Author Topic: Safe thickness to leave after Routing?  (Read 1184 times)
lettuce
  • Make It So!
« on: May 29, 2006, 06:24:13 am »
What is the rule of thumb thickness you should leave if you are routing areas for joysticks to fit into? As i dont want to route too deep, and then have the CP splinter and crack when playing as there is not enough thickness in the MDF??
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Safe thickness to leave after Routing?
« Reply #1 on: May 29, 2006, 07:15:04 am »
If you're using 3/4" MDF then just route to the depth of yout joystick mounting plate and it should be fine.... If it seems too thin and weak then glue a plywood backing piece under the bottom surface of the panel or mount a metal strengthening plate under the bottom of the panel.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #2 on: May 29, 2006, 04:20:55 pm »
Leave half an inch.  Fozzy's tip should give you that thickness.  Thinner than that, and you're risking someone's kid hanging on it like it's a handhold on a rock climbing wall and pulling everything out, or at least damaging something that'll be quite hard to repair.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: May 29, 2006, 04:37:18 pm »
Fozzy and Lettuce, you guys need to specify if you're talking about routing on TOP or BOTTOM. I got the impression he meant BOTTOM.
NO MORE!!
lettuce
  • Make It So!
« Reply #4 on: May 29, 2006, 05:17:15 pm »
Yeah i meant routing from under the CP. Ive left 1/4" and that seems to be sturdy with no visable movement of the MDF around the routing areas. Have no plans to have kids playing on it so all should be well.
DrewKaree
  • HAH! Nice one!
« Reply #5 on: May 29, 2006, 07:37:22 pm »
Seems like routing just enough for the mounting plate would be the exact same and wouldn't matter if it were top or bottom.  Is there some other mounting plate you're thinking of?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #6 on: May 29, 2006, 07:58:33 pm »
Leave a quarter inch of material and you'll be fine.
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #7 on: May 29, 2006, 08:43:59 pm »
Ditto. I have routed a half an inch for my wico's and they have held up just fine, even after some drunken Street Fighter.
Capthowdy
  • Last login:April 13, 2015, 03:33:18 pm
« Reply #8 on: May 30, 2006, 02:39:55 am »
I'm planning on leaving a quarter inch of wood plus the 1/8 plexi...that should keep it strong enough.
