October 03, 2025, 12:39:14 am
Try running fastmame instead. Unlike the i686 optimized version, as it could give you a noticable speed increase. It can be up to a maximum of 30% increase, while i686 version is only advertised to give a 3-5% increase in speed, and that's on a pentium chip....www.geoshock.com
fastmame uses microsofts compilers. And it does a better job of optimizing the low level stuffso yes, it does do a good increase. I hear that its more like 10% with spikes up to 30%.but 10% is a HUGE differences when you need it.I've never seen a difference on my athlons between the different normal compiles. So I only used the main one.
