Author Topic: How much is this worth?  (Read 1134 times)
struby
  • Last login:April 23, 2007, 08:42:05 pm
« on: September 17, 2006, 11:50:25 am »
I have a cab that i built and I was going to make a mame machine out of i, but I got off task and don't know if I want to take the cab approach anymore and I could use some money, I am In southeastern PA.
It is a 3/4 inch plywood cab with a monitor shelf with a slant...I am not sure of degree, maybe 12 degrees or something, it has a toe room slot on the bottom I didn't put a back on it because i figured it would be easier to make, get into, and it would be against a wall.  It also has a bottom shelf and two more shelves inside, one high enough for acomputer, the front is strait, I wasn't planning on bulding in a cp, i was gonna make it seperate, so there is no slant for a cp.  I put on one layer of primer white on it.  It is sturdy, and I'll post up some pictures if anyone shows interrest, it is well made and the dimensions are:
79 inches high
28 inches wide
26 inches deep
motorfish
  • Last login:September 30, 2009, 03:35:08 am
Re: How much is this worth?
« Reply #1 on: September 17, 2006, 12:00:29 pm »
Really difficult to tell without at least a picture.
Have you paid your dues Jack?......Yessir, the check is in the mail!
struby
« Reply #2 on: September 17, 2006, 12:32:04 pm »
Alright well i should have a camera tonight, I'll either make a new post or post them in here then, thx.
srabelpawz
  • Last login:May 16, 2010, 11:07:44 am
« Reply #3 on: September 19, 2006, 05:43:54 am »
 pm me when you post a pic since i don't come to this site that often. i'm in southeast pa and am interested
