Author Topic: Missile Command help needed  (Read 2773 times)
GearHead
  • Last login:January 01, 2022, 11:24:59 am
  • need more gear...
« on: June 11, 2006, 08:33:08 pm »
I have a cocktail version of Missile Command that was working nicely but now that I'm considering selling it the machine has decided to give up on life.  Before I start opening up the machine and poking around I was hoping someone here could help diagnose the problem.
The machines turns on and displays this on the screen.  I reseated all the socketed ICs and hit the edge card connectors with an eraser to clean them up.   Any thoughts?  Thanks.
SirPeale
  • Green Mountain Man
Re: Missile Command help needed
« Reply #1 on: June 11, 2006, 10:27:16 pm »
What are the voltages?  I assume you have checked them with a digital multimeter.
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: June 11, 2006, 11:21:41 pm »
 big blue?
« Last Edit: June 11, 2006, 11:31:03 pm by Q*Bert_24/7 »
GearHead
  • need more gear...
« Reply #3 on: June 12, 2006, 12:35:54 am »
Peale,
Yep, I checked all the voltages at the test points on the board.
I get the +12, +5, -5.  The 10MHz and 5MHz clock signals are good too.
I'll check out the video sync levels later.
Q*Bert,
What do you mean by big blue?
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: June 12, 2006, 01:09:18 am »
Big blue is a very large capacitor(about the size of a coke can), located near the x-fmr block, on the metal plate in the bottom of the machine.
It can cause all kinds of wierd problems.
Havok
  • Trade Count: (+17)
« Reply #5 on: June 12, 2006, 12:16:18 pm »
They are notorious for failing in Atari cabs. Bob Roberts sells them:
http://therealbobroberts.net/parts.html
And, a little bit of info about them:
http://therealbobroberts.net/bigblue.html
« Last Edit: June 12, 2006, 12:19:21 pm by Havok »
Kevin Mullins
    • Me on Myspace
« Reply #6 on: June 12, 2006, 01:45:25 pm »
Does the game play "blind" ?
Will it coin up and start a game with sounds and such going on even though you can't see it correctly ?
And does the Missle Command have a TEST or SERVICE switch in it ?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: June 12, 2006, 02:15:53 pm »
Since your voltages look good, I doubt the big blue is at fault (though I am no expert -- I am just assuming that the AC coming IN must be right, if the DC going OUT is right...)
Flip the test switch on, then power up. You will hear some beeps and noise indicating the status of your RAM chips, etc.  The manual will tell you what the beeps mean.
Also clean the board edge traces and make sure the harness is on tight.
NO MORE!!
grantspain
« Reply #8 on: June 12, 2006, 04:00:15 pm »
looks like a graphics ram fault to me,its a long time since i have seen one but did'nt the z80 chip cause faults like this
Q*Bert_OP
  • Oh yes, we did!
« Reply #9 on: June 12, 2006, 08:18:00 pm »
It's possible...
GearHead
  • need more gear...
« Reply #10 on: June 14, 2006, 11:37:50 pm »
I looked at all the DC voltages with a 'scope and they're smooth and clean.  This might rule out Big Blue being the culprit.
The game does not play at all.  Test switch up or down yields the same result - nothing.  No sound or change in the display.  The processor could be it.  Maybe the clock crystal?  I'm getting more of a sine wave than a square wave out of the 10MHz test point.
Any more suggestions?
Thanks.
Q*Bert_OP
  • Oh yes, we did!
« Reply #11 on: June 14, 2006, 11:53:06 pm »
CHeck your processor, I'm not sure about your crystal...
