Author Topic: need spyhunter yoke gear info  (Read 1750 times)
KonkeyKong
  • Last login:October 10, 2021, 09:57:07 pm
  • Monkey is my business and business is good.
« on: August 05, 2006, 09:03:32 pm »
more specifically info on the small gear that turns the pot.  Diameter? Tooth count? Any place that might have them available?
« Last Edit: August 11, 2006, 09:04:06 pm by KonkeyKong »
Izrun
  • Last login:February 06, 2010, 10:32:20 am
    • izrun.com
Re: need spyhunter yoke info
« Reply #1 on: August 07, 2006, 12:23:08 pm »
I'll try to take a look at this when I get home today.  I just happened to disasemble my spy hunter control panel yesterday, so it should be accessable.
--Izrun
"There are 10 types of people in the world. Those that use binary and those that don't."
KonkeyKong
« Reply #2 on: August 07, 2006, 12:39:21 pm »
If you could get a picture or two that would be great since I'm thinking I'm really gonna have to hunt for this gear it would be nice to be able to show people what I'm looking for.
Izrun
    • izrun.com
« Reply #3 on: August 07, 2006, 02:59:28 pm »
No problem!
--Izrun
Izrun
    • izrun.com
« Reply #4 on: August 07, 2006, 07:06:10 pm »
Here we go.  This is the best I could do.  Dimensions are on the pictures.  I got to use my new caliper, so that's pretty cool.  ;D
There are 42 teeth.
Total Height: 0.495"
Teeth Height: 0.125"
Diameter: 1.375" (including teeth)
Center Diameter: 0.250"
Center Cylider width: 0.157"
Teeth Height: .075" (best estimate)
I think this should suffice, but if you need anything else let me know.
--Izrun
KonkeyKong
« Reply #5 on: August 07, 2006, 07:15:32 pm »
These rock!!!!
Izrun...U Da MAN!
Thank-you,  :cheers:
thank-you, :cheers:
 thank-you! :cheers:
KonkeyKong
« Reply #6 on: August 08, 2006, 06:51:59 pm »
Izrun,
If you get a chance can you take a couple pics of the backside of the assembled shifter?  mine appears to be missing the spring and the switch, and the manual I found on KLOV.com is a tad unclear as to how those parts work.
Thanks for all your help, boy, restoring this puppy might take longer than I thought.
Izrun
    • izrun.com
« Reply #7 on: August 09, 2006, 12:59:36 pm »
Sure thing...
--Izrun
Izrun
    • izrun.com
« Reply #8 on: August 09, 2006, 11:20:46 pm »
How's this?  Let me know if you need a different angle.
--Izrun
KonkeyKong
« Reply #9 on: August 09, 2006, 11:42:05 pm »
once again, exactly what I needed. I sure appreciate the time you took to get these shots. great angles!
Thanks again :applaud:
KonkeyKong
Re: need spyhunter yoke gear info
« Reply #10 on: August 11, 2006, 09:03:34 pm »
McMaster Carr has a pretty close, if not next best alternative to the smaller gear diagrammed above.  It has 40 teeth instead of 42, the other dimensions are so close it's scary.  You'd have to drill in the set screw holes which shouldn't be too tough since the gear is molded nylon. At $3.50 a piece you can't go wrong.  I got a couple in the mail today and the teeth mesh beautifully with the larger gear.
McMaster Carr part# 57655 K45
