Author Topic: WANTED: someone to mod my sega saturn SCART cable to VGA/RGB cable  (Read 2039 times)
eastbayarb
  • Last login:March 08, 2013, 12:15:06 pm
I just don't have the time to do this. I have a sega saturn scart cable and I need it modified to connect to a VGA port on my monitor (yes, my monitor supports both 15khz and 31.5khz).
I'd do it myself but I work and going to school
thank you!
P.S. I am in the San Francisco Bay area but can ship it!
eastbayarb
Re: WANTED: someone to mod my sega saturn SCART cable to VGA/RGB cable
« Reply #1 on: August 26, 2006, 02:33:11 am »
anyone?
gir26
  • Last login:June 14, 2018, 11:19:25 am
« Reply #2 on: August 26, 2006, 11:24:59 am »
Find a guide and Ill do it for ya!
gir26
« Reply #3 on: August 26, 2006, 11:53:19 am »
Ok, found a guide, but not to convert to vga.
The guide I found was part of a Saturn to Jamma project.
I could build the small circuit easy enough.
What you would be left with is your 3 (rgb) wires and your video sync wire.
Would this format work for you?
I couldnt find any info on a saturn -> vga device/ mod.
Goz
  • KOTA
« Reply #4 on: August 26, 2006, 12:23:13 pm »
I might be selling my modded Saturn with VGA cable and 4meg cart. I likely wont finalize my decision for a week or so.
Here's a link that shows the pinout for just about everything.
LINK
You shouldn't have a problem hacking a cable / making it work if you have the pinout from the link above.
I have everything else you'd need to use it in a cab as well (hacked playstation pads and playstation to saturn controller adapter, etc).
