Author Topic: Fixing clearcoat damage  (Read 3647 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« on: September 24, 2006, 05:06:05 pm »
Is there anyway to repair bubbling of the clearcoat on a car without sanding all the paint off and starting anew. This is related to yet another car I'm looking at.
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Re: Fixing clearcoat damage
« Reply #1 on: September 24, 2006, 07:24:33 pm »
Gorilla Glue.  Clamp those bubbles right back down.
NightGod
« Reply #2 on: September 25, 2006, 05:30:43 am »
No.
shardian
« Reply #3 on: September 25, 2006, 09:03:17 am »
Stingray
« Reply #4 on: September 25, 2006, 11:24:09 am »
Color sanding won't work if the damage is all the way through the clear or if the clear has started to peel. Just FYI.
-S
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #5 on: September 27, 2006, 12:28:24 pm »
Sand down the bubbles using 400 grit paper. Blend the edges of the clear into the paint but not through it. (this is the trick - use very, very light pressure on your paper) Respray your clear over the sanded portions. Sand with 1000 grit paper, repeat this for two or 3 coats. Finish up with polishing compound. Voila.
I restore vintage bicycles as a hobby and do this kind of repair all the time. You can sand and blend paint and clearcoat just like any other material. It's not all that hard, it just takes a little nerve to do it for the first time.
If you build a frankenpanel, chances are I don't care for you as a person.
Brax
« Reply #6 on: September 27, 2006, 12:31:59 pm »
-S
Colour sanding uses the exact same methods you would use to repair your clearcoat. You just have a few added steps of respraying your clear afterwards. It's not exactly a big leap to go from colour sanding to clearcoat repair.
Stingray
« Reply #7 on: September 27, 2006, 12:55:28 pm »
-S
Yes I'm aware of that. I've been doing auto body work for 20 years. Unless I completely misread, the OP isn't looking to do any paint work. An attempt at color sanding an area where the clear is damaged all the way through would only make the problem worse. In any case if a person doesn't own the needed paint spraying equipment (and let's face it, not a lot of people do), it's a bit more than a few added steps.
-S
« Reply #8 on: September 27, 2006, 01:02:19 pm »
And boy is he tired.  What a project.
Brax
« Reply #9 on: September 27, 2006, 03:40:49 pm »
-S
It can be done with rattle cans and it won't look any different. (premptive strike: Yes, you're right. It won't be as durable. But if it's like any clearcoat bubbles I've ever seen, it'll be on a horizontal surface. Unless you regularily have  swimsuit models cavorting on your car, it'll be fine. Btw, if you do have said models squirming on your car, call me! In my opinion, it would be fine regardless where the repair is. I've done bike frames and they don't scratch any worse than a factory finish.))
As I said, the method is the same as colour sanding. It's not colour sanding per se. As long as you're careful not to go through the colour as you're blending the edges of the clear into the paint all will be fine.
There are methods the professionals use and then there are hobbyist methods that achieve the same goal. He asked if it could be done. I assure you with 100% certainty that it CAN be done and you'd never know it was repaired.
Stingray
« Reply #10 on: September 27, 2006, 03:51:31 pm »
That might be okay for a bicycle, but not for a car. Not my car anyway.
-S
shardian
« Reply #11 on: September 27, 2006, 04:19:39 pm »
The spoiler on my car is clear coated, and the clearcoat is poppin off all over the place. the exposed maroon paint looks dull, but is in tact. So, you are saying I can scrap the bubbling clear coat lightly, then feather the clearcoat down to make a smooth transisiton from existing CC to paint. Then extremely lightly sand everthing to achieve a color blend. Then recoat everything with CC and polish like a mad man. Is this correct? I could care less if it doesn't work. It is worth a shot. If it fails then I can just sand and repaint the whole thing.
You all and your conflicting info.  ;) ;D
« Reply #12 on: September 27, 2006, 04:53:52 pm »
DrewKaree
  • HAH! Nice one!
« Reply #13 on: September 27, 2006, 10:32:48 pm »
The spoiler on my car....
If it's something you bolted on because it's teh kewl, go ahead and give bicycleboy's advice a shot.  A bolt-on spoiler would have already ruined any car, and if that's the case, even that bicycle advice would be an improvement.
Say, are they still painting vintage bikes with catalyzed polyurethane?  That'd be great if they were, so we'd know that rattle-can enamel would definitely work, instead of guesstimating.....what kinda primer do you use to make those two dissimilar products work well together?
USS, you've moved on to another car by now, right?  Or is all this jibber-jabber helping you decide?
boykster
  • The cake is a lie!
« Reply #14 on: September 28, 2006, 01:46:32 am »
I'm still thinkin this is the best route to go...
shardian
« Reply #15 on: September 28, 2006, 08:16:14 am »
If it's something you bolted on because it's teh kewl, go ahead and give bicycleboy's advice a shot. [/quote]
No, I am proud to say I have never bolted on one of those tin can spoilers on ANY of my cars...although I was sorely tempted in HS. ;D I have also never put a "weed-eater" muffler on any cars either. I don't know why some kids think that a car that sounds like an eternal fart is a good thing. :laugh2:
It is the stock spoiler just like the one in the pictures of the link I provided.
« Reply #16 on: September 28, 2006, 08:33:52 am »
The best is when a weed eater muffler backfires because the car barely runs.  It's like a loaf of bread breaking the sound barrier.
Brax
« Reply #17 on: September 28, 2006, 10:04:10 am »
It won't even take that much polishing. I'd use 2 or 3 layers of clear minimum, sanding with 1000 grit between each layer and then finishing up with the polishing compound. I did the same repair on the roof of my Daytona and it worked fine. Once you spray your clear, you'll get a rough dust like finish between the new clear and the existing clear. The polishing compound will remove that when you apply it. You're essentially blending the new clear into the existing clear.
To the naysayers: Gee, what a miracle if it works because nobody on the planet has ever made a clearcoat repair before.  ::)
« Reply #18 on: September 28, 2006, 10:05:04 am »
Just put duct tape on it.
Brax
« Reply #19 on: September 28, 2006, 10:44:44 am »
The most exotic paint I've come across to date is a two-stage Dupont Imron. I usually use an enamel for repairs. (enamel also comes in the pearl colours some european frame manufacturers use.) I restore steel lugged frames so dissimilar paints aren't an issue since I can sand down to bare metal between the lugs, use an etching primer, enamel colour coat and then the clear.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #20 on: September 29, 2006, 02:28:55 am »
Clear nail polish.  Comes with it's own brush.
DrewKaree
  • HAH! Nice one!
« Reply #21 on: September 29, 2006, 09:52:23 pm »
I bet you didn't have to tell him about the brush part.  Nancy.
Brax
« Reply #22 on: September 29, 2006, 11:28:24 pm »
An AIRbrush is used for clearcoat repairs; the supplied paintbrush is for my pretty toenails. Everyone knows this. Especially this crowd. Buncha freaks.  :-*
...it puts the lotion in the basket.
« Last Edit: September 29, 2006, 11:31:37 pm by Brax »
USSEnterprise
    • USS Odyssey
« Reply #23 on: September 30, 2006, 07:31:47 am »
I'm going to go see the volvo 850 in a few minutes. I'm going to play with all her knobs and buttons. :angel:
USSEnterprise
    • USS Odyssey
« Reply #24 on: September 30, 2006, 07:32:50 am »
oops, wrong thread
DrewKaree
  • HAH! Nice one!
« Reply #25 on: September 30, 2006, 11:22:18 am »
oops, wrong thread
You think it's any easier for US to keep up with? :dizzy: :laugh2:
USSEnterprise
    • USS Odyssey
« Reply #26 on: September 30, 2006, 11:31:02 am »
valid point
psik0tik
  • Last login:March 09, 2008, 11:32:31 pm
  • Bah Bah Bah
« Reply #27 on: October 11, 2006, 12:32:29 am »
Imron is a single stage paint...2 stage would be basecoast clearcoat...sorry I own a body shop had to put my input in...and if imron 5.0 is the most exotic then you have been out of the loop forever :)
Going to Mcdonalds for a salad is like going to a crack house for vitamins.
