Author Topic: Painting in AZ heat = terrible job  (Read 3207 times)
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« on: July 19, 2006, 10:50:02 pm »
So, today I came home and began painting my 3rd coat with Rustoleom black satin. I started by sanding down my second coat with 400 grit sandpaper ( I have been going through 220 - 320 and now 400) Man this thing was looking smooth as glass.
 To make a long story short don't paint in the heat! The temp outside was at least 113 today and in the garage probably even more. I would roll on a layer and by the time I rewet my roller it was beginning to dry on me. Now this thing has roller streaks all over the place. Not to mention the paint is thicker in areas than others. Then to top it off 2 flys landed in my tackey dry surface...
Looks like I will be sanding back down to the 220. :hissy:
My old user name was marlborroman13, but I kicked the habit many years ago!
DaveMMR
Re: Painting in AZ heat = terrible job
« Reply #1 on: July 19, 2006, 10:55:23 pm »
I had to actually move my cabinet indoors to paint for that very reason.  I'm still not doing a great job, but at least it's for a totally different reason.
MYX
    • MYX Digital Blog
« Reply #2 on: July 20, 2006, 08:22:23 am »
Yeah, on my first coat, I made the mistake of trying to paint outside too. Sand and repaint my friend. Paint in your garage at night. For like 2 bucks you can get some .4 mil plastic sheeting and make a little paint booth. Will it keep all dust and bugs out, no, but it will keep most of em out if you are cafeful not to go in and out a lot.
Check out This Post You will see my paint booth. I live in Georgia and there are LOTs of bugs and Pollen. I only had 2 bug incidents, and it was mostly my fault for keeping the front flap of the paint room open. I say mostly a wreckless flying I am sure had something to do with it.
M    Y    X
  • Last login:Today at 03:05:55 pm
« Reply #3 on: July 20, 2006, 10:19:15 am »
I know what you mean - I painted all of the closet doors in the house this past weekend and I brought each one outside to lay flat and so the fumes wouldn't bother the baby.  It was hovering around 100 and they didn't come out as nice as they should have...  Oh well.
somunny
  • Is it hot in here?
« Reply #4 on: July 20, 2006, 01:46:38 pm »
I don't know how you do it, man!  I can barely stand being in our garage for ten minutes.  I've taken up inside projects to pass my first summer in AZ.  ;)
Steve
Banacek
  • Last login:November 08, 2017, 05:01:31 pm
« Reply #5 on: July 20, 2006, 02:01:25 pm »
Hmm, looks like my painting is going to have to be done in the early morning or not at all   :(
AMDman13
« Reply #6 on: July 21, 2006, 12:47:39 am »
It's weird up until about 4 years ago I was the same.. Couldn't stand the extreme heat. Now I'm right at home anywhere from 100-115. I'm just one of those strange desert rats. Just don't put me anywhere cold. I practically need a jacket to go to the movie theater in the summer.
Anyway, the cab is smooth again. Sanded back down with 220 grit this afternoon. I plan to do my painting from now either late at night or crack of butt dawn. Good thing I installed all of that fluorescent shop lighting.
« Last Edit: July 21, 2006, 12:49:44 am by marlborroman13 »
442much
  • Last login:May 23, 2008, 09:27:36 pm
« Reply #7 on: July 22, 2006, 10:20:45 pm »
I just finished painting my cab in Tucson and had similar problems.  If only I could have painted it in the winter.  It didn't come out smooth, but I was able to sand it down with my finish sander.  However, I started to notice that it made a nice very slight texture (which I left on the cab with the final 2 coats).  What I found to help out was to mix in a small amount of floetrol and especially water.  I added the floetrol to the can, but I add water to the paint tray.  My paint looked blue when wet and black when dry, so when it started to turn black, I just added more water and stirred.
Also, I could never get the paint (no problems with the primer) to fully dry until I moved the cab in the house.
AMDman13
« Reply #8 on: July 23, 2006, 12:20:26 am »
I'm using oil based paint, however I am wishing I would have went the latex route more and more. Latex is far more foregiving...
442much
Welcome I myself attended JR High and part of HS in Tucson!
Goz
  • KOTA
« Reply #9 on: July 23, 2006, 10:53:11 am »
Sadly enough since moving to the Phoenix area I have put the painting aspect of my projects on hold until November due to the heat. It hit 118 two days ago...
  • Last login:July 23, 2025, 07:04:20 pm
« Reply #10 on: July 23, 2006, 12:38:42 pm »
Yeah...  I walked outside after work (Right next to SKy Harbor Airport) and I thought I was gonna fall over, lol.  Plus there was a breeze blowing, which makes you feel like you're in a convection oven.   >:D
DaveMMR
« Reply #11 on: July 23, 2006, 01:06:50 pm »
Since I'm not a paint expert, I need to ask: Besides not creating a mess, is there a major advantage to painting outdoors?  I mean, the cab, I assume, will be indoors when it's done.  Why not just bring it in early, lay down some plastic (and make a plastic enclosure too if you don't want dust everywhere), crack a few windows and paint it then?  We all paint our walls/ceiling at some point, why not the cab?
I was originally going to paint outdoors but I envisioned too many problems.  Besides weather (humidity and rain), there's the chance wind might blow debris onto the freshly painted surface or a bug will decide to rest in it.
AMDman13
« Reply #12 on: July 23, 2006, 01:24:50 pm »
DaveMMR
No advantage that I can think of.. I am actually in the garage since I have been sanding in between all of my coats. Makes a huge mess.
Besides, my wife as cool as she has been with this whole cab.... Bringing it in to paint might drive her over the edge!! :)
NightGod
« Reply #13 on: July 23, 2006, 05:30:29 pm »
Personally, I agree with doing the painting indoors. You have MUCH better climate control. Biggest thing to do is handle the dust. I surrounded my work area in hanging plastic. When I was using 220 grit (primer stages) I opened a window and pointed a fan out it. Once I moved to 400 grit (finish/clear coat), the fan wasn't nessicary.
And always wear a respirator mask when sanding, especially at 220 grit, that kicks up a TON of dust. If you ever doubted the need to wear a mask, check the below pic-its a side-by-side of a new mask and the one I wore during the sanding (which was 3 runs at 220 and 2 at 400).
Banacek
« Reply #14 on: July 23, 2006, 08:00:45 pm »
Hey, how would one of you fellow AZ residents feel about helping me work on my control panel? :) I don't have any tools out here with me (I'm an ASU student). Right know I'm finishing up deciding on the layout, then all I really need help with is cutting the shape and the holes.  If you're down let me know! (Sorry to threadjack!)
« Reply #15 on: July 24, 2006, 07:40:46 am »
I'd help you, but I'm only here for the summer...  and I didn't bring any of my tools with me.  I'm interning @ Honeywell.
Banacek
« Reply #16 on: July 24, 2006, 11:32:23 am »
Good for you. How is that working out? One of my friends is interning at Intel and the other is at General Dynamics. Where do you go to school?
« Reply #17 on: July 24, 2006, 05:49:56 pm »
Virginia Tech...  Getting my bachelors degree in Aerospace Engineering in May 2007.  w00t!
AMDman13
« Reply #18 on: July 25, 2006, 12:06:45 am »
I would help, but my wood working ended with the cab. I had Knievel build my CPT for me.. I highly recommended it! His work and detail is well worth the money/blood/sweat and tears!
Banacek
« Reply #19 on: July 25, 2006, 01:14:40 am »
No worries, I was just looking for a way to save some money  ;D
MYX
    • MYX Digital Blog
« Reply #20 on: July 25, 2006, 09:17:42 am »
Wow, your cab should be able to float effortlessly in the air with some concoction of anti gravity magnetics r sumthin. "MDF...Bahhh!!! This sucker is made of cast iron and I can move it upstairs with 1 hand..."
Oooh scary, you might be playing star wars... but for real.
M    Y    X
Banacek
« Reply #21 on: July 25, 2006, 02:30:42 pm »
Hey guys, we got a cold front coming in this weekend (high on Sat is supposed to be 93) so if you got the free time for some painting.. :)
Maverick
  • Last login:August 09, 2006, 09:53:19 pm
« Reply #22 on: July 25, 2006, 06:37:11 pm »
I live in Mohave Valley...better known as HELL. Its been in the 120's so far and I've had to put off all projects until Fall. As a pro painter in the area I can offer a few tips.
!. If using oilbase products - use Penetrol as an additive, it will help it flow much better and keep it from drying too fast.
2. If using Waterbase (Latex) - Use Flotrol
3. Paint before 10:00 or after 10:00
Goz
  • KOTA
« Reply #23 on: July 25, 2006, 07:02:02 pm »
Didn't know there were that many Arizona BYOAC'ers...
« Reply #24 on: July 25, 2006, 08:27:39 pm »
Come next summer, I may be permanently out here.  *crosses fingers*
Sylpher
  • Last login:August 03, 2009, 12:18:44 pm
    • Sylpher's Homepage
« Reply #25 on: July 26, 2006, 08:22:23 pm »
Looks like Az is quite the arcade state. I am also unfortunate enough to be so impatient I can't wait until winter to work on my cabinet in this hellish place.
AMDman13
« Reply #26 on: July 26, 2006, 10:35:03 pm »
I can't wait either.. I've been working on this thing primarly on weekends since Feb.. Seems like it will never be done.
I've been doing all of my painting in the wee hours of the am and the results are much better..
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #27 on: July 28, 2006, 08:23:11 am »
I tried to paint as well, but was not happy with the results.
I am, however, very pleased with the look of laminate on my project.  It is nearly bullet proof and easy to keep clean.  Slightly more work to apply though ;)
John
Galaga... Was there any other game?
ArcadEd
  • Last login:March 04, 2012, 01:25:15 am
  • Arcade-In-A-Box , Relive Your Childhood
    • Arcade-In-A-Box
« Reply #28 on: July 28, 2006, 10:54:03 am »
Me neither, but I'm one of them as well ;).  (Tucson actually)
MYX
    • MYX Digital Blog
« Reply #29 on: July 28, 2006, 01:44:25 pm »
you could put a light coating of sand on the cab in the morning. Leave it outside all day. Bring it back in at night and you should have a glass covered cab. (MYX random thought of the day)
M    Y    X
AMDman13
« Reply #30 on: July 29, 2006, 04:39:34 pm »
Maverick
Thanks I took your suggestion today and bought some Penetrol. This looks like it's going to be the answer to my prayers!
What a difference!
JCL
  • Last login:April 20, 2008, 04:11:10 pm
  • What Are You Looking At?
« Reply #31 on: July 30, 2006, 12:51:35 am »
Wow there really are a lot of Arizonites out there. I had no idea. I'm in Chandler and work at a large semiconductor company. I gave up and making a complete cab and just have a desktop controller.
« Reply #32 on: July 30, 2006, 11:52:49 am »
It's finally starting to cool down a bit.  High of 95 today...   :)
Banacek
« Reply #33 on: July 30, 2006, 12:37:58 pm »
This is only temporary, unfortunately. August will come back with a vengence.
Maverick
« Reply #34 on: July 30, 2006, 12:55:34 pm »
Maverick
What a difference!
You are very welcome. I run a paint company in the valley, and believe me you cant just stop painting because of the heat. If you did you would be out of business.
« Reply #35 on: July 30, 2006, 01:28:19 pm »
August 12 I'm driving back to Virginia...    ;D
