Author Topic: Mala and video requirements  (Read 3898 times)
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
« on: August 19, 2006, 03:03:55 am »
My Mala gamelist (up-down scrolling) is not responding while my video-previews are on in Mala RC7a.   I updated DIVX codecs, updated DirectX, moved video up and down in the layout's Z-buffer, changed video size, and many other tweaks with no success.  Any ideas?
I used video previews before without problems, but have reinstalled XP and a new version of MaLa so many things could have changed.
My MAME cabinet is a 1.5GHz w/256MB ram.   My other computer (2.8GHZ/1GB) is scrolling with the vids on in Mala fine however.  Could it really be a CPU/ram issue  ???  I had vids working fine on the MAME machine before so I'm thinking something changed (meaning I probably broke something)  hmmm
loadman
  • Moderator
    • MaLa
Re: Mala and video requirements
« Reply #1 on: August 19, 2006, 03:56:50 am »
Can you play the Vids using Windows Media Player?
Can you play a vid as a MaLa startup vid? (found in options/gui/start)
CM
« Reply #2 on: August 19, 2006, 10:34:11 am »
The AVI files play in Windows media player.  They also play in Mala, but the keyboard becomes unresponsive while they are going.  The right-click mouse menu still comes right up though.
The startup vid option is not there.  The help tab shows Version 1.0 RC7 [1.0.1.211]
Angry_Radish
  • Last login:October 24, 2020, 06:36:17 pm
« Reply #3 on: August 19, 2006, 01:02:01 pm »
I had the same problem with the vids, installing ffdshow solved it for me.
Worth a shot....
loadman
  • Moderator
    • MaLa
« Reply #4 on: August 19, 2006, 06:33:29 pm »
If you get the update you can play vids on start-up (1.0 RC7a)
At a guess you have dowloaded RC7 but not the update part to make it RC7a
Refer Here
Its just a new mala.exe and malaylayout.exe. Simply download and replace these two files you have.
[EDIT] I just loaded MaLa on a slower PC I have 1.5g  and all works fine so I doubt it's a MaLa issue   :P
« Last Edit: August 19, 2006, 06:42:33 pm by loadman »
