Author Topic: Wiring Coin Door Lights. Need connectors possibly?  (Read 1850 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: October 14, 2006, 12:21:15 pm »
I have the over/under mini door system from Happ.  I was wondering.  I am using the Molex Connector method with some wire connectors.  Those twist on style like you see with a ceiling fan or over head ceiling lights.  I was needing to know though.....On the bulbs themselves.  The ones that come from happ.  Is there a way/connector to use to connect the wire to the bulb.  I have seen in some pictures an insulated style connector.  Could you use like a female quick disconnect connector or something like that.  I really don't want to solder wire to the bulb.
Aurich
  • Last login:September 12, 2021, 01:34:32 am
Re: Wiring Coin Door Lights. Need connectors possibly?
« Reply #1 on: October 14, 2006, 12:51:32 pm »
To the bulb itself? Or the socket the bulb goes into? Quick disconnects should be just fine on the socket tabs, hopefully that's what you mean. :)
fatfingers
  • Got UltraStiks?™
« Reply #2 on: October 14, 2006, 03:33:28 pm »
Quick disconnects is what I used.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
rdowdy95
  • This is my rifle.
« Reply #3 on: October 14, 2006, 04:25:36 pm »
Thanks guys that was what I was thinking.  I have the .187 kind and the .25 kind so I will just see what fits better.
fatfingers
  • Got UltraStiks?™
« Reply #4 on: October 14, 2006, 04:51:31 pm »
Mine were very small --- .100 I think?  I know I had to make a special run for new quick disconnects.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #5 on: October 28, 2006, 02:58:12 am »
42-0351-00 Lamp Holder
From Happ ask Ponyboy. That's where I got mine.
These are sweet and use a standard 161 bulb which is 12v. These bulbs can easily be picked up at an auto parts store.
My old user name was marlborroman13, but I kicked the habit many years ago!
