Author Topic: Hankin tabletop  (Read 5074 times)
original_maxlamer
  • Last login:November 08, 2007, 08:39:00 am
Hankin tabletop
« on: July 30, 2006, 06:41:14 am »
Has anyone got access to one of these who can check my measurements or has accurate plans
I've wanted to build one of these for a while but couldn't find the plans, and from some of the "project anouncements" threads there are other byoac members whom may also want plans for one of these.
Was at work and one turned up onsite, but i had to rush when taking measurements, and the machine has moved on to another site.
Anyways i slaped togather basic plans which should be enough to work off, or easy enough for someone to complete.
Also there is good reference pictures linked from this thread http://forum.arcadecontrols.com/index.php?topic=23937.0
loadman
    • MaLa
Re: Hankin tabletop
« Reply #1 on: July 30, 2006, 07:14:40 am »
I will check tomorrow night. (That means within 24 hours from this Post time)
loadman
    • MaLa
Re: Hankin tabletop
« Reply #2 on: July 31, 2006, 06:56:40 am »
Let me know if that helps (attached).
FYI  I have an original with the cashbox.
It is very crampt in there (check my website) and had to install extra fans
I could have ditched the cashbox drawer but I wanted that to work
« Last Edit: July 31, 2006, 07:08:06 am by loadman »
original_maxlamer
Re: Hankin tabletop
« Reply #3 on: July 31, 2006, 07:56:16 am »
Huge Thanks to you loadman  ;)
« Last Edit: July 31, 2006, 07:58:34 am by original_maxlamer »
loadman
    • MaLa
Re: Hankin tabletop
« Reply #4 on: July 31, 2006, 06:53:39 pm »
Make sure you alert me if you decide to build one
 :P
« Last Edit: July 31, 2006, 08:57:21 pm by loadman »
original_maxlamer
Re: Hankin tabletop
« Reply #5 on: July 31, 2006, 08:42:07 pm »
Will do mate, it will be a while before i get a chance to start as i would need to make some room for the finished machine.
loadman
    • MaLa
Re: Hankin tabletop
« Reply #6 on: August 27, 2006, 06:51:04 am »
Here are some more dimensions of the top and control panel as requested by Chris
Measurements are in Millimetres
mod
  • Last login:June 18, 2008, 06:19:30 pm
Re: Hankin tabletop
« Reply #7 on: October 08, 2006, 09:52:30 pm »
loadman,
Thanks for your wonderful efforts. I have been hounding Marcus for ages to supply plans on his Hankin cab, however, even though he is still active on these boards, he has not responded to my pm's or made promised plans available.
I love the Hankin design and will be starting construction soon.
Thanks again and will keep in touch.
Regards,
Mod.
loadman
    • MaLa
Re: Hankin tabletop
« Reply #8 on: October 08, 2006, 10:39:24 pm »
loadman,
Regards,
Mod.
Please do I would love to know how you go
