February 11, 2026, 11:31:13 am
For me, each time WinJukebox encounters one of the files it says:ERRORCannot get file sizeThe location of the file and its nameI click 'OK' then WinJukebox says the following about that same file:ERRORCannot load MP3 fileThe location of the file and its name
The name and location of the files it errors on look perfect.
Tinkered some more; let's try this again. Can you try the executable at http://webpages.charter.net/celamantia/jukebox/wincabb9.zip and see if it solves any or all of these problems?Once again, this executable has not been tested much and should not be considered stable, so I recommend you back up your original wincab.exe first.
Chris, I do have an idea though. Why not add an option for sorting those letters as "normal" letters or as your routine currently sorts them? Then people could have it either way they like...
