Author Topic: Computer PSU Pinout?  (Read 1033 times)
MYX
    • MYX Digital Blog
« on: May 26, 2006, 10:04:08 pm »
As a result of a previous thread, I will be using an additional Computer PUS to supply power to my audio amp as well as other misc. circuts. My question is this... There are a BUNCH of wires in a bundle that run from the CPU to the motherboard. Are these standard? Are the colors standard? What do all the lines do (if they are standard)?
I will need to trick the PSU to think that it is always on and I have read (somewhere???) that if you cross line a to line b it will think that it is been turned on. Any and all help is appreciated. Thanks
M    Y    X
wrench
  • Last login:August 02, 2024, 03:16:38 pm
  • Another project I couldn't say no to
Re: Computer PSU Pinout?
« Reply #1 on: May 26, 2006, 10:45:53 pm »
here's the fix
MYX
    • MYX Digital Blog
« Reply #2 on: May 26, 2006, 11:05:58 pm »
Great that solves that. Any ideas what the rest of the pinouts are for?
M    Y    X
MonMotha
« Reply #3 on: May 27, 2006, 01:08:56 am »
http://xtronics.com/reference/atx_pinout.htm
First link on google.  A cursory inspection against what I rememeber of the pinout seems to indicate it is correct.
The colors are semi-standard.  Orange seems to always be 3.3V, Red is always 5V, yellow is always 12V, black is always ground.  After that there seems to be some variation.  Blue and gray/white are usually used for the negative rails, and green seems standard for the power remote.  Many PSUs will have a label on the side telling you what each color is.
