Robotron all the time, and diagonals are life-and-death in that game  ;))
Anyway, like I said: a P360 should be smooth and silent in operation. If not, either a part is broken or installed incorrectly.
destructor
« Reply #22 on: November 16, 2006, 11:06:05 am »
You use them every day. But how long in every day? 1 hour? I usually play 8-10 hours, in tournaments 16 hours for a day.
My cables disconnect after week (I didn't touch cables. Cables were hidden inside panel).
Spring isn't fine.
Diagonals are ok? - try to play DoDonPachi or other shmup, next change actuator to moded (if you have). Next try to play on beatem-up games (Final Fight) and try to move by diagonals. For me playing on Knights of the Round is very hard using this stick (Ultrastik 360 is perfectly here).
And I understand you, for you joystick is fine. You use it for not 'hardcore' playing.
KevSteele
« Reply #23 on: November 16, 2006, 11:15:22 am »
Heh...if Robotron isn't hardcore, I don't know what is.  8)
destructor
« Reply #24 on: November 16, 2006, 11:21:11 am »
I don't say what game is hardcore. And say about your playing.
And yes, Robotron isn't hardcore game. I remember it from one tournament. Unlucky I used kayboard during this tournament and my score was not high.
Why you say about Robotron only? Is it knows that you test P360s on this game only?
« Last Edit: November 16, 2006, 11:23:45 am by destructor »
KevSteele
« Reply #25 on: November 16, 2006, 11:34:59 am »
Destructor,
I play a ton of different games: schmups like Do Don Pachi, classics like Robotron, and more.
P360's are great, and I've played the hell out of them. My kids have as well (my youngest has even dangled from the cab holding on to just the joysticks). The P360's have held up fine, no crunching, smooth motion, easy diagonals.
We have a difference of opinion here. No right or wrong, but I stand by my review. You're free to disagree with me.  :)
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #26 on: November 16, 2006, 12:37:52 pm »
Hardly a statement of qualificaton to evaluate whether the game is hard core or not.  :dizzy:
I, for one, would disagree with your assessment, but perhaps I am just too old or not as skilled as you.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
Keypel
« Reply #27 on: November 16, 2006, 12:44:04 pm »
KevSteele, That video was meant to prove beyond a reasonable doubt that the pivot bushing is installed correctly.
Here is a picture of the assembly diagram:
And here is a picture from the video:
How can you say the pivot bushing is upside down?
I've spent the last three days taking this joystick apart , putting it back together, making 3d drawings, examining it, making videos, etc
The bottom line is the joystick I got was poorly made. The pivot bushing fits loosely around the shaft and the actuator was probably cut a few hairs to short as well. These two problems are causing the loosely fitted pivot bushing to shoot from side to side causing that snapping sound you heard in the vid .
I'd like to take it back but happ charged me $17.57 for S & H +tax on a $50 joystick. Now I'd have to pay to ship my old 360 back to them and hopefully wouldn't have to pay for them to ship me a new one. Then I'd be afraid of getting another p360 that came from the last manufacturing batch.
« Last Edit: November 16, 2006, 12:59:03 pm by Keypel »
destructor
« Reply #28 on: November 16, 2006, 12:48:39 pm »
Cheers.
Try to play on Zing Zing Zip. I still can understand how is possible to normal play on this game. Looks as simple shooter but in really it's ... hardcore?
KevSteele, I agree with introduction and instalation only :D
KevSteele
« Reply #29 on: November 16, 2006, 12:55:33 pm »
Keypel,
I'm not sure what to say is the problem - like I said, it could be a broken part. Another option is possibly a mis-matched part (i.e., a bushing from another model of joystick)
Whatever the reason, it most certainly is not working as it should. I know it'll cost you to mail it back, but an exchange is probably your best bet at this point, as it sounds like you've tried everything else.
CheffoJeffo
« Reply #30 on: November 16, 2006, 01:00:06 pm »
You remember playing Robotron using a keyboard -- how can that possibly be a reasonable basis for evaluation ?
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
ahofle
    • Arcade Ambience Project
« Reply #31 on: November 16, 2006, 01:05:43 pm »
You should watch some of his MAME inp replays.  I would say he's one of the most qualified people on this board to speak to joystick performance and game 'hardcore-ness' (although Robotron is still hardcore hehe).  I'm not sure what he does for a living, but I wish I could play games 8 hours a day. :)
« Last Edit: November 16, 2006, 01:12:19 pm by ahofle »
kowal
  • Suzo 4ever
« Reply #32 on: November 16, 2006, 01:11:42 pm »
Kevin I like your reviews. But several mistakes are also.
P360 has tragical diagonals.
http://www.shoryuken.com/
read pleyers opinions about this joystick. All they have problem with diagonals.
Is hard to make low block/jump in fighters. Professional players do not play on P360, because he has bad diagonals. I bought P360 after reading review on Retroblast. I wanted to have joystick with good diagonals. And he acted how 4way ;D  he cracked and had asymmetric throw! I have 4 P360. The same problem in every was. In different degree but he was.
You should repair this review. A lot of men read this review. Opposite situation is Mag-stick, sorry but You harmed this joystick. It was not it been possible to does not hit in diagonal on square restrictor :angel:
Handle balltop is lower from battop-this is standart. Look on Japanese joysticks. He after installing shaft should stand on 2-3cm.
This SilkStick stands unnaturally high-4,5cm! it was not it been possible to play effectively-the level of hands is uneven (stic<--->buttons)
KevSteele
« Reply #33 on: November 16, 2006, 01:21:27 pm »
Kowal,
Like I said, we're going to have to agree to disagree here - I get great diagonals from the P360. You're obviously a fan of fighter games, which I don't play, so there's one reason for disagreement.
Same thing with the SlikStik sticks - just because a Japanese cab has them lower does not make that the "gold standard" height. The P360 review was with the included bat shafts, not the SlikStik balltop ones, which were added after the review was complete.
I stand by the review, and respectfully disagree with your opinions on the diagonals.
destructor
« Reply #34 on: November 16, 2006, 01:22:30 pm »
Cheers
1. Special prepared keyboard :D (not cheating or mapping keys otherwise). 'Prepared' keyboard for 2-joystick games isn't wrong. I won Inferno round in GEGOTW tournament using keyboard. Most my scores was made using keyboard until I buy first 'arcade' stick (X-Arcade :D). In whole word is only one controller not for me (I don't know how to use it :D) - game pad.
2. All (almost all) Golden Era games are for me ... patterns, I'm not happy when I must play again on old games where one problem only is found pattern for one stage and repeat it for others. For Robotron it's a bit harder because game is harder with every level, (it depends from live setting too) but it's boring still.
destructor
« Reply #35 on: November 16, 2006, 01:28:29 pm »
Kowal,
Did you create this reviews for you or for all players? Or maybe you are HAPP share-holder? :)
90% players say - diagonals are not easy
You and 10% players (maybe HAPP share-holders too :D) say - diagonals are easy
What should be in review?
Or you can write in review: I and 10% players from world say that diagonals are easy, 90% players say that diagonals are hard.
RetroJames
« Reply #36 on: November 16, 2006, 01:30:02 pm »
Actually I reviewed the MagStik and I did have issues at first with hitting the diags but soon adjusted. I still use them today and have no problems at all hitting my mark.
There is a load of subjective material in your statements, something one has to watch out for when reviewing or commenting on controls. You may note I was very careful to frame my opinions as just that.
Aside from faulty craftsmanship, poor engineering, or poor manufacturing, if a stick is well made, whether or not you like it, or it is good for you, is VERY subjective. Height, ability to hit the diags, ball or bat, dustcover ontop or bottom, color, stiffness, throw, none of these can be considered good or bad overall unless there are extreme cases like you can't move the sick or whatever, they are all very much tied to personal taste, ability to adapt, and preference.
Always looking for a factual error to be fixed in reviews, but on the opinion and subjective side I too stand by anything I have written.
RetroJames
« Reply #37 on: November 16, 2006, 01:33:41 pm »
Kowal,
Ok and now you pissed me off.
'Did you create this reviews for you or for all players? Or maybe you are HAPP share-holder? :)"
I'll thank you to apologize for that remark, it's a ---smurfy--- thing to say. We and the other contributors at RB write these reviews as subjectively as possible, based on our observations, experience, ability, and so forth. Even a hint that we pander to vendors at the expense of the readers really ticks me off. We all work too effing hard to keep RB going to have you or anyone else imply that we are colluding with vendors in our reviews.
KevSteele
« Reply #38 on: November 16, 2006, 01:35:13 pm »
Destructor:
You say 90% of players find diagonals hard on the P360?
I say that 99% of statistics are made up on the spot.  ;)
kowal
  • Suzo 4ever
« Reply #39 on: November 16, 2006, 01:44:16 pm »
Kevin you need not agree with me. But then many men's opinion. P360 has bad diagonals.
http://forum.arcadecontrols.com/index.php?topic=53037.0
you read  players opinions on SRK?
since this in fighter and shmups has weak diagonals it means that there are weak diagonals. You  not need play in fighters this your matter. If would had good diagonals it was given to play in all games. Not every will buy this joystick to Robotron.
professionals see defect this joystick. How you think who it is right. Do men which tournaments win or someone who plays 4fun in  house?
« Last Edit: November 16, 2006, 06:23:13 pm by kowal »
