Author Topic: I have a 1.4 Ghz AMD Athlon, should I use the i686 version of MAME .66?  (Read 3602 times)
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
I'm going to grab the new version of MAME tonight and I'm not sure which version to get.  I would assume that I won't get any benefit by running the i686 optimized version on an AMD processor, but I'm not sure.  What do you recommend?
thx,
-Ace-
I want my own arcade controls!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Actually I think you will get some optimization.  Anyway, only one way to really find out,  get both,  run an intesive game with verbose, see if there is significance in fps.
AceTKK
errrr... verbose???
cdbrown
  • Last login:October 16, 2017, 09:52:03 pm
  • Bowowow
I think that's F11 which brings up the fps at the top right corner of the screen.  Make sure you have frameskip off or set to zero.  Run a game that is cpu intensive (alot of the midway games are) and press F11.  You should see some numbers at the top of the screen.
eg 60/60 means doing 60 fps out of a possible 60 fps, that's what you want it to run all the time (but it won't for some games).  May get something like 32/60 where it is running nearly half as slow as it should.
Find some games which slow down and test them on both builds.  You may find that one gives you a few more fps than the other which is always beneficial.
Minwah
    • MAMEWAH
I use STUN Runner and Galaxy Fight for this purpose...they don't seem to run too well on my 1.4Ghz.
  • Last login:February 11, 2026, 07:46:44 pm
Try running fastmame instead.  Unlike the i686 optimized version, as it could give you a noticable speed increase.  It can be up to a maximum of 30% increase, while i686 version is only advertised to give a 3-5% increase in speed, and that's on a pentium chip....
www.geoshock.com
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
www.geoshock.com
tell me more about this fastmame - is it legit? What do they do differently?  How new is this (I haven't heard of it) ?
Heck I remember when compiling with proc optimization flags wasn't done by the mame team's binaries - some other mamer put out builds called Amame or pmame (depending on your processor)... *Shrug* (just sharing some history for no good reason)
Furthermore: where's the source to fast mame (just curious)?!
rampy
« Last Edit: March 11, 2003, 10:21:30 am by rampy »
Lilwolf
fastmame uses microsofts compilers.  And it does a better job of optimizing the low level stuff
so yes, it does do a good increase.  I hear that its more like 10% with spikes up to 30%.
but 10% is a HUGE differences when you need it.
I've never seen a difference on my athlons between the different normal compiles.  So I only used the main one.
What he said :D
Justin
  • Last login:January 08, 2026, 10:28:19 pm
    • Centipede MAME cabinet
I have an Athlon XP 1800+  and just yesterday tested both the normal and the 686 optimized versions of mame.  The 686 MAME was in fact slighlty slower than the std MAME...   but I guess ymmv depending on your exact processor... you did not say you had an Athlon XP... so...
"3 warps to Uranus" -- so I stopped playing!
AceTKK
Re:I have a 1.4 Ghz AMD Athlon, should I use the i686 version of MAME .66?
« Reply #10 on: March 13, 2003, 02:18:49 am »
That's interesting Justin.  I haven't gotten around to testing the two builds head-to-head yet, but I will report back when I have.  My processor is a 1.4 Ghz. Thunderbird core, not the Palamino (XP) core.
-Ace-
