Author Topic: trackball ring: update  (Read 2643 times)
darkmanx
  • Last login:May 29, 2003, 04:46:57 am
« on: April 03, 2002, 03:24:57 pm »
Hey all. I just wanted to give an update on the trackball ring idea Elkor had. it was to use a speaker port. Well i ordered the 2" one and it it PERFECT. the tubing part will be cut down so just a ring is left. the hole is the EXACT same size as the crystal trackball top piece, cant get better than that. the plastic is easy to cut and i will get some pics up once its installed. THANK YOU ELKOR!! the link to the product:
http://www.crutchfield.com/cgi-bin/S-hTR6zQ42p1S/ProdView.asp?s=0&c=11&g=745&I=0733R8X5&o=m&a=0
WHELP! As if you knew what an eternity was. Grovel before your true master!
darkmanx
Re: trackball ring: update
« Reply #1 on: April 03, 2002, 09:06:16 pm »
also, i finally plugged in the trackball today. it seems newer crystal trackballs have the lighting color reversed. the ball is lit green by default, and turns red on a button click. i havent changed anything on the unit, thats how it came.
Elkor
  • Last login:February 12, 2007, 12:42:50 pm
  • What did I just say?
    • Full Circuit
« Reply #2 on: April 04, 2002, 09:37:26 am »
glad I could help dude.
-C
The sudden sight of me causes panic in the streets. They have yet to learn
-- only the savage fears what he does not understand.
                -- The Silver Surfer
Jonathan_the_Red
  • Last login:Never
  • Cab-buildin' fool
    • Jonathan's Cab-in-progress
« Reply #3 on: April 04, 2002, 11:35:29 am »
FYI, my Crystal Trackball has those lighting colors as well... green when no button pressed, red with button pressed. I don't like it. The green is kind of sickly and pale, the red is nice and bright. I might reverse the colors, or just supply my own LEDs.
