Author Topic: Mini-PAC USB / PS/2 Question  (Read 994 times)
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
« on: September 01, 2006, 06:49:56 am »
I just purchased a Mini-PAC with the USB cable and realized that I would rather hook it up via the PS/2 port (motherboard has some weird USB issues).  Can I simply buy a USB to PS/2 converter plug to hook it up or do I need the special PS/2 cable from Ultimarc?
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: Mini-PAC USB / PS/2 Question
« Reply #1 on: September 01, 2006, 09:18:57 am »
All you need is a standard male-to-male PS/2 cable as sold for use with switch boxes etc. Note trackball/spinner are not supported in PS/2 mode.
Andy
ChicagoDave
    • Dave's Website
« Reply #2 on: September 01, 2006, 09:22:59 am »
Andy
Thanks Andy!  Do you think the converter I mentioned above would also work?
Homer Simpson:
AndyWarne
    • Ultimarc
« Reply #3 on: September 02, 2006, 07:44:38 am »
If the converter is a simple plug adaptor it will work. Any kind of active converter with circuitry in a module will not work properly.
Andy
