Author Topic: Testing: Indexing fix for filenames with international characters  (Read 7147 times)
Chris
    • Chris's MAME Cabinet
For those people who have files with international characters that WinCab has not been able to find/index/erxtract tags from/play:  Can you try the executable at http://webpages.charter.net/celamantia/jukebox/wincabb9.zip and see if it solves any or all of these problems?
NOTE: This executable has not been tested much and should not be considered stable, so I recommend you back up your original wincab.exe first.
--Chris
--Chris
JustMichael
  • Mmmmm!! Cheesecake!!
Re: Testing: Indexing fix for filenames with international characters
« Reply #1 on: July 27, 2006, 04:45:28 am »
For me, each time WinJukebox encounters one of the files it says:
ERROR
Cannot get file size
The location of the file and its name
I click 'OK' then WinJukebox says the following about that same file:
ERROR
Cannot load MP3 file
I then click 'OK' and WinJukebox will continue processing files until it hits the next filename with international characters then it says those same things again about the new file.
Lave Laar
  • Last login:January 04, 2022, 06:23:13 am
    • Freeware arcade related programs
« Reply #2 on: July 27, 2006, 05:22:39 am »
I get the same errors as JustMichael.
Chris
« Reply #3 on: July 27, 2006, 08:14:57 am »
ERROR
ERROR
Does the filename look correct in the error messages?
What are a couple of the filenames that are being choked on?
Thanks for your help!
--Chris
--Chris
Lave Laar
« Reply #4 on: July 27, 2006, 01:35:20 pm »
The filenames look correct in the errormessages.
Examples on filenames that doesn't work :
- "Folk og R
pascal
  • Last login:July 27, 2006, 04:41:13 pm
« Reply #5 on: July 27, 2006, 04:41:13 pm »
Hello,
Same error with French characters...
Regards
JustMichael
« Reply #6 on: July 27, 2006, 06:50:21 pm »
The name and location of the files it errors on look perfect.
Chris
« Reply #7 on: July 27, 2006, 10:52:34 pm »
Thank you!  Working on it now....
--Chris
Chris
« Reply #8 on: July 28, 2006, 12:18:42 am »
OK, I'm getting some really weird results with this... going to have to pull this apart and rebuild it, I think...
--Chris
Chris
« Reply #9 on: July 30, 2006, 01:06:10 am »
Tinkered some more; let's try this again.  Can you try the executable at http://webpages.charter.net/celamantia/jukebox/wincabb9.zip and see if it solves any or all of these problems?
Once again, this executable has not been tested much and should not be considered stable, so I recommend you back up your original wincab.exe first.
--Chris
Ralfx
  • Last login:July 30, 2006, 06:53:24 am
« Reply #10 on: July 30, 2006, 06:53:48 am »
Hi Chris
You've done a great job again !
Tested it on a german win xp and it works fine. No "Various Artists" or "Directory Artists" any more.  :applaud:
Thank you very much  :cheers:
Chris
« Reply #11 on: July 31, 2006, 02:20:49 am »
Great!  Thank you for checking this out!
Note that in this version, I believe CD skins are completely broken, so again it's not ready for human consumption... it's really just for testing that Unicode fix.  I'm working on it.
--Chris
--Chris
JustMichael
« Reply #12 on: August 02, 2006, 06:18:23 am »
Well it does read the files now.  Blue
Chris
« Reply #13 on: August 02, 2006, 02:27:34 pm »
Hmm... I must not be using a Unicode-compatible comparison in the sort.  Should be an easy fix.  Thank you for finding this!
--Chris
Chris
« Reply #14 on: August 02, 2006, 09:48:28 pm »
Oddly enough, the Unicode comparison routines I'm using use the ASCII collating sequence... odd. I'll figure it out.
--Chris
Lave Laar
« Reply #15 on: August 03, 2006, 04:16:20 pm »
I believe that this is actually the way it's supposed to be.  The
« Last Edit: August 03, 2006, 04:21:22 pm by Lave Laar »
JustMichael
« Reply #16 on: August 03, 2006, 07:55:40 pm »
not if the "
« Last Edit: August 03, 2006, 08:02:20 pm by JustMichael »
Chris
« Reply #17 on: August 03, 2006, 08:40:41 pm »
Chris, I do have an idea though.  Why not add an option for sorting those letters as "normal" letters or as your routine currently sorts them?  Then people could have it either way they like...
Excellent idea...  I can't possibly know the "correct" alphabetical order for every language that uses high-order characters...  Especially since, theoretically, song titles could be in Chinese characters. Korean, Arabic, presuming the font supports it (the included default font does have the Arabic characters at least)...
--Chris
--Chris
JustMichael
« Reply #18 on: August 08, 2006, 09:42:11 pm »
Well I hope to see something soon.   ;D
Chris
« Reply #19 on: August 08, 2006, 10:10:06 pm »
Me too.  :)
I think I just found the place where CD skins are broken... and now my question isn't "Why isn't it broken" so much as "How did it ever work in the first place?"  I've found a huge design flaw that didn't show itself before because two constants happened to coincidentally have the same value; now that they don't, it's all broken.  Yet another section to gut and redesign from sctatch...
--Chris
