Author Topic: When I Start Wincab I get this  (Read 10336 times)
billblumjr
  • Last login:March 29, 2010, 12:07:17 am
« on: October 04, 2006, 11:43:46 pm »
It states this in an error style box "unable to install sound driver" and it stops and won't continue.. I searched here for an answer and can't find anything
I am running WinXp with SP 2 my sound card is SB PCI 512 and I am running DirectX 9.0c... help..
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: When I Start Wincab I get this
« Reply #1 on: October 04, 2006, 11:52:20 pm »
Odd... never seen that in Windows, only in DOS....
You should now have a jbdebug.log file... can you post it?
--Chris
--Chris
Kevin Mullins
    • Me on Myspace
« Reply #2 on: October 05, 2006, 12:00:39 am »
I saw that same error once in Windows when I had forgotten that it was already running in the background and tried to start it again. (just thought I'd throw that out there)
billblumjr
« Reply #3 on: October 05, 2006, 04:19:38 am »
Here is the log file
0:00:00.00-LVL0-DEBUGLOG_INIT: WinCab Jukebox 3.1.1 (Sep 13 2006 build) Critical Log Started
0:00:00.00-LVL0-DEBUGLOG_INIT: Debug log detail level: 0
0:00:00.00-LVL0-DEBUGLOG_INIT: *****************************************************
0:00:00.00-LVL0-DEBUGLOG_INIT: SYSTEM INFORMATION:
0:00:00.00-LVL0-DEBUGLOG_INIT: Library version: Allegro 4.2.0, MSVC
0:00:00.00-LVL0-DEBUGLOG_INIT: CPU Vendor: AuthenticAMD
0:00:00.00-LVL0-DEBUGLOG_INIT: MAX_PATH: 260
0:00:00.00-LVL0-MAIN: *** Error initializing sound driver.
0:00:00.00-LVL0-MAIN: Error message: Failed to init MIDI music driver
Chris
  • Moderator
« Reply #4 on: October 05, 2006, 08:09:22 am »
Hmm.  MIDI failure, and odds are you don't even need MIDI.
Try adding the following to the end if your jukebox.ini file:
Code: [Select]
[sound]
midi_card=0
Does that help, or does it just change the error message in the log?
--Chris
--Chris
billblumjr
« Reply #5 on: October 05, 2006, 11:10:33 am »
Ok it started up ok that time.. it said I had a fatal error.. no songs in pathline.. so I am gonna redo that and see what happens.. otherwise.. it works
Chris
  • Moderator
« Reply #6 on: October 05, 2006, 11:17:23 am »
Everyone sees that one the first time... I really need to make it prompt for a path rather than error out.
--Chris
billblumjr
« Reply #7 on: October 05, 2006, 11:18:12 am »
No prob.. put the path in.. and now it works.. thanks
blicky
  • Last login:August 08, 2011, 06:57:02 pm
« Reply #8 on: June 15, 2008, 05:58:51 am »
Hi just found this old post and I have a similar problem (never really worried too much because Doscab works fine in a full screen dos box anyway). The sound card works in windows and in dos but Wincab throws almost the same error.
0:00:00.00-LVL1-DEBUGLOG_INIT: DWJukebox for Windows Ver. 3.1.5 (Jan 20 2008 build) Started
0:00:00.00-LVL5-DEBUGLOG_INIT: Debug log detail level: 5
0:00:00.00-LVL5-DEBUGLOG_INIT: *****************************************************
0:00:00.00-LVL5-DEBUGLOG_INIT: SYSTEM INFORMATION:
0:00:00.00-LVL5-DEBUGLOG_INIT: OS version: 4.10
0:00:00.00-LVL5-DEBUGLOG_INIT: Library version: Allegro 4.2.0, MSVC
0:00:00.00-LVL5-DEBUGLOG_INIT: CPU Vendor: GenuineIntel
0:00:00.00-LVL5-DEBUGLOG_INIT: MAX_PATH: 260
0:00:00.00-LVL1-MAIN: Using initialization file: jukebox.ini
0:00:00.00-LVL2-MAIN: Initializing sound driver...
0:00:00.00-LVL0-MAIN: Error message: Failed to init digital sound driver
Chris
  • Moderator
« Reply #9 on: June 22, 2008, 11:36:10 pm »
I wonder if something else is using the driver at the time the jukebox is starting up.  Do you have more than one sound card in your machine?
--Chris
