Author Topic: Cocktail are you kidding me? Monitor Moutning question  (Read 2246 times)
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
« on: August 12, 2006, 04:16:59 pm »
did they really make cabinets like this?  The monitor needs to be mounted to the ...bezel?  the glass/wood part..and then be lowered straight down into the cabinet?
attached pics will hopefully make sense.  Seems like most cocktails I've seen have the monitor on hinges.
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
pointdablame
  • Last login:August 04, 2025, 06:16:22 pm
Re: Cocktail are you kidding me? Monitor Moutning question
« Reply #1 on: August 13, 2006, 12:58:17 am »
yup, quite a few cocktails were like that.
first off your and idiot
  • Last login:Today at 02:12:14 pm
« Reply #2 on: August 13, 2006, 11:42:54 am »
Ahh, the cocktail monitor mount... the bane of my arcade project.  I can't believe that they used to mount to the bezel... if that's the case, my worry level just went down by a factor of 10.  I bolted mine to the hinged door and tabletop - 4 bolts in each.  I recommend you do the same, if possible.
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
« Reply #3 on: August 13, 2006, 02:42:58 pm »
I recently looked at a SI cocktail, and it had the monitor mounted to the bezel.
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
Kevin Mullins
    • Me on Myspace
« Reply #4 on: August 13, 2006, 04:52:33 pm »
Mine is mounted down in the cab itself. (cocktail)
When you lift the top the monitor stays down inside.
Kinda like this one:
http://coinop.org/kk/si/screen.jpg
« Last Edit: August 13, 2006, 04:55:35 pm by Kevin Mullins »
Sizzler
  • Last login:January 25, 2008, 12:28:46 am
« Reply #5 on: August 13, 2006, 05:12:47 pm »
It's Midway SI vs Taito SI
Click for pic
Kevin Mullins
    • Me on Myspace
« Reply #6 on: August 13, 2006, 07:31:17 pm »
Ahhh... very true.
I didn't even think about that.
Mine is a Taito version.
