Author Topic: best way to cut t-molding...?  (Read 2985 times)
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« on: July 16, 2006, 09:07:52 pm »
what is the best way to get a straight cut on the end of t-molding...?
        thanks...!
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
Re: best way to cut t-molding...?
« Reply #1 on: July 16, 2006, 09:30:12 pm »
I just used a utility knife, had no problems whatsoever.
My Websites
« Reply #2 on: July 16, 2006, 10:21:13 pm »
I used a utility knife too and it came out fine (not 100% perfect but close enough).  There is a thread around here somewhere where someone used a pipe cutter to get the perfect cut...
  • Last login:Yesterday at 04:38:46 pm
« Reply #3 on: July 16, 2006, 10:55:22 pm »
I used scissors.
somunny
  • Is it hot in here?
« Reply #4 on: July 17, 2006, 09:36:55 am »
I have one of those cutters that places like Home Depot use to cut rubber/plastic tubing.  Perfect cut every time.
Steve
Ken Layton
  • Guru
  • Technician
« Reply #5 on: July 17, 2006, 09:50:23 am »
I used a cutoff wheel in a Dremel tool.
fixedpigs
« Reply #6 on: July 17, 2006, 07:40:14 pm »
thanks for all of the suggestions...!
