Author Topic: Standard menu/command buttons  (Read 1433 times)
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
« on: August 25, 2006, 03:38:19 pm »
Before I drill too many holes I'm curious what the basic command buttons should be, besides the coin buttons, pause, exit. Mine are hidden on the backside of a panel, but I probably have space for 3 on each side.
shbon
  • Last login:November 29, 2024, 12:54:46 pm
Re: Standard menu/command buttons
« Reply #1 on: August 25, 2006, 03:57:12 pm »
I did pretty much what you've said. I have three small momentary switches on the underside of the CP. These do PAUSE/COIN1/ESCAPE. Via my IPAC the shifted functions are SNAP/COIN2/RESET
I did it this way so as not to have extra buttons showing that wouldn't be on a real cabinet, but also to have the convenience of straight forward one hit buttons for coin / pause / escape.
Any other command buttons (E.g. F2/F11) I've put on shifted buttons on the CP itself.
Seems to give the best of all worlds!
Shaun
severdhed
  • RIP Dinosaur Hippo
« Reply #2 on: August 26, 2006, 10:45:06 am »
i have four.  Esc, Enter, Tab, and Pause.  enter, while not really needed for mame, comes in handy for some other emulators, and navigating windows
Dreamwriter
  • Last login:August 28, 2010, 04:33:09 pm
  • Sleep is for the weak!
    • Games of Yore
« Reply #3 on: August 26, 2006, 11:08:42 am »
I only have two extra buttons on mine - an Exit button (for backing out of MAME menus and MAME itself, same button that starts the games in my front end) and a Menu button (same as Tab).  You can program Mame to use joystick and a normal game button to navigate Mame's menus and make changes once you are in the menu.  I figure if I ever need to actually exit entirely out to Windows, I'll hook up a real keyboard.
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« Reply #4 on: August 26, 2006, 12:10:04 pm »
I don't have a lot of extra space, so I rely completely on the IPAC shifted functions. Only esc. is noted on my CPO.
Make your cabinet look its best with custom art from
Gamecreature!
