Author Topic: I-Pac Button Problem Solved  (Read 1418 times)
mvolke1
  • Last login:August 27, 2020, 09:48:24 am
    • My Pi-Powered Galaga-Thmed Bartop
« on: November 12, 2006, 05:42:01 pm »
Hooking up my controls today, and having some problems with the "Coin 1" button. After trying several different switches, only one of them appears to work to activate the Coin 1 button. The switches work for their other assigned functions, but not for "Coin 1."I don't think it's a bum I-Pac because I did fine one switch that works to activate the Coin 1 button. And I don't think all of the switches are bad because they work for other functions.
Any ideas?
« Last Edit: November 16, 2006, 04:47:25 pm by mvolke1 »
I'm with stupid.
AlanS17
    • AlanS17
Re: I-Pac Button Problem
« Reply #1 on: November 12, 2006, 07:58:01 pm »
I'm not seeing a problem... If you have one that works, what more do you need? I don't have an explanation for the behavior, but it doesn't sound like it's preventing you from getting everything working.
MrQuan
  • Last login:October 30, 2008, 03:47:14 am
  • Well, at least you threw a punch...
    • Tilt Arcade - Check it out!
« Reply #2 on: November 13, 2006, 11:09:38 am »
Strange problems usually end up being a grounding issue, I would suggest the switches working or not is more coincidence???  Perhaps check your wiring, and if you're daisychaining your ground, make sure you don't have any faulty or intermittent contacts (a multimeter set to continuity indication would be perfect for this).
mvolke1
« Reply #3 on: November 14, 2006, 03:29:59 pm »
I will check the ground. I did try new wiring, but with the same ground. All of the buttons are on the same ground. The coin for player one is the first one in the chain, so that could be it. I'll have to get a multimeter and check it out.
The reason I want a player one coin is two-fold. It's a cocktail table, so when I'm playing one-player, it's annoying to reach over and hit the coin button. Secondly, some games, like Guantlet, require each player to have their own coin button to get credit.
I'm with stupid.
shardian
« Reply #4 on: November 14, 2006, 03:33:46 pm »
Did you run a ground loop? I am guessing this is what you were implying, but just wanted to clarify. Could help in troubleshooting.
mvolke1
« Reply #5 on: November 14, 2006, 03:39:44 pm »
If you mean a daisy chain, then yes. Each control item is on the same ground going to the I-Pac.
I'm with stupid.
mvolke1
« Reply #6 on: November 16, 2006, 04:46:23 pm »
Hey All,
It did end up being the ground. I borrowed a multimeter from work and the groundwas not connecting. Changed the wiring and I'm all good. Strange, since I'm using braided, but whatever. It works.
And thank you all for your help!  :notworthy:
I'm with stupid.
