Author Topic: MameWah 1.62b10 Error on load up??  (Read 3315 times)
lettuce
  • Make It So!
« on: July 30, 2006, 09:20:49 am »
Have just installed the latest beta of Mamewah, and get this message on startup of mamewah,  'An internal error has accured - see c:\mamewah\mamewah.log' then the program closes. When i look at the log there a error message repeated a few times:
Video_Stop
30/7/06 13:20 PM Error: 9 Subscript out of range in Movie_Stop
What is cauing this error
Re: MameWah 1.62b10 Error on load up??
« Reply #1 on: July 31, 2006, 05:21:04 am »
I have just fixed this in my wip version :)
However, the reason for this error to occur (as far as I can tell anyway) is bad configuration...namely if Mamewah cannot find any 'emulators' set up.  You need to create subfolders within \mamewah\config for each platform, and have the associated ini files within...eg:
\mamewah\config\mame\mame.ini
\mamewah\config\mame\mame-0.ini
\mamewah\config\mame\mame-1.ini
etc.
HTH
lettuce
  • Make It So!
« Reply #2 on: July 31, 2006, 12:04:09 pm »
Ok dude, ill give that a go
lettuce
  • Make It So!
« Reply #3 on: August 01, 2006, 12:13:55 pm »
etc.
HTH
I tried that i took the ini file that mame made from the mame directory, place in in mamewah\config\mame, but i still get the same error
« Reply #4 on: August 02, 2006, 07:11:04 am »
Don't put Mame's mame.ini in there....because that is for Mame, not Mamewah.  As long as you create the \config\mame folder, Mamewah will auto-generate the ini file for you.
lettuce
  • Make It So!
« Reply #5 on: August 02, 2006, 11:44:48 am »
The config\mame folder is already there when i install mamewah? Even when i start up mamewah for the very first time after install i get the error message
Malacus
  • Last login:April 17, 2010, 12:42:16 am
  • DANCE!
« Reply #6 on: August 16, 2006, 02:30:20 pm »
i havent really found this anywhere else - had the problem myself and started looking around to find nothing
-open mamewah.ini
change
current_emulator
to
current_emulator                          mame
after that, i cant seem to generate a rom list...
sorry for bumping and old one...
~Classic Gaming Since 1983~
Banacek
  • Last login:November 08, 2017, 05:01:31 pm
« Reply #7 on: August 16, 2006, 08:12:20 pm »
try upzipping the file with either Winzip or XP's built in zip interface. I had the same error, but I used WinRar to unzip the file. After I used XP, it worked fine.
peanut
  • Last login:November 11, 2009, 01:47:29 pm
  • arcade nut
« Reply #8 on: August 17, 2006, 04:48:28 pm »
i also have this error on a clean install of mamewah, and nothing seems to fix it
« Reply #9 on: August 21, 2006, 06:24:29 am »
I would definately recommend using WinZip to unzip my downloads...several people have had problems when using WinRAR.
I can only suggest try v1.62b11 when it arrives....I keep saying this but it should be very soon now...
