Author Topic: TMNT control panel layout template and keywiz 4 player "how to"  (Read 9348 times)
spystyle
« on: October 17, 2006, 08:35:09 am »
Hello from Maine,
Attached is the control panel layout for TMNT 4 player, 1 square = 1 inch. This can be used on the Simpsons, TMNT, Bucky O'Hare, and probably more. I built the Bucky O'Hare and am using the attached layout and the following KeyWiz formula.
I have figured out how to use a 32 input keywiz for 4 players :
stick 1 uses 4 inputs + 3 buttons
stick 2 uses 4 inputs + 3 buttons
stick 3 uses 4 inputs + 3 buttons
stick 4 uess 4 inputs + 3 buttons
= 28 inputs +
enter, esc, tab, coin = 32 inputs total :)
note : player's 2nd button must double as that player's "start" (in MAME's input configuration)
note : "coin" button must quadrupel as "p1 p2 p3 p4 coin" (in MAME's input configuration)
Cheers,
Craig
« Last Edit: October 18, 2006, 10:47:19 pm by spystyle »
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
spystyle
Re: Does anyone have the Simpson's 4 player CP layout measurements?
« Reply #2 on: October 17, 2006, 05:10:30 pm »
*sigh*
JakoBud's plan does not include the control panel layout, see the attachment
johnm160
  • Last login:April 09, 2024, 09:00:46 pm
« Reply #3 on: October 17, 2006, 08:03:36 pm »
It looks similar to this but the two center sticks on the simpsons are closer to the front.
I am not sure if these measurements would help you out or not.
spystyle
« Reply #4 on: October 17, 2006, 08:31:56 pm »
Thank you very much, they would do much better than what I have right now!
If I can't track down Simpsons measurements I could alter these
Also, after you submit them I will put them in the "CP layout repository" (I don't know if one exists, but if it doesn't I will open one)
Cheers :)
Craig
« Last Edit: October 18, 2006, 08:19:50 am by spystyle »
johnm160
« Reply #5 on: October 17, 2006, 10:06:35 pm »
Also, after you submit them I will put them in the "CP depository" (I don't know if one exists, but if it doesn't I will open one)
Cheers :)
Craig
Well mine currently looks like this:
But the original NBA Jam holes are still under it. I will work on it tomorrow It will be a little tough to get a really accurate measurement with all the controls still in it, but I will get it as close as I can.
Any time my friend, Your CD has helped me a bunch.
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
« Reply #6 on: October 18, 2006, 07:52:08 pm »
Was the Konami cab for TMNT the same button size/layout as The Simpsons?  If so, then this should help:
http://www.classicarcadegrafix.com/sunshop/index.php/action/item/id/45/prevaction/category/previd/1/prevstart/0/
Once resized you can get a better idea of joy/button placement...except you're adding third buttons.  All the The Simpsons I played on had only two buttons per player and required simultaneous button presses for the combos...
spystyle
« Reply #7 on: October 18, 2006, 08:15:57 pm »
Hooray!
Thank you :)
That will work fine. Actually I was planning on using 3 buttons anyway. I guess I should stop calling it a Simpsons and start calling it a TMNT
Cheers,
Craig
