Author Topic: Help with rewiring Sony 20" with 13W3 cable  (Read 1802 times)
diverdown
  • Last login:April 21, 2025, 03:45:48 am
« on: October 05, 2006, 08:20:59 pm »
I recently acquired a HP A4331a monitor. The RGB cable was severed and I dint have the end of it. All I had was a pigs tail bit sticking out the back of the monitor.
I have decased the tube and disconnected the wire from the chassis.
It appears to have been a 13w3 cable. below
 I would love to turn it back into a standard cable. I would settle for being able to return it to a 13w3 and then buy an adapter.
How easy would this be?
I can solder and follow directions, but as i dint know which colour wires mean what is it just too hard. i can get the RGB and grounds but there a re a few red brown white wires i am not to sure about.
If it ain't broke give it to me...i'll soon fix that
StephenH
Re: Help with rewiring Sony 20" with 13W3 cable
« Reply #1 on: October 08, 2006, 02:21:42 pm »
This page has 13W3 to VGA cables and adapters
http://www.monitorworld.com/cables_home.html
diverdown
« Reply #2 on: November 01, 2006, 10:58:50 pm »
Did it using some info on the web...... turned the moitor on...............it worked but the pic was way too dark, everything seemed to be fine with what I had done............
Problem easily solved.........I threw the monitor away
