Author Topic: Hantarex Polo Color problem....  (Read 11704 times)
Kevin Mullins
    • Me on Myspace
Re: Hantarex Polo Color problem....
« Reply #40 on: August 14, 2006, 12:46:40 pm »
They are a pretty darn close matchup to eachother.   Go for it !!
LM1203N :
http://pdf1.alldatasheet.com/datasheet-pdf/view/8607/NSC/LM1203N.html
U2203B :
http://www.ortodoxism.ro/datasheets/Temic/mXyzutqw.pdf
Safan
  • Last login:September 07, 2006, 07:02:50 pm
« Reply #41 on: September 07, 2006, 04:10:46 am »
OK i have a similar thingy after cleaning up my cabinet and putting the wrong plugs into each other  :banghead:
A had no blue color, just green & red ...
Switched RGB pin an the jamma plug (soldered), so my blue does work!
So i take a look on the scheme, the good thing is that the 3 colors circuits are identical so you can compare to each other!
Take a look at the electronic board at the back on the tube, swapped the rgb's like i did on the jamma plus and the colors are all working just one missing wile swapping.
Built out my chassis measured all components of that circuit, i had a broken zenerdiode!
Changed also capacitors & transistors as i was afraid of damage after connecting the wrong plug .....
And it works! Lucky me  :P
Oh i have a hantarex mct9110 monitor, but i presume it's much the same ....
« Last Edit: September 07, 2006, 04:12:49 am by Safan »
MacStone
  • Last login:March 01, 2015, 09:33:34 am
« Reply #42 on: November 13, 2006, 11:01:44 am »
Hi guys,
I'm sorry for the lack off updates on this but i have been very, very busy.  :cry:
It's been 3 months since I've came here with my monitor problem, and i finally got it to work with the help of all of you.  :notworthy:
Hopefully i will get some screenshoots once i finish installing the software.
In the meantime, here is a pic of the neck card with the new chip installed.  :applaud:
Cheers,
Mac
grantspain
« Reply #43 on: November 13, 2006, 02:48:15 pm »
thats good news,was the problem the Lm decoder i/c in the end or other
MacStone
« Reply #44 on: November 13, 2006, 02:56:46 pm »
Yes, it was the IC chip.
I've managed to solder a socket onto the board, to facilitate the chip's removal.   :applaud:
Now i keep one spare just in case.
grantspain
« Reply #45 on: November 13, 2006, 03:22:02 pm »
well congratulations and it looks a pretty professional job as well,sockets are always handy.now we just wait to see perfect screen shots
Bunnyuk
  • Last login:May 20, 2017, 05:52:20 am
« Reply #46 on: July 12, 2015, 05:57:16 pm »
Hi guys,
Where can I purchase  these transistors for the neck board, and capacitors?
