Author Topic: Anyone using PCI Express?  (Read 1376 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: July 08, 2006, 04:03:21 pm »
Hey guys I am building a cab soon, and I have always built computers with AGP.  I will not be using the Arcade VGA or anything like that.  I am just going to be looking for a card that has the component outs and putting it into a Sharp 27inch TV.  Most of the cards and stuff that I see now are PCI Express.  Is PCI Express good and will it work okay with MAME or is AGP better for MAME?  I am trying to determine my MOBO model and Video Card.
NightGod
Re: Anyone using PCI Express?
« Reply #1 on: July 08, 2006, 04:19:53 pm »
PCI Express is perfectly fine unless you end up using an arcade monitor and need an Arcade VGA card, which only come in AGP versions. Since you're going the TV route, you shouldn't have any problems.
Jawadali
  • Last login:March 30, 2010, 09:14:58 pm
« Reply #2 on: July 09, 2006, 03:27:00 pm »
Just to reiterate what NightGod said, There should be no problem using PCI-E. The main benefit for PCI-E is that it allows more bandwith and provides more power for the cards that need it (the current high-end/future cards). AGP 8x still had life left in it, but the industry decided to switch for the afrementioned reasons.
Any card that has TV-out should work (most cards do; many even have component video out which would provide better clairity).
rdowdy95
  • This is my rifle.
« Reply #3 on: July 09, 2006, 06:36:17 pm »
Thanks guys since I am using a 27 inch Sharp TV with component outs I will be going the PCI E route.  Also going to find a good Radeon with the component out hookups.
ahofle
    • Arcade Ambience Project
« Reply #4 on: July 10, 2006, 01:19:59 pm »
Even if you don't find a card with component out you can get a VGA to component adapter.  Try a search around here as I'm certain it's been mentioned before.
