Author Topic: 720 Degrees.  (Read 4066 times)
Witchboard
720 Degrees.
« on: September 04, 2006, 10:54:46 pm »
I've recently got my hands on one of these and was wondering if anybody knows a source for a couple of parts.
Was the monitor bezel paper or plastic in these?  I don't know, because mines gone.  :dizzy:  Also, there's some odd t-molding that goes across the bottom of the monitor area with a notch in it to hold the glass.  Mine has cracked off at the base of the slot part.  Looking to get some more so I can get the glass back in, which I do have.  Also would like a replacement dust washer.  I'm not holding my breath on any of the parts, especially the t-molding.  It doesn't even have a part number for it in the manual.  Any pointers out there?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: 720 Degrees.
« Reply #1 on: September 05, 2006, 02:36:46 pm »
I'm surprised the t-molding doesnt have a part number. Atari usually itemized EVERYTHING in the manual.
Atari normally used cardboard bezels. I can't say for sure, but chances are 720 had a cardboard one as well.
« Last Edit: September 05, 2006, 02:40:18 pm by RayB »
NO MORE!!
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: 720 Degrees.
« Reply #2 on: September 05, 2006, 09:12:20 pm »
If you find more than one dustwasher, I'm looking for one, too.
Witchboard
Re: 720 Degrees.
« Reply #3 on: September 05, 2006, 10:18:52 pm »
Will do, I'll keep an eye out for you Kremmit.
Steve
  • Trade Count: (-2)
  • Last login:June 24, 2009, 06:18:34 pm
Re: 720 Degrees.
« Reply #4 on: September 06, 2006, 12:00:03 am »
Unsure if this link will help you any: http://www.geocities.com/civitat/720/720-Home.html
My 720 has a paper/cardboard bezel.
The 80's is what it's all about.....
Witchboard
Re: 720 Degrees.
« Reply #5 on: September 06, 2006, 08:34:39 am »
Cool deal.  Is your glass smoked?
Glaine
  • Last login:April 24, 2013, 12:09:17 pm
Re: 720 Degrees.
« Reply #6 on: September 08, 2006, 10:04:32 am »
I'm confused. Your cab uses a joystick. I thought 720 used a big trackball?
RayB
  • There's my post
    • RayB.com
Re: 720 Degrees.
« Reply #7 on: September 08, 2006, 10:07:27 am »
Nope.
Joystick handle mounted at an angle on a spinner with 2 encoder wheels.
NO MORE!!
Witchboard
Re: 720 Degrees.
« Reply #8 on: September 08, 2006, 12:37:44 pm »
Yeah, I think it's referred to as a chain joystick, since it does have a little bicycle chain that goes to the encoder wheel.
Steve
  • Trade Count: (-2)
Re: 720 Degrees.
« Reply #9 on: September 09, 2006, 06:28:42 pm »
Yep the joystick rotates and does indeed use a chain (I'll see if I can find/take some pics if needed)
The glass on mine is clear and not smoked.
The link I posted is not mine, but helped me restore 2 cabs I had (sold one)
Keep us updated  :)
Steve
Witchboard
Re: 720 Degrees.
« Reply #10 on: September 09, 2006, 10:39:19 pm »
Thanks for clarifying the glass.  All the pictures I've seen also seem to show clear glass vs. smoked.  I guess it's possible that since my glass-retaining t-molding is broken, the original glass may have been broken and replaced with this.
Steve
  • Trade Count: (-2)
Re: 720 Degrees.
« Reply #11 on: September 10, 2006, 12:11:55 am »
I've never seen a 720 with smoked glass (out of about the 10 or so I've seen in person)
The sides, I've seen gray and red
Witchboard
Re: 720 Degrees.
« Reply #12 on: September 10, 2006, 01:57:41 am »
Mine has the gray sides.  Looks like I'll be getting some glass cut as well.
Wade
  • Last login:December 01, 2025, 08:21:17 am
  • 80's Child
    • Wade's Gameroom
Re: 720 Degrees.
« Reply #13 on: September 15, 2006, 10:33:17 pm »
720's were actually what I call "silver".  It looks like grey in photos, but it has a metallic look to it and the color changes a bit depending on the angle you look at it.  Most of them I've seen have been repainted a plain grey though.  I have one in line to restore, but I really don't know what I'm going to do to match that color.  I wanted to just laminate it gray but since discovering it is metallic, I haven't been able to find a match.
Wade
NightGod
Re: 720 Degrees.
« Reply #14 on: September 15, 2006, 11:20:57 pm »
Go to a Menard's and check out the Dutch Boy Dimensions Metallic paint. hey should be able to get a good match for you using that stuff.
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
Re: 720 Degrees.
« Reply #15 on: September 22, 2006, 08:39:09 pm »
My friend's 720 is smoked tempered glass. Same with the one at the University here in town. Just so you know there are some
Witchboard
Re: 720 Degrees.
« Reply #16 on: September 24, 2006, 10:24:43 am »
Thanks.  :cheers:
mongeau16
  • Last login:March 05, 2007, 03:39:19 am
Re: 720 Degrees.
« Reply #17 on: September 25, 2006, 03:10:54 pm »
my 720 had black sides when i got it so i just went with the solid greay sides too.  clear glass as well. i think mine plays weird too. are you suppose to get 3 lives at the start of each game? heres the pics of mine when i got it and now.
Witchboard
Re: 720 Degrees.
« Reply #18 on: September 25, 2006, 10:13:07 pm »
You can setup the different options through dip switches on the board.  If you're needing a manual you can get one here.  Lookin' good on the 720 restoration.
mongeau16
Re: 720 Degrees.
« Reply #19 on: September 26, 2006, 02:29:39 am »
thanks so much for that. i know now that mine was set on all the most difficult settings. guess im way better at it for that. :) i didnt know much about the board when i bought it. all i did was cleanup the inside since it worked fine.  i pretty much replaced everything on the outside except the buttons and the coin door(which i repainted.) the only thing mine is missing is the black ring that goes between the joystick and the control panel.
Kremmit
  • - AHOTW -
Re: 720 Degrees.
« Reply #20 on: September 27, 2006, 01:08:15 am »
What is it about those dang things, anyway?  That's three missing ones in this thread alone.
mongeau16
Re: 720 Degrees.
« Reply #21 on: September 27, 2006, 02:12:34 am »
mine is still technically there, but someone cut the edges of it so the opening is as big as the hole for the joystick.  it seems like there should be some sort of easy fix for that. but i see cheap complete control panels on ebay all the time. ill probably just get one of those. might be worth the spare parts
Witchboard
Re: 720 Degrees.
« Reply #22 on: September 27, 2006, 08:08:19 am »
Same here.  That's how mine is.
