Author Topic: WTB: Compact Flash ribbon cable. Will pay bounty if anyone can find one.  (Read 3408 times)
ften
  • Last login:March 06, 2022, 10:20:43 pm
  • Beep Beep
    • Fathertom.net
I basically want a 50pin female to 50pin female ribbon cable that will fit into a Compact Flash / Micro-Drive slot. Kind of like an IDE cable, but for the CF-I or CF-II standards. I know I can't be the only person who thought to himself "Man I would like easier access to this Compact flash adapter." The first person who finds me a site that I can buy the cable off of I will PayPal or MoneyOrder 20 bucks.
I've searched Google, Allelectronics, Digikey, etc and still nothing. At this point I'm not even sure they make such a thing.  :banghead:
Rules on bounty;
I don't want a Developer Compact Flash Extender (like with a PCB board) as they are generally "bulky", won't work with my project and are ridiculously expensive.
I don't want anything that is like 100 dollars, just a cheap ribbon "IDE like" cable.
Thanks,
FTen
2600
Re: WTB: Compact Flash ribbon cable. Will pay bounty if anyone can find one.
« Reply #1 on: October 25, 2006, 07:59:07 pm »
Curious, What is this for? PC or something else?
Witchboard
« Reply #2 on: October 25, 2006, 10:27:01 pm »
You mean like this? <---- link
If so, you can keep the $20.
Oops, you said 50 pin.  These are the cables I used for my compact flash adapters, they are for 2.5" laptop connections.  Maybe the same site will still have what you're looking for.
« Last Edit: October 25, 2006, 10:28:36 pm by Witchboard »
tyroneshu
  • Last login:January 01, 2008, 11:21:22 pm
  • Currently building my first Cabniet!
« Reply #3 on: October 25, 2006, 11:49:00 pm »
What does this look like?  Can you use regular 50 pin scsi Cables?
ften
  • Beep Beep
    • Fathertom.net
« Reply #4 on: October 26, 2006, 12:33:40 am »
Well I want the cable to connect directly into a male CF port, so a SCSI cable wouldn't work.
I've actually de-solder a compact flash card and started re-soldering the CF female connector to a standard 80pin  IDE cable, but the leads on the connector are so small and fragile it's a ---smurfette--- to do.  If I can't find a cable I guess I'll just finish solder that, but the cable will wind up being pretty fragile.
I looked over that site Witchboard, doesn't have what I need. Thanks for the link though.
I'm planning on using the cable with my Nintendo DS.
Thank you,
-FTen.
werejag
  • Last login:July 06, 2018, 05:16:51 am
« Reply #5 on: October 26, 2006, 12:35:45 am »
i have been looking and the best bet is to get 1 compact flash conector , a ribbon cable and a female compact flash connetor. solder it together. seems simple enough. can you tell us why this weird req . so we can find best solution?
gloop stick the ends to make this less fragile
« Last Edit: October 26, 2006, 12:42:56 am by werejag »
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
ften
  • Beep Beep
    • Fathertom.net
« Reply #7 on: October 26, 2006, 01:30:18 am »
I was planing on using it with a PCB board I made to do a Compact Flash to Toshiba 1.8" HD conversion. The board itself will use a male CF connector.
Spaz Monkey: I think that link is to a proprietary 50pin cable, I'm looking for something that would directly plug into a male 50pin CF port.
Think this but with out all the extra crap;
http://www.sycard.com/cfext180.html
Worse comes to worse, I'll just make the cable myself.
-FTen
